  1. Feb 22, 2022 at 7:07 AM
    Malinois38
    Malinois38 New Member
    Pa.
    2022 Platinum Hybrid WCP
    When you hear the growl, turn on your 4 wheel drive. If the growl stops, then it is your Needle bearing. I have had it for 2 years. Worse in cold weather & never hear it in the summer.
    Toyota diagnosed it & said keep running it.
    WVI[QUOTED] and joseph_womack like this.
  2. Feb 22, 2022 at 8:41 AM
    AstroDude
    AstroDude New Member
    Eddie
    2011 Toyota Tundra Double Cab 4x4
    Ironman 4x4 3.5" lift Stoptech drill and slotted rotors RRW 0 offset rims BMC 35" K02s TrailToys High Clearance Rear Bumper Steel and Kevlar braded brake lines Front diff drop UpTop Overland Rack RoofNest Falcon XL Roadshower 4L IronMan4x4 Awning IronMan4x4 Privacy Tent Custom built bed molle panel (because they don't make them for crew cabs)
    So I have an IronMan4x4 shower tent set up right above the roadshower. I love it and I've had 6 people (not at the same time obviously) use it in one setting. The shower hose ( https://aventuron.com/products/yaki...rikT3Ff7dgoHt3eMt03RKLmH1pcUxSZRoCdB0QAvD_BwE ) is straight garbe EXCEPT for the end pieces. Once you start to bend the hose enough, the aluminum starts to crack/break and water shoots out everywhere.
    To fix this I reused the two circles parts and attached them to a braided hose that I picked up at home depot. ( https://www.homedepot.com/p/The-Plu...gaaJ5mn1vq-ZrkvwBhhoCReoQAvD_BwE&gclsrc=aw.ds )
    The roadshower just heats up via the sun but if that's not enough (for winter time camping) I just use a teapot to boil some water, pour the water into the roadshower, use my quick connect compressor to pressurize the system and boom. Hot sower for about 20min. If a lot of people will be taking a shower, the valve on the right side of the picture can be used to shut off the flow. With that control, 6 people or more can take a shower.
    With aluminum, I don't have to worry about green algae building up within the water tank AND I can offroad as hard as I want without worrying about the attachments breaking off due to carrying 10 gallons of water.
  3. Feb 22, 2022 at 8:31 PM
    WVI
    WVI New Member
    @008 Tundra Limited
    I'll try that.
    Which needle dearing are you refering to?
    Thanks
  4. Feb 22, 2022 at 9:59 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    After fitting Icon RXT leafs a couple weeks ago I gained about 2"+ of down travel so it was time for longer brake lines.
    Ended up finding Old Man Emu's relocation kit. Sure I could have cut, drilled, and painted brackets, but for $15 it was worth my time. Installed in the driveway in 5 minutes.
    ARB / Old Man Emu FK32 is the kit.
  5. Feb 23, 2022 at 4:33 AM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    2013 5.7 4WD CM Bench-Seat Silver
    6” Pro Comp 37’s Custom audio and interior Off road capability is current focus
    What prompted you to extend the lines?
    Did you experience anything negative or did you do it for preventative issues?
    joseph_womack likes this.
  6. Feb 23, 2022 at 5:09 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Speaking of rear leaf springs. Can you guys give me your thoughts on my current OEM springs. I used to tow quite heavy for work but now the truck is my 100 mile daily with no towing in the near future. I’m not looking to lift it at all. Just want a smooth ride.
    Thanks!
    4151F344-849A-4451-B310-9E3F291F7BFA.jpg 49284E66-AE6E-46CF-9A58-65C737DAB3EB.jpg
    D4x4TRD and 20GR8 Super like this.
  7. Feb 23, 2022 at 5:18 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Is it just me or are those leafs more "w" shaped than banana shaped?
    What kind of trailer (tongue weight) were you hooking upto this truck?
  8. Feb 23, 2022 at 5:28 AM
    Malinois38
    Pa.
    It’s probably the front differential where the drive shaft connects. That’s where mine is. Noise usually occurs around 30mph. Like I said, I decided to live with mine, 14yr old truck with 200k. There is an aftermarket fix if you research it.
  9. Feb 23, 2022 at 5:42 AM
    Kwe1982
    Kwe1982 New Member
    Wisconsin
    2007 Tundra and 2011 Sequoia
    man them frames from California are clean, rust sucks.
  10. Feb 23, 2022 at 9:08 AM
    VWTim
    Corvallis, OR
    Looks like just leaf spring wear, my stock leafs with a mini-pack looked like that after being installed for 100K, most of that highway with little to no load. Honestly, if the ride is ok to you, just leave it as-is. Going to an aftermarket leaf pack can soften it up, but most will add lift and reduce overall weight capacity by removing the overload leaf.
    Shanet421 and joseph_womack like this.
