Day 2 and 128mi = In Shop
Discussion in '3rd Gen Tundras (2022+)' started by 904pizza, Feb 24, 2022.
  1. Feb 24, 2022 at 5:59 AM
    904pizza
    904pizza [OP] New Member
    2022 Tundra SR5 TRD
    Waiting to see what happens, but these alerts popped up this morning. Will see what the dealer says.
  2. Feb 24, 2022 at 6:04 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Bummer.
    avssuc and Taco-Spike like this.
  3. Feb 24, 2022 at 6:05 AM
    Taco-Spike
    Two Trucks
  4. Feb 24, 2022 at 6:07 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    In the engine, throttle or transmission. Thanks for narrowing it down, Toyota. :facepalm:
  5. Feb 24, 2022 at 6:43 AM
    904pizza
    2022 Tundra SR5 TRD
    1 of the turbos failed... Part on back order.
  6. Feb 24, 2022 at 6:50 AM
    BayRunner
    BayRunner I’m here, except when I’m not
    2017 Tundra Platinum
    This new gen…such a joy. o_O
  7. Feb 24, 2022 at 6:52 AM
    CNE0207
    CNE0207 New Member
    Arvada, CO
    2020 Cement CM Limited
    Buy a Toyota for reliability they say….
    bummer man!
    TundraLaw likes this.
  8. Feb 24, 2022 at 6:55 AM
    “J”
    “J” New Member
    NC
    2021 Tundra SR Barcelona Red
    First model year problems. Not surprised at all.
    avssuc, Seafury and Cpl_Punishment like this.
  9. Feb 24, 2022 at 6:59 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I hate to hear that. Hopefully Toyota will get all of these issues worked out before releasing the '23's.
  10. Feb 24, 2022 at 10:09 AM
    BayRunner
    Failing turbos are not first model year issues. These are bad turbos and most likely a vendor issue.
  11. Feb 25, 2022 at 6:33 AM
    nuclear
    nuclear New Member
    And you don't think that issue will be solved in successive years?
  12. Feb 25, 2022 at 6:36 AM
    904pizza
    2022 Tundra SR5 TRD
    I think they will get it fixed in upcoming years, turbos aren't new items, but their vendor likely cut a corner somewhere. I'm worried I'm going to wait 4-6 weeks for turbo 1 to get fixed on the left, only to get 200mi down the road and have the right one that probably was built in the same batch fail.
    ColoradoTJ likes this.
  13. Feb 25, 2022 at 6:41 AM
    Laffingas
    Laffingas New Member
    '22 Tundra Limited - Army Green
  14. Feb 25, 2022 at 6:42 AM
  15. Feb 25, 2022 at 6:43 AM
    Laffingas[QUOTED] likes this.
  16. Feb 25, 2022 at 6:46 AM
    Booney
    Booney New Member
    Northern Colorado Mountains
    Smoked Mesquite 2021 1794 Off Road TRD
    That would make me a little anxious. A person doesn't buy something new just so it can be parked. You got that little taste of something good and then it turns into a Lucy with the football situation.
    Mattedfred and Ruggybuggy like this.
  17. Feb 25, 2022 at 6:57 AM
    Sean492
    Sean492 New Member
    Winston Salem, NC
    2018 MGM Tundra Sport
    I would think they will set you up with a ride while the repair happens and I hope once its repaired you are good to go for a long time.
  18. Feb 25, 2022 at 7:22 AM
    “J”
    “J” New Member
    NC
    Why not? They sourced new parts, such as motor, turbo, probably trans. My 21 didn’t come with a turbo on the 5.7. So I’m imagining that they had to go out and source those parts. Hence, first model year issue.
    Seafury likes this.
  19. Feb 25, 2022 at 7:27 AM
    BayRunner
    Because turbos are not new. The ‘21 with failing power steering is not new but bad parts. Same with the ‘22 turbo. Bad parts not a new model design issue.
  20. Feb 25, 2022 at 7:30 AM
    “J”
    “J” New Member
    NC
    I understand your point, but you’re not understanding mine.
  21. Feb 25, 2022 at 8:34 AM
    BayRunner
    It’s all good brother. I do understand your point but I just look at it differently. No big deal, life moves on :cheers:
    Sean492 and “J”[QUOTED] like this.
  22. Feb 25, 2022 at 8:53 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    What the hell is this monstrosity? Why can't old cartoons just be left alone?
    mountaingroan, Mattedfred and Seafury like this.
  23. Feb 25, 2022 at 9:04 AM
    boyders
    boyders New Member
    But yet your latest year of last gen has had two recent recalls due to part defects so it has nothing to do with what year of production we're in if it is a part defect and NOT a design defect. Supply defects happen in every year man. If there was a design defect in the first year, sure, call it first year issues. This is not a design defect.
    Just because you and some old guard are having emotional issues with losing the v8 and have the opinion that the v6tt is worse doesn't make this a design problem either.
    Cpl_Punishment likes this.
  24. Feb 25, 2022 at 9:04 AM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Ultimately it's Toyota's responsibility to insure that any parts sourced are meeting their quality standards.
    nuclear and Mattedfred like this.
  25. Feb 25, 2022 at 9:11 AM
    “J”
    “J” New Member
    NC
    cheers!
  26. Feb 25, 2022 at 9:16 AM
    “J”
    “J” New Member
    NC
    I think you’re reading way more into my post than what’s there. Technology moves along, if v6 is the future, so be it. I’ll roll with what ever they put out, as long as the quality stays forefront…..
    boyders[QUOTED] likes this.
  27. Feb 25, 2022 at 11:43 PM
    Booney
    Booney New Member
    I love old cartoons. Lucy was a bitch.
