Wild Peak 275/70/r18 - Do I Need New Wheels?
Discussion in 'Wheels & Tires' started by clee33, Feb 23, 2022.
  1. Feb 23, 2022 at 1:46 PM
    clee33
    clee33 [OP] New Member
    2021 Tundra Double Cab SX
    Hey everybody!
    I'm fairly new to the community and was wondering if I could get some opinions on whether or not I should get new wheels to go with my Wild Peak A/T3 tires and Bilstein 5100 kit. I'm driving a 2021 SR5 SX.
    After consulting a couple local shops, they told me I'd need to replace the stock wheels to prevent rubbing. I wanted to keep the stock wheels but only if there is way to prevent rubbing without trimming. I asked them if spacers would be an option but they said no. I'm also going with the 1.9" lift option for the front 5100's.
    So that being said, what recommendations do you all have as far as tire/wheel set up?
    Any feedback is greatly appreciated! Thanks!
  2. Feb 23, 2022 at 1:50 PM
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    The shops are way wrong. Those will fit fine even BEFORE the lift. They are only 1” bigger. You might have to bend up your stock skid plate with a set of pliers.
    biebs96, clee33[OP] and GODZILLA like this.
  3. Feb 23, 2022 at 1:56 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    I had those exact tires on my unlifted and stock 2016. Fit perfect with stock wheels, no trimming, no rub, no problems.wildpeak side.jpg wildpeak.jpg
    jhardy1979, clee33[OP] and GODZILLA like this.
  4. Feb 23, 2022 at 1:56 PM
    18" TRD Off Road Wheels
    You need a new shop. They are trying to scare you into buying new wheels. Note: I have that exact size Wildpeak on my truck (I do have aftermarket wheels with a +25 offset) and there was some rubbing because the Falken Wildpeaks ran a tiny bit larger than other tires in the same size. That said, none of the rub I had required trimming. Just removal of the little splash guard on the bottom of the front bumper.
    clee33[OP] likes this.
  5. Feb 23, 2022 at 1:57 PM
    frichco228
    Frank
    Virginia
    BTW, I also am running them with my lifted coilovers. I did trim the ears off the factory skid plate, just in case. But with 2 inch lift up front, again no rubbing or issues.
  6. Feb 23, 2022 at 2:41 PM
    clee33
    Thank you for the response! The shops I called probably just wanted me to spend more money for labor and what not. Bending the skid plates isn't a problem for me.
  7. Feb 23, 2022 at 2:45 PM
    clee33
    Looks awesome! :thumbsup: I'm more excited to get them installed now. Thanks for the pics to reference the size.
  8. Feb 23, 2022 at 2:48 PM
    Kanobi13
    Kanobi13 New Member
    Question is do you need new tires....
  9. Feb 23, 2022 at 2:49 PM
    clee33
    You are probably right! The two places I called were the highest rated for off-road shops too which makes me kind of sad. Oh well - the search for an honest shop continues! Thanks for all the info.
  10. Feb 23, 2022 at 2:53 PM
    clee33
    I just bought 4 new ones though :( I'm sure I'll get these installed one way or another haha
  11. Feb 23, 2022 at 3:40 PM
    PermaFrostTRD
    Northern NY
    You definitely don’t need new wheels. If a shop is telling you after their installation that a 1” taller, same width tire as stock is going to rub, then I wouldn’t let that shop change your windshield wipers much less install a lift.
    100’s of members on this forum have run that tire on stock wheels with and without a lift. All without any issues.
  12. Feb 23, 2022 at 3:47 PM
    Kanobi13
    Kanobi13 New Member
    Just giving a hard time i did not need new tires or rims but got them anyway..
    clee33[QUOTED][OP] likes this.
  13. Feb 23, 2022 at 4:52 PM
    clee33
    Duly noted. Thanks for the input.
    PermaFrostTRD[QUOTED] likes this.
