  1. Feb 24, 2022 at 7:08 PM
    LTC104X4
    LTC104X4 New Member
    2010 Tundra Grade SR5
    None at present
    I removed the old rusted out rear bumper from my 2010 SR5 and installed a replacement. I took the time to coat the inside of the bumper with a zinc rich primer and then an enamel topcoat. The worst problem was breaking of 3 or 4 mounting bolts. I had to drill them out and tap the mounting holes before the reassembly. I also took the opportunity to scrape, chip, prime & paint this area of the undercarriage. The front bumper is next on the agenda. Also looking for an OEM backup camera setup for the 2010. The truck is wired for the backup system front and rear. Is there a premade short harness piece to go from the socket on the rear-view mirror to the 14-pin connector under the overhead console?
    joseph_womack and omgboost like this.
  2. Feb 24, 2022 at 7:14 PM
    oogabooga289
    oogabooga289 New Member
    Christ. When did he start doing door handle covers, too?! Now I have to get them...
    20GR8 Super[QUOTED] likes this.
  3. Feb 24, 2022 at 8:05 PM
    20GR8 Super
    Corey
    PNW Outskirts
    2007 Super White CM Limited
    I’ll have to look into that but assume that replacing the entire door panel can’t be cheap. I think I’ll be a big boy and deal with it and move onto some of other mods I want to do. :D
    Ohannon7 likes this.
  4. Feb 24, 2022 at 8:08 PM
    20GR8 Super
    Corey
    PNW Outskirts
    Don’t know how long they have been available but they are a good fit, and pretty good quality for the price of them.
  5. Feb 26, 2022 at 5:18 AM
    mnm
    mnm Old Guy...
    Mark
    Smithfield, VA
    2008 Tundra Limited 4x4 DC
    Getting the gardens ready...
    Beachcomber, Prostar 190, WVI and 7 others like this.
  6. Feb 26, 2022 at 5:43 AM
    iDon’tRead
    iDon’tRead New Member
    I wish it was spring here in Minnesota so I could work on the truck and car :(
    Mountun Goat and 20GR8 Super like this.
  7. Feb 26, 2022 at 7:25 AM
    Ricos
    Ricos New Member
    Ricardo
    2010 Tundra SR5 White Widow
    Never stopping ...
    Picked up a tundra with the Tundra :D
  8. Feb 26, 2022 at 7:29 AM
    Retroboy1989
    Northern Utah
    It's even a double cab.
    Ricos[QUOTED] and 20GR8 Super like this.
  9. Feb 26, 2022 at 7:30 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    where does one pick one up?
  10. Feb 26, 2022 at 7:31 AM
    Retroboy1989
    Northern Utah
    Is that an rc?
  11. Feb 26, 2022 at 9:13 AM
    RToad
    RToad New Member
    I spent a lot of time wishing it was Spring. I was born and raised in Iowa. Finally got tired of it and moved to South Carolina a little over 4 years ago. Now I just enjoy the weather :)
    joseph_womack and 20GR8 Super like this.
  12. Feb 26, 2022 at 1:49 PM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    2013 5.7 4WD CM Bench-Seat Silver
    6” Pro Comp 37’s Custom audio and interior Off road capability is current focus
    Yesterday I got some things installed but it was dark for pics so here we go.
    1) added optitron gauges, having some issues detailed in another thread, mainly with Info Button wire harness missing 2 wires and I’m a FFV so the gas gauge needs something for it to work properly.
    2) added the AJT all black knobs bc they are cheaper than new black oem ones
    3) added a Voltmeter and 2 USB port combo “cigarette lighter” upgrade, I need this bc I suspect my alternator is dying or not sufficient for the current drain
    4) relocated the dash light dimmer switch to a place that is more usable for my ergonomic needs
    5) painted a white line on the Kicker bass knob for quick and easy dial location identification
    6) Painted the silver ring for the A/C and the 4x4 knobs after tapping off the icons bc the new ones that are black are too much for my cheapness. Sure, it’s a touch ghetto, but I dont care too much I just need it to not be ALL silver
    7) lastly I got tired of my cupholders flopping around when I put the bench seat up so I put a black screw and washer in the bottom and torqued em down. Then I just kinda looked at the truck for 20 minutes in joy and wonder
  13. Feb 26, 2022 at 1:55 PM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    Next for interior I need
    1) a new steering wheel or atleast a nice cover
    2) I’d also like one of those nice full size screens for the head unit like @Shanet421
    3) get rid of chrome Toyota thing in steering wheel
    What I really should be doing is add a winch and more recovery and off road capabilities though
    :mudding:
  14. Feb 26, 2022 at 4:32 PM
    Shanet421
    San Diego,CA
    Nice work I like where your going with it! My head unit was a hand me down from @Gravy and I really do like it for the price I have nothing bad to say at all.
  15. Feb 26, 2022 at 11:12 PM
    Punisher17
    Punisher17 New Member
    Picked up a tundra with the tundra inside another tundra. The tundra picked up also had a tundra inside it too.
