LED cargo lights
Discussion in 'New Member Introductions' started by Estradafix, Jul 8, 2021.
  1. Jul 8, 2021 at 12:53 PM
    Estradafix
    Estradafix [OP] New Member
    Art
    2019 Tundra Trd SR5 Double Cab
    Hello from Vacaville Ca.
    My Tundra is basically stock aside from its sprayed on bed liner, Nerf bar side steps, tonneau cover, and interior storage organizer. I did recently add under railing led lights to the bed which are an awesome addition. My question is, I swapped out the cargo factory bulbs to led bulbs and now the key fob won’t lock the doors. Anyone else experiencing this issue?
    YardBird likes this.
  2. Jul 8, 2021 at 12:56 PM
    Welcome from NY.
    That has been a common problem with some 2018+ Tundras. I believe VLEDS came out with a bulb that doesn't interfere with the key fob/locks.
  3. Jul 8, 2021 at 12:56 PM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    Try different brand of led bulbs
  4. Jul 8, 2021 at 12:56 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Search out some thread in the Lighting section or general search and you will find others.
    It's usually the Cab Break Light bulb that interferes with the FOB distance/range. I had the same issue, tried a different brand bulb and it worked perfectly.
    Estradafix[OP] and mountainpete like this.
  5. Jul 8, 2021 at 12:57 PM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    2024 Tundra Platinum LR
    Yes, you need to get VLeds. They have something in them that doesn’t interfere with the transmitter that is in the roof right near your cargo lights. It’s definitely the bulbs you have messing it up. Mine did the same
    Estradafix[OP] likes this.
  6. Jul 8, 2021 at 12:59 PM
    THinTX
    THinTX New Member
    Tony
    2018 MGM DC 4X4
    Make sure they’re Canbus LEDs. Switch them to off setting instead of door to see if issue is resolved.
  7. Jul 8, 2021 at 1:01 PM
    JerryH
    JerryH Gravy Boatin, I don’t park I dock.
    SOMD
    2020 Crewmax Limited Cement
    I would contact the company of the bulb manufacturer and see if they have bulbs that will not interfere. I had to do this with the Fyre Flys from Amazon. They sent out some new cargo lights that did not interfere.
  8. Jul 8, 2021 at 1:01 PM
    Turn the cargo light switch to off.
    Now try the key fob and see if it works.
  9. Jul 8, 2021 at 1:02 PM
  10. Jul 8, 2021 at 1:12 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    As others have said, common issue across many brands of vehicles with cheap LEDs. @Jim LE 1301 gave an easy way to confirm.
  11. Jul 8, 2021 at 1:33 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  12. Jul 8, 2021 at 1:45 PM
    RdKing
    RdKing Not A Roll Model
    Rich
    Eastern Seaboard
    2019 Tundra Platinum 3R3 / Barcelona Red
    Roadtunes By: Taylor's Audio/Tech12Volts Alma GA. JBL Complete System
    Welcome from Delaware
  13. Jul 8, 2021 at 2:44 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    That's how I found out who the culprit bulb was.
  14. Jul 8, 2021 at 2:58 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  15. Jul 9, 2021 at 7:47 AM
    Estradafix
    Art
    Thanks all! I have some research to do but I'm confident the problem will be resolved with your information.
  16. Jul 9, 2021 at 8:21 AM
    :thumbsup:
  17. Jul 9, 2021 at 9:03 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Odd things can happen to a Tundra with LED bulb swap ins....Some brands have issues, some dont but there are a ton of threads here where folks had some really strange issues, seemingly random, and the cause was a LED bulb somewhere.
  18. Jul 9, 2021 at 3:13 PM
  19. Jul 9, 2021 at 4:41 PM
    SwampThing
    SwampThing New Member
    I didn’t know this was a possible issue, but the VLEDs I have work great in my 2018.
  20. Jul 9, 2021 at 4:54 PM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Yes is has to do with the resistors on the led bulbs. I had the same problem. I got mine from fire flye on Amazon.
  21. Jul 19, 2021 at 6:23 PM
    AlaskanAssassin
    AlaskanAssassin I now walk into the wild
    Alaska
    2020 DC TRD-OR, Cement
    The first set I purchased off Amazon caused the same issue with my key fob. I wasn’t able to lock or unlock the truck if the cargos light were on. If I turned the cargo lights off from the inside, it would work again. I definitely wanted to fix this issue before the Alaskan winter hit.
    I decided to purchase another set (from a different manufacturer) and they worked great….no more key fob issues. These are the ones that did work: https://amzn.to/3xTns6H
  22. Feb 24, 2022 at 2:29 PM
    Rocko9999
    Rocko9999 New Member
    How much brighter are these over stock?
  23. Feb 25, 2022 at 7:22 AM
    mattgecko
    mattgecko The LED Light Guy... MattGeckoLEDs.com
    South San Jose, CA
    2011 Tacoma, Off road, super charged 4x4
    Welcome!
