Meatier looking tires for Platinum but staying stock ...
Discussion in 'Wheels & Tires' started by dlopp64, Feb 24, 2022.
  1. Feb 24, 2022 at 9:49 AM
    dlopp64
    dlopp64 [OP] New Member
    Doug
    Nebraska
    2022 Tundra Platinum 4x4 short bed
    All - Any recommendations and/or pic's showing what tires i could go with if i stay stock wheels, suspension w/ no rub points. This is for a 2022 platinum that has the rear height control air suspension and 20 rims. Looking for a nicer meatier slightly bigger look on tires that still can maintain a smooth quiet ride. Does that exist? :) Looking forward to hearing from all the folks that know way more than this guy.
    TK1979 likes this.
  2. Feb 24, 2022 at 10:05 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Any of the stock size, P load all terrain tires will look much better and perform well in some weather and offroad. Falken, Nitto, Toyo, BFG are always popular around here. If you are strictly street, you may consider Michelin defenders which perform great and last a long time, but do look tame. Personally I went with Wildpeaks- aggressive look, quiet for an AT tire, smooth on the road and 3 peak rated for mud/snow,rain. Hit up discounttire.com or tirerack and you can easily see all the options, prices, features, etc. You have LOTS of options.
  3. Feb 24, 2022 at 10:06 AM
    KroppDuster
    Here. There. Everywhere.
    Bilstein 5100s
    Just to clarify...
    Are you looking for recommendations of larger tire sizes that will fit the stock suspension, or just tire recommendations for the OEM tire size that look more aggressive? Just curious. I can read your post both ways.
    If you want to go larger, I've seen quite a few folks go 295/60/20 easily with no rub on stock suspension. That's about an 1.5" taller and ~1.25" wider of a tire than the stock tires. Here's a pic of one of the trucks with the OEM 20" rims that is currently running that size: https://www.tundras.com/threads/gen-3-2022-wheels-and-tires-photo-thread.101215/#post-2615572
    TK1979 and dlopp64[QUOTED][OP] like this.
  4. Feb 24, 2022 at 10:34 AM
    dlopp64
    Doug
    Nebraska
    Thanks !! Very much appreciated
  5. Feb 24, 2022 at 10:35 AM
    dlopp64
    Doug
    Nebraska
    Yes slightly larger 33”? Thanks for making the assumption and good looking
  6. Feb 24, 2022 at 11:55 AM
    coolbeans
    coolbeans New Member
    I put the All Weather Nokian outpost AT tires on my stock 4 runner. They look fantastic, they are quiet too but are a very functional off road tire.
    Midnight Rider and dlopp64[OP] like this.
  7. Feb 24, 2022 at 11:57 AM
    frichco228
    Frank
    Virginia
    You can fit larger tires no problem on a stock truck. 33s easy, 34s depending. But something to know- that usually means moving from P load to E load (just because that is what they make in larger tires that fit our trucks) , so the ride will be stiffer with the higher load rated tires. It is noticeable, so if best/smoothest ride is your goal, larger than stock tires may not be what you want. Just pay attention to the load rating when you are looking at tire replacement. P is passenger, or standard load. Its what the truck came with from factory but they just dont make many tires larger than stock in that load rating. You will probably be seeing E load as most common, there may be a couple brands of tires in the size that you want that will have D or maybe even standard load.
    Hadelson and dlopp64[QUOTED][OP] like this.
  8. Feb 24, 2022 at 12:01 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Bak Revolver, BedRug, Undercover Swingcase, PopLock, Bilstein 5160(rear), Firestone RideRite, TRD rear sway bar, Coachbuilder +2 rear shackles, Andersen 5” aluminum adjustable hitch, TRD dual exhaust, VLEDS interior leds including the footwell kit, TundraTex FRAC mod, VLEDS LPR backup tag mount led, Husky X-Act mats, Color matched cup holder bezel (silver), Ceramic 20% tint all around, 50% Ceramic windshield, Color Matched door handles & mirror caps, The “Stubby” antenna, AMP Research steps, VLEDS 6”step lights, ToyTec/5100 Bilstein coil overs, 700lbs red ToyTec springs (2.75” lift), 20x9 +18 Method 306 custom painted and custom fit center caps, Gorilla spline lugs, Bridgestone Revo 3s 285/60R20, TRD skid plate, RaptorLiner “Red” tow hooks, 19 Pro black LED headlights, VLEDS Triton V6 turns, Rigid SAE D series fog lamps, 19 TRD hood scoop, 2019 TRD Pro grille, Coachbuilder bumper shims, X-Pel protect under mud guards, Opti Coat Ceramic, Opti Coat Sealed. And some snakes and sparklers, because they are my favorite!
    I’m very happy with my Revo3 from Bridgestone. They are aggressive without being over the top. 9C799761-270A-46B5-BF8F-C0D5FFBFCB15.jpg
    TK1979 likes this.
