Little help please
Discussion in 'General Tundra Discussion' started by Reekers529, Feb 23, 2022.
  1. Feb 23, 2022 at 8:42 PM
    Reekers529
    Reekers529 [OP] New Member
    Just started truck and noticed antifreeze running out. Pulled front grill and see that the antifreeze highest point was coming out of first picture. Had front end apart last weekend replacing lights and grill. Never touched this part. Shut truck off restarted and nothing??
  2. Feb 23, 2022 at 8:47 PM
    Reekers529
    Not sure if related other day driving heard a whining when under load. Super cold out stopped put in park rev engine no noise, put in drive whined a little more while moving under load but went away Farley quick.
    Any help would be appreciated thank you!
  3. Feb 23, 2022 at 8:49 PM
    Reekers529
    This is how much came out.
  4. Feb 24, 2022 at 3:11 AM
    1eyedclyde
    1eyedclyde New Member
    Clyde
    NewCastle CO
    21 SC Pearl Platinum
    Hows your coolant level?
  5. Feb 24, 2022 at 4:36 AM
    Windsor
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Where is it leaking from? I see an AC condenser and transmission cooler.
    Are you sure it is coolant?
  6. Feb 24, 2022 at 10:00 AM
    Reekers529
    Overflow is low….. my antifreeze is pink, liquid running out was greenish in color and had antifreeze smell I did wash my truck before coming home it is 12 degrees here, sat in heated garage a good four hours before I went out and worked on it. Gonna top of reservoir and keep eye on it. Really odd it was coming out transmission cooler coil right under AC condenser line.
    Any chance I froze up a bunch of detergent from auto car wash?doesn’t seem likely to me but I’m at a loss.
    Thank you for the replies!
