Low oil pressure ?
Discussion in '1st Gen Tundras (2000-2006)' started by MagnoliaTom, Feb 26, 2022.
  1. Feb 26, 2022 at 6:10 AM
    MagnoliaTom
    MagnoliaTom [OP] New Member
    Tom
    Northwest Houston
    2002 Tundra SR5 Access Cab
    Is this low pressure? I’ve found conflicting information that it’s normal for this Gen with 4.7 or that I should replace the oil pressure sending unit. I’m thinking of replacing the sending unit when I change the oil.
  2. Feb 26, 2022 at 6:11 AM
    Is what low pressure?
  3. Feb 26, 2022 at 6:15 AM
    MagnoliaTom
    Tom
    Northwest Houston
    Picture didn’t load. It’s there now
  4. Feb 26, 2022 at 6:36 AM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    It's perfectly normal.
  5. Feb 26, 2022 at 6:38 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Your picture looks normal to me as well.
    MagnoliaTom[OP] likes this.
  6. Feb 26, 2022 at 6:45 AM
    MagnoliaTom
    Tom
    Northwest Houston
    Thanks guys. Is it also normal for the pressure to be below the first mark at idle?
  7. Feb 26, 2022 at 6:48 AM
    des2mtn
    Shady Grove
    Tonto cover
    If this is what you mean by below the first mark at idle - yes, that's normal as well. The gauge likes to move around.
    Jack McCarthy and Schcoman like this.
  8. Feb 26, 2022 at 6:51 AM
    MagnoliaTom
    Tom
    Northwest Houston
    Yes. That’s it. Thanks for the info!
    des2mtn[QUOTED] likes this.
  9. Feb 26, 2022 at 7:03 AM
    It’ll actually go to 3/4 of the first mark after it’s warmed up and idling at a standstill.
  10. Feb 26, 2022 at 8:05 AM
    MagnoliaTom
    Tom
    Northwest Houston
    Here’s my pressure at idle. I was at a light after 90 miles on the highway
    Not quite 1/4 up the first mark
  11. Feb 26, 2022 at 8:23 AM
    IIRC, at startup, mine will slowly rise to just below the middle mark, then drift down to about where yours is between the 1st/2nd mark once warm.
    I was just watching it yesterday after starting cold and waiting for idle to drop.
    Aerindel and MagnoliaTom[OP] like this.
  12. Feb 26, 2022 at 8:39 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Normal warm idle oil pressure is 5-7 psi if I remember correctly.
  13. Feb 26, 2022 at 8:43 AM
    Casper421
    In the woods
    06 DC
    I’ve never experienced any of this “normal” level you guys alway mention. My oil pressure rises to the middle line and never drops. Raises if I step on it but never drops below the middle(normal) line. NOL should be the middle of the gauge.
  14. Feb 26, 2022 at 8:52 AM
    Yours sits right about here, pretty solidly? (my voltmeter doesn't fluctuate like this anymore, and there's more text below the video) https://imgur.com/a/RePgHHB
    That's a short vid of mine when warmed up (5-6 miles of driving). It rises slowly to just above that line in the 1st 30 seconds the engine is running, then settles just below it to the spot shown in the pic, maybe 1-2 needle widths below that line. If I jam on the gas, it will pop a little above the line, but otherwise pretty steady.
    Clearly our trucks are newer, use a different gauge, etc.
    Casper421[QUOTED] likes this.
  15. Feb 26, 2022 at 8:55 AM
    How many rpms are you at idle? Is it around 500 rpms or much higher?
  16. Feb 26, 2022 at 9:04 AM
    Here's normal idle on my VVTi
    Jack McCarthy and Casper421 like this.
  17. Feb 26, 2022 at 9:12 AM
    Casper421
    In the woods
    06 DC
    That’s exactly how mine acts. Right below the middle line, if not right on.
    Once she warms up she’ll sit around 650 in park and 500 in gear, just like @shifty`
  18. Feb 26, 2022 at 9:46 AM
    NickB_01TRD
    KY
    Wonder if people with the early trucks were complaining about what they thought was low oil pressure to the dealers a bunch so in the newer trucks it was configured different.
    Aerindel likes this.
  19. Feb 26, 2022 at 2:36 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Not knowing what early vs newer refers to, I'll simply say on my 2004, that at approx 2000 RPM, mine is dead middle and at idle it is approx 1/4(1st mark up from L. That is where I view it should be because that's how they designed meter presentation IMHO. It also somewhat aligns with what FSM speaks of....idle 4.2psi/3K RPM 43-85 psi
    As for the OP, IMHO, his idiot gauge appears to be a little lazy. It's showing a lower than what I would call normal reading at 2000 RPM and even at idle to suit me. Of course, not knowing how his underhood looks, it could be simply lack of resistance making it back to the gauge. If OP has concerns, removing oil pressure switch and temporarily hooking up an oil pressure gauge, might help alleviate those concerns.
  20. Feb 26, 2022 at 2:51 PM
    chunk
    chunk New Member
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    It's fine, the pressure at idle is between 4 and 5 psi, from the manual.
  21. Feb 26, 2022 at 5:34 PM
    Aerindel
    Aerindel New Member
    Montana
    Just to add weight to what everyone else has said...
    It's perfectly normal behavior for trucks of our year.
    I see you also have the ABS disabled. Good for. Best thing I ever did for my truck was pull the ABS fuses.
  22. Feb 26, 2022 at 6:00 PM
    MagnoliaTom
    Tom
    Northwest Houston
    Actually I have a bad wheel speed sensor that intermittently causes the ABS light to come on. I’ve got a new one ordered from rock auto.