  9. Feb 24, 2022 at 12:22 PM
    Breathing Borla
    Northern Illinois
    load E?
  10. Feb 24, 2022 at 12:23 PM
    Breathing Borla
    Northern Illinois
    this
    its hard to find tires I like that are not Load E. I think next time Im going to try and stay with a P tire, I'll have to try and find something
    TK1979 and dlopp64[OP] like this.
  11. Feb 24, 2022 at 12:31 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I've been very happy with my Goodyear Wrangler UltraTerrain AT | Discount Tire
    Running 275/60/20, it is a 33" tire.
    Nice aggressive tread with a good-looking sidewall.
    It is SL rated so it rides smoother than a D or E rated.
    I had D rated KO2s and these are much smoother.
    I went in to buy Cooper XLTs, but got these instead.
    [​IMG] [​IMG]
  12. Feb 24, 2022 at 12:35 PM
    dlopp64
    Doug
    Nebraska
    What size and rating are they?
  13. Feb 24, 2022 at 4:27 PM
    Omohundro
    Jody
    McMinnville TN
    Yes, load range E
  14. Feb 24, 2022 at 4:28 PM
    Omohundro
    Jody
    McMinnville TN
    285/69R20
  15. Feb 24, 2022 at 4:44 PM
    ThePolak
    ThePolak 2022 Platinum hunt/tow/haul/family ride on order!
    The Land of the Cobra Chicken
    You took the thread right out of my mind. I was thinking the same - stock 20” wheels and larger tires.
  16. Feb 24, 2022 at 4:55 PM
    Krusher22plat
    Krusher22plat New Member
    22plat
    I have a set of these coming in tomorrow for my black plat…..48lbs
  17. Feb 25, 2022 at 9:04 AM
    patho
    patho New Member
    Hey, do you have pics of these? I've been waiting to see pics other than promo pics!
  18. Feb 25, 2022 at 10:46 AM
    TundyMcTunra
    TundyMcTunra Irrational people are not often convinced by facts
    Lost in the PNW
    2010 Tundra Limited Crew Max 4x4, 2018 Tacoma Inferno TRDORDCSB, 2019 Rav4 Lunar Rock, 1991 4Runner Crawler. Ivan Stewart Edition
    Toyo Open County M/T done and done
    Prostar 190 likes this.
  19. Feb 25, 2022 at 11:02 AM
    ThePolak
    Those look nice. Post up some pics when you get them mounted please.
  20. Feb 25, 2022 at 3:23 PM
    Krusher22plat
    22plat
    Will do……stunner……delayed arrival….TBD
  21. Feb 25, 2022 at 3:27 PM
    ThePolak
    The three words I loathe hearing nowadays… “supply chain issues”. Wishing you a speedy arrival of those babies.
  22. Feb 25, 2022 at 4:35 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    You need some bias ply trepadors, I think that will solve your issues.
  23. Feb 26, 2022 at 8:01 PM
    Joe T
    Joe T New Member
    I ran some toyo at2 (non extreme) 275/60/20 on my ecoboost f150 and they are hands down the best halfton tire I have ran. Light weight and quiet. Little to no decrease in performance.
    Just check the dry weight.
    dlopp64[OP] likes this.
  24. Feb 27, 2022 at 4:16 AM
    Baldwin
    Baldwin New Member
    I had a set of Yokohoma Geolandar AT G015 and they were great. More of a stock replacement, but they are also winter rated and drive really nice.
    sn_85 likes this.
  25. Feb 27, 2022 at 4:58 AM
    Rockanock
    Rockanock 21 Chevy 2500
    BFG KO2’s are my recommendation. Run them on my 2500 and they are great. I’ve been in more mud than I care to admit for work, and they have done fantastic. On road they are quiet and handle well. These or the falken at3’s would be my choice
  26. Feb 27, 2022 at 5:33 AM
    Txduckslayer
    Txduckslayer New Member
    295/65/20 ridge grapplers everything is stock on the truck with the AVS system.
  27. Feb 27, 2022 at 6:11 AM
    Joe T
    Joe T New Member
    295/60 or 295/65?
    295/65 is taller than 35”
  28. Feb 27, 2022 at 7:06 AM
    Txduckslayer
    65
  29. Feb 27, 2022 at 7:09 AM
    Breathing Borla
    Northern Illinois
    Those have to be heavy load e I would guess being that big
  30. Feb 27, 2022 at 7:15 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Of course it does, look no further than Michelin's LTX-AT2s provide the ultimate smooth silent road ride yet have significant enough side snipes to genuinely serve off road sand, mud, rock and loose soil conditions with ease. They don't just look tougher than Michelin Defenders, they are really a lot tougher.
    Now they are not cheap yet what great product is?
    https://business.michelinman.com/tires/michelin-ltx-a-t2
