Nitto Tires psi
Discussion in 'Wheels & Tires' started by WestCoast Fl, Aug 26, 2021.
  1. Aug 26, 2021 at 8:42 AM
    WestCoast Fl
    WestCoast Fl [OP] New Member
    Mick
    2006 Tundra Double Cab
    Bilstien adjustable shocks XD series 17" wheels
    Hey guys a new member here. So I'm about to embark on a 700 mile trip. I have the nitto terra grappler 285/70/R17 116T tire. I wanted to get everyone's opinion on pressure. I called the manufacturer and they are recommending 28# on the front 30# on the rear. At the moment I don't have any chalk to do the chalk thing . These numbers seem low to me . What do you guys think
  2. Aug 26, 2021 at 8:44 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    You’ll get better milage, but a rougher ride at higher pressure?
    air em up to max, then take air out until they quiet down?
    WestCoast Fl[OP] likes this.
  3. Aug 26, 2021 at 8:45 AM
    bsktball55
    bsktball55 New Member
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    I've been running about 38 in my ridge grapplers and they are wearing well. I agree those numbers seem a little low.
    avssuc and WestCoast Fl[OP] like this.
  4. Aug 26, 2021 at 8:51 AM
    Taco-Spike
    Two Trucks
    Ive been running 40 in my terra grapplers. I tried 35 for a while and felt a small sway so bumped them up. Might feel a little more firm, but handles better bumping them up a bit.
  5. Aug 26, 2021 at 8:52 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Use this calculator to get you in the ballpark. Enter the stock tires size and pressures, then enter the size and type of tire you have on the truck. Then you can adjust a couple lbs from there and see what feels best.
    Darkness and WestCoast Fl[OP] like this.
  6. Aug 26, 2021 at 8:53 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    I carried a bicycle pump for several days finding perfect for my motorcycle.
  7. Aug 26, 2021 at 9:28 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    I run ko2 285/70/17 E at 35 psi, different tire but close.
  8. Aug 26, 2021 at 9:35 AM
    WestCoast Fl
    Mick
    I think I'll start at 35-38 psi. My tires are 5 years old. My concern is the summertime heat. Would rather use more gas with lower pressure then have a blow out. Tires say 44 max.
    avssuc and Darkness like this.
  9. Aug 26, 2021 at 10:25 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Safe psi 35-38 is good.Welcome too
  10. Aug 26, 2021 at 12:19 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I have similar tires in a similar size on a similar truck. E rated 285/75/16 yokohama ats on an access cab. I have been running roughly 34 front and 38 rear for a long time.
    If your tires are e rated they like a higher pressure than d or c rated, or even p rated. Good luck.
  11. Aug 26, 2021 at 12:34 PM
    WestCoast Fl
    Mick
    Thanks,
  12. Aug 26, 2021 at 12:35 PM
    WestCoast Fl
    Mick
    Hey thanks I'm not sure about the rating i will definitely check
  13. Aug 26, 2021 at 1:39 PM
    jamess28
    jamess28 New Member
    Tulsa, OK
    2005 DC SR5 TRD Off-road 4x4
    I run Nitto Terra Grappler G2 265/70-17. 36# front and 34# rear. Great ride and even tire wear. I have had these tires since October 2018 and have run about 27k miles on them.
  14. Aug 26, 2021 at 2:00 PM
    10 blue trucks
    10 blue trucks New Member
    04 4WD RCLB
    D rated would be around 65 max
    E rated would be 80 max
    So you Likely have C, SL, or XL. I doubt you would see much benefit over 40
    psi. unless heavily loaded and trying to reduce the wallow of softer sidewalls.
    I have never enjoyed driving over 55 mph, with less than 32 psi in any tire I've tried on a Tundra. The sweet spot will be in there somewhere. Will depend on your specific tire/rating//age/condition and your fully loaded weight for the trip
    FYI -- Higher psi reduces heat due to more air volume, and reduced friction. Not necessarily safer to air down.
  15. Aug 26, 2021 at 3:58 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Im running 38-40 on my 285/80/18 Nitto Ridge.
  16. Aug 26, 2021 at 5:10 PM
    Tires don't blow out from being inflated, they blow out from being underinflated. Underinflation creates more friction and heat which causes the tire to fail. But 28# is not underinflation. The door sticker in my 2000 AC recommends 26# for the factory front tires. The 44psi Max should be used when towing to achieve the maximum load carrying rating for the tire.
  17. Aug 26, 2021 at 5:25 PM
    I have the 285/70/18 RG's and I run mine at 44 psi.
  18. Aug 26, 2021 at 5:27 PM
    To be clear, I do not run 26# in mine. I run 35psi most times. Wear pattern has been great. I rarely have the need to air down, I occasionally air up to tow. 44psi then.
  19. Aug 26, 2021 at 5:56 PM
    WestCoast Fl
    Mick
    Really? The age of tires are showing small dry rot lines between tread and I thought with over inflation it would cause fail. Thanks for reply
  20. Aug 26, 2021 at 6:06 PM
    WestCoast Fl
    Mick
    Thank you. Glad I reached out to you guys
  21. Sep 19, 2021 at 9:38 AM
    avssuc
    avssuc Efilnikufesin
    Gulf Coast
    2021 Tundra TRD Pro LR
    My concern too. We tow a camper, and I run the Tymate Tire Pressure Monitoring System, cheap little Amazon device, let's me monitor heat and PSI, solar powered too.
  22. Feb 23, 2022 at 9:44 AM
    fmscott2
    fmscott2 New Member
    Do those Tymate sensors throw off the balance of your tires?
  23. Feb 23, 2022 at 10:39 AM
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    Nitto told me 38 front / 41 rear for my Ridge Grapplers.
  24. Feb 23, 2022 at 11:52 AM
    avssuc
    Gulf Coast
    To be honest, I'd never even worried about it. IMO, the weight is very nominal and shouldn't be an issue, but I'm not a tire expert, so folks are free to correct my assumption if they know better.
  25. Feb 26, 2022 at 8:00 PM
    Okierunner
    Okierunner New Member
    2020 TRD Offroad Crewmax
    Icon UCA Bilstein 6112/5100 Method 17s Ridge Grappler 35x12.50 Trd Dual exhaust
    I run 32-25 in my Ridge Graps 35x12.50x17
  26. Feb 26, 2022 at 10:11 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Yes @KNABORES is right.
  27. Feb 26, 2022 at 10:19 PM
    alb1k
    Left Coast
    It's good
    Max rating of any tire is what it can handle. E rated are 10 ply sidewall and can handle 80 PSI. If you run your E rated tires at 80 around town or in the dirt, you will have a bad ride and unnecessary tire wear. Determine your pressure for your use, comfort, wear and performance. All things equal, that's 36 pounds on the high end and 32 pounds on the low. Those numbers may change if you are towing, racing or off-roading.