  16. Feb 27, 2022 at 3:51 AM
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
  17. Feb 27, 2022 at 12:25 PM
    Tundra3k
    Tundra3k New Member
    Kansas
    2012 Crew Max
    Upgraded all of my door speakers today with some Skar Audio. 6x9's in the front and 6.5's in the rear. Took an hour tops, with all the proper brackets and wiring adapters.
    Prostar 190, RToad, toyofan87 and 9 others like this.
  18. Feb 27, 2022 at 1:49 PM
    Shanet421
    San Diego,CA
    Got any links for what you decided on?
  19. Feb 27, 2022 at 2:51 PM
    Tundra3k
    Tundra3k New Member
    Kansas
    2012 Crew Max
    6x9 adapters - https://www.amazon.com/dp/B00IIC6CPE?ref=ppx_yo2_dt_b_product_details
    6.5" rear door adapters - https://www.amazon.com/dp/B00IIC63P8?ref=ppx_yo2_dt_b_product_details
    Skar 6.5" speakers - https://www.amazon.com/dp/B01BFK1X4A?ref=ppx_yo2_dt_b_product_details
    Skar 6x9 speakers - https://www.amazon.com/dp/B01BFK1U4S?ref=ppx_yo2_dt_b_product_details
    Front and rear door speaker harness - https://www.ebay.com/itm/264948859526
    500 piece mixed bag of panel, fender, etc clips - https://www.ebay.com/itm/392300376196
    Fastener clip pliers - https://www.amazon.com/gp/product/B08YYJ32NC?ie=UTF8
    Pretty straight forward install. I already have the panel tools along with a zip lock bag full of extra clips of all sorts. You'll have to snap the extra tabs on the 6.5" speaker adapters off and then install the speakers onto the bracket. Let me know if you have any other questions.
    Thanks
    myt1, Beachcomber, Ohannon7 and 2 others like this.
  20. Feb 27, 2022 at 8:44 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    2013 Platinum-SOLD 2022 Sequoia, Celestial Silver Metallic
    Uhhh.....yeah, need more info on this. :cool: Does it come in Crewmax?
    WVI and 20GR8 Super like this.
  21. Feb 28, 2022 at 6:52 AM
    aelarson
    aelarson New Member
    AZ
    2011 SR5 Tundra (Silver Sky Metallic)
    Went snowmobiling this weekend after we got dumped on in Northern WI. It was a process to get into the cabin - knee deep to waist deep snow! I managed to bury the Tundra, but was a breeze to get it out with our skid steer.
  22. Feb 28, 2022 at 10:26 AM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    need to put it on a lift and 35s and let it plow through!
    aelarson[QUOTED] likes this.
  23. Feb 28, 2022 at 10:38 AM
    aelarson
    aelarson New Member
    AZ
    I wish - as much as I love the look of a lift and large tires, it isn't very practical for what I use the truck for. A lot of highway miles!
    joseph_womack[QUOTED] likes this.
  24. Feb 28, 2022 at 10:48 AM
    joseph_womack
    Joe
    Louisiana
    yeahhhhhhh I know whatcha mean, that 10 mpg in the city and 12.5 on the highway isn't fun :mad:
  25. Feb 28, 2022 at 11:00 AM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    So I drove a little bit and the Miles Remaining is dropping, I just haven’t driven enough to see the gas needle drop. Regardless, I think I can salvage these gauges and just run the two wires that I need for the Info Buttons to work, then if I really need to I can find a FFV specific cluster thanks to @FredB32 vin lookup help or I can pop-off the needle and reset it the analog way thanks to @Jeff_5_7 idea.
    i did that idea on my JDM orange set just to test popping the needle off and damaging it.
    The horseshoe pry bar worked great.
    then I decided to use acetone and rub off the orange on the needle, pop off OEM faceplates, and tag which LED’s would actually need un-soldered and re-soldered whatever color I want and honestly there’s not that many bc all the other LED’s light up notification icons. I did use too much acetone and melt one of the small needles bc I was not being patient. I’m gonna figure out how to make the optitron work but wanted to know how to adjust the JDM orange as a worst case scenario.
    just waiting on the male pins to arrive to finish the jump wire I need for the Info buttons to work, then I might be popping off the Optitron gas needle. Here’s the cable I am making…
  26. Feb 28, 2022 at 11:30 AM
    Tundra3k
    Tundra3k New Member
    Kansas
    2012 Crew Max
    MTRock, Ohannon7, RToad and 1 other person like this.
  27. Feb 28, 2022 at 11:48 AM
    Tundra3k
    Tundra3k New Member
    Kansas
    2012 Crew Max
    RToad and joseph_womack like this.
  28. Feb 28, 2022 at 11:49 AM
    FredB32
    FredB32 New Member
    Fred
    2011 TRD RW
    Where's "Northern WI" for you, out of curiosity?
  29. Feb 28, 2022 at 11:50 AM
    aelarson
    aelarson New Member
    AZ
    Family cabin is located in Minong.
  30. Feb 28, 2022 at 12:51 PM
    FredB32
    FredB32 New Member
    Fred
    2011 TRD RW
    Fun - I've passed through that way several times. Certainly nice in the summer (especially if you like beef jerky :D). My brother-in-law and his family are from there as well.
