Cv axle cage mod
Discussion in '1st Gen Tundras (2000-2006)' started by Jasont, Feb 24, 2022.
  1. Feb 24, 2022 at 9:08 AM
    Jasont
    Jasont [OP] New Member
    05double cab
    2.5 rough country
    Gotta replace my cv boots, thinking about doing a cage mod. But haven’t really seen or heard much about it.. has anyone done this. Pros and cons please and thank you
  2. Feb 24, 2022 at 9:51 AM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    I've never heard of a cage mod, what is it??
    5N0W808 and Sirfive like this.
  3. Feb 24, 2022 at 10:16 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Ive heard of a bird cage for rear axles, to convert from leafs to arms, but it doesnt work for a front axle? Also confused and interested.
    ok dug a little deeper he’s talking about the innards of the CV. I didnt find toyota stuff,
    but, cage:
    race:
    whats the mod? Polishing?
    FrenchToasty and 831Tun like this.
  4. Feb 24, 2022 at 10:38 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I'm gonna guess modifying the cage to allow increased articulation???
  5. Feb 24, 2022 at 10:55 AM
    Jasont
    05double cab
    2.5 rough country
    Exactly. I saw a post on the 1st gen fb page. Just curious if anyone has done it, and how it worked
  6. Feb 24, 2022 at 3:53 PM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
  7. Feb 24, 2022 at 4:19 PM
    Jasont
    05double cab
    2.5 rough country
  8. Feb 24, 2022 at 4:24 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Your droop/bump/full steer angles are well within what the CVs can handle. Unless you have a special setup that can utilize the increased angle of the CV, you won't be gaining anything.
    Cruzer, Hbjeff, Wynnded and 1 other person like this.
  9. Feb 24, 2022 at 6:08 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Darkness and 5N0W808[QUOTED] like this.
  10. Feb 24, 2022 at 6:14 PM
    Jasont
    05double cab
    2.5 rough country
  11. Feb 24, 2022 at 6:37 PM
    snivilous
    SW UT
    No sir. Usually the upper arm or the shock are the drop limits, not the CV. Easy way to test that is to jack your truck up so the tire is off the ground, and spin the tire. If it spins freely and isn't cogging and sticky then you know your CV is not your droop limit. If I was you I would rebuild or get new CVs and not worry about the cage, I don't think you need to modify it since I don't think it's limiting your performance.
  12. Feb 24, 2022 at 6:49 PM
    Jasont
    05double cab
    2.5 rough country
    that’s the one point I never thought about. Makes perfect sense
    Darkness likes this.
  13. Feb 24, 2022 at 6:49 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The 1st gen Tundra CV axles were used on the 1st gen Tacomas that had 3.5in wider long travel A-arms, like the ones offered by Total Chaos. The CVs were modded for the greater articulation. All that was really done was cutting off a flange the interfered with the axle itself. This allowed for full travel. Nothing was done to the "cages". You only wanted to use the factory Toyota units as they were much stronger than the aftermarket ones as they were cast.
  14. Feb 24, 2022 at 7:58 PM
    Jasont
    05double cab
    2.5 rough country
    So really not much of a need for the tundras
  15. Feb 24, 2022 at 8:00 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Maybe if you’re going for drift car steering angle, but you’d need longer cv axles and control arms.
    bmf4069 and Darkness like this.
  16. Feb 25, 2022 at 7:49 AM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    We were talking about these in another CV thread and I called Trackmotive to see what the difference was in the extended travel and extreme travel. The guy told me they are the same thing but extreme travel is the new branding. The extended travel are branded FVP on RockAuto but have the same part number and look the same. They are only $125 per.
    https://www.rockauto.com/en/moreinfo.php?pk=13489621&cc=1431003&pt=2288&jsn=1595
    Sirfive[QUOTED] and Darkness like this.
  17. Feb 25, 2022 at 8:11 AM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    My bad!!
  18. Feb 25, 2022 at 8:55 AM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    I have 2 rebuilt oem front axles with new kartek boots and cage mod. On the shelf for a few years. You live near VA Beach?
  19. Feb 25, 2022 at 10:13 AM
    Jasont
    05double cab
    2.5 rough country
    Vegas
  20. Feb 25, 2022 at 12:01 PM
    Tundradrenalin
    Virginia Beach, VA
    Bummer.
    Essentially for the cage mod, you'r cutting about 10mm (the entire boot flange) off of the axle housing. Then you put a larger boot, typically the porcshe 930 boot around the entire house and clamp it down. Looks like this: [​IMG]
    FrenchToasty and Wynnded like this.
  21. Feb 25, 2022 at 12:06 PM
    Tundradrenalin
    Virginia Beach, VA
    search on google images "cv cage mod or "cv boot mod" and look at the other tundra site member write ups. The write ups on taco world are good also, basically the same thing. Much easier to do standing up at a work bench than on your back. Cheap investment of parts but terribly messy. I told myself I'd never do it again lol
  22. Feb 25, 2022 at 2:04 PM
    Jasont
    05double cab
    2.5 rough country
    I figured since I’ve gotta re boot em anyways. Why not
