How Bad is this Damage to Repair?
Discussion in '1st Gen Tundras (2000-2006)' started by wth20_20, Feb 25, 2022.
  1. Feb 25, 2022 at 4:47 PM
    wth20_20
    wth20_20 [OP] New Member
    2004 Toyota Tacoma Tundra 4WD SR5 TRD Off-Road Package
    The left shock failed, but not sure if there is more sage than I can see. Hoping folks on here can help identify what needs to be fixed? Would greatly appreciate it.
    Darkness likes this.
  2. Feb 25, 2022 at 4:59 PM
    Remove both shocks, replace both shocks.
    bmf4069, dinosaur, BubbaW and 7 others like this.
  3. Feb 25, 2022 at 5:02 PM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    Not a strut, it's a shock on rear, and just looks like it broke, unable to see upper mount , but looks like you just need to replace it ,but be sure and replace both. The leaf springs take most of the weight, shocks stabilize and smooth the ride. Replace with OEM BILSTIEN , OR GOOD recomendation from others.
    1lowlife and wth20_20[OP] like this.
  4. Feb 25, 2022 at 5:32 PM
    AZTundra
    Paul
    Phoenix, AZ
    Replace rear shocks (x2) and should only be about a 30-45 min job.
  5. Feb 25, 2022 at 5:59 PM
    wth20_20
    Lol, I slid off into a ditch unfortunately...
  6. Feb 25, 2022 at 6:08 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    I would just remove it and straighten it out with a BFH, and then reinstall
    gascap and Darkness like this.
  7. Feb 25, 2022 at 6:15 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
  8. Feb 25, 2022 at 7:00 PM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    Impossible to straighten bent shock piston. Can't beleive you would even suggest that to someone.
  9. Feb 25, 2022 at 7:10 PM
    sn_85
    sn_85 New Member
    Boise
    2006 DC Tundra 4WD, 2013 Land Cruiser, 2022 RAM 2500 Bighorn
    I hope that's a sarcastic recommendation!!!
  10. Feb 25, 2022 at 7:12 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    This kills the shocks.
  11. Feb 25, 2022 at 7:21 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    It was a joke. What year is your first gen?????
  12. Feb 25, 2022 at 7:27 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    Don’t know if this had anything to do with the shock bending that way, but it looks like your missing a leaf spring on the drivers side.
  13. Feb 25, 2022 at 7:55 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I think you're right, good eye.
    Getting the old shocks off the frame is the hardest part. Could take a little time but after that its 10 minutes tops to put the new ones on. Pay attention to where the upper mounts go, there is a hole near them that people use by mistake.
    831Tun likes this.
  14. Feb 25, 2022 at 8:28 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    That's really weird, or at least I've never seen that. Check your leafs for any movement, compare side to side. I'm just wondering if perhaps the center pin broke allowing the axle to move. Doesn't look like it from the pics but worth a couple minutes to visually inspect it well. The shocks look newish, sure they're the correct length?
  15. Feb 25, 2022 at 9:02 PM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    Look really close they are all there.
  16. Feb 25, 2022 at 9:49 PM
    Aerindel
    Aerindel New Member
    Montana
    It costs as much as a new pair of shocks.....how much do you want to spend?
    Also....how the hell did you do that? I've never in my life had that happen to me on any vehicle. I've had shocks so bad they where falling off because of rust...but never buckled like that.
  17. Feb 26, 2022 at 6:30 AM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    It's as easy as this.