  11. Feb 23, 2022 at 9:12 AM
    VWTim
    Corvallis, OR
    While installing the leafs I noticed the brake lines and ABS line were taught at any droop over the current point. You can bend the top bracket for the ABS line and get a bunch of slack, but I had to unbolt the brake lines to drop the axle enough to bolt in the new springs. Currently my Fox pigggypack shocks are acting as downtravel limit, not good. At the bottom of their travel there is just enough room on the brake lines, but won't be with the new shocks. Longer ICON RXT shocks have been ordered and I'll take it easy to not fully flex the truck out until then.
  12. Feb 23, 2022 at 2:20 PM
    WVI
    WVI New Member
    @008 Tundra Limited
    Thanks.
    I drove it a few times in4HI, no change.
    Seems to only start after it drives for a bit.
    Malinois38[QUOTED] likes this.
  13. Feb 24, 2022 at 6:56 AM
    Shanet421
    San Diego,CA
    A couple more black dash pieces showed up yesterday.
    6C1A8BED-9104-493C-9880-C57FBB0A01A9.jpg B57A2301-8BD1-4409-B47F-59C50BF35016.jpg 3F902677-2B03-420B-8293-167ACEDB2957.jpg
  14. Feb 24, 2022 at 7:34 AM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    Shanet421[QUOTED] likes this.
  15. Feb 24, 2022 at 12:00 PM
    D4x4TRD
    D4x4TRD New Member
    Định
    Va beach, VA
    2012 Sr5 DC TRD 4x4 Blaaaaaack baby 4.6liter
    Blacked out front grill badge Bigger tires 305/60r18 Tonneau cover
    3FD253BA-CA07-4BDE-8AEB-DA596A73EF08.jpg 3FD253BA-CA07-4BDE-8AEB-DA596A73EF08.jpg 57233380-6E76-49C8-BFA5-31D1C91626AE.jpg Went from 275/65r18 to a 305/60r18. No modding necessary. But there is probably a quarter inch between tire and upper control arm.
  16. Feb 24, 2022 at 12:13 PM
    FredB32
    FredB32 New Member
    Fred
    2011 TRD RW
    I hate that all my postings are "things I'm set to do as soon as it stops snowing and isn't -20 any more" but...
    Got my pieces to put together a push-button tailgate opener (not tied to my remote or anything, just a simple button).
    wv00097, WVI, joseph_womack and 6 others like this.
  17. Feb 24, 2022 at 3:20 PM
    Shanet421
    San Diego,CA
  18. Feb 24, 2022 at 3:25 PM
    cm.soole
    cm.soole New Member
    Cale
    Thornton, CO
    2011 CM SR5 TRD off road
    I plati-dipped my badges black, new cabin filter. Would really like to upgrade my tires to a 295/70R18 to fill out the wheel wells a little more!
  19. Feb 24, 2022 at 4:42 PM
    Cortez11
    Cortez11 New Member
    2013 DblCab 5.7 4x4
    Went to get my OEM battery checked after it started hard the last few days of negative temps. It checked out good after 9 years!!!!
  20. Feb 24, 2022 at 4:46 PM
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
    Idk why, but doesn’t it seem like OEM batteries last so much longer than aftermarket.
  21. Feb 24, 2022 at 4:51 PM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    That's why I went with OEM on my 2013, it wasn't bad yet but wanted new, and OEM 27R was only 118.00 at dealer. Wired up the old one in the bed as a hookup for accessory plugs in bed, still works great.
    WVI and joseph_womack like this.
  22. Feb 24, 2022 at 4:54 PM
    Cortez11
    Cortez11 New Member
    2013 DblCab 5.7 4x4
    That’s not a bad idea! Mine read 27R which surprised me. I was reading a thread last night that said OEM replacements weren’t available?
  23. Feb 24, 2022 at 5:01 PM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    Yup , you are right , it is 27R for right hand + terminal .
  24. Feb 24, 2022 at 5:38 PM
    Retroboy1989
    Northern Utah
    Some threads on here talk about how crappy the factory batteries are. Some even replace them while they are still good :notsure:
    Ohannon7 likes this.
  25. Feb 24, 2022 at 6:28 PM
    COTundie
    Trey
    Pretty things
    Internet sites are full of opinions
    I am on the Interstate MTP wagon.
  26. Feb 24, 2022 at 6:38 PM
    20GR8 Super
    Corey
    PNW Outskirts
    2007 Super White CM Limited
    Put the AJT door handle covers on and realized my door panels are not black they are dark brown. Also the dash looks black next to the door panel. I’m guessing all with an interior this color are that way or is it just mine? I’m now second guessing how the window switch bezel would look black. I may switch the knobs to black on the dash but leave everything else silver. Would definitely be easier on my wallet since I’m not keen on spray painting things myself. My OCD doesn’t like when I paint things myself.
  27. Feb 24, 2022 at 6:42 PM
    Shanet421
    San Diego,CA
    This is so confusing to me
    Like the truck is going through an identity crisis
    I only had to paint the switch bezel
    20GR8 Super likes this.
  28. Feb 24, 2022 at 6:46 PM
    Tipsovr
    Tipsovr New Member
    2012 RW Crewmax
    The black door handle next to the brown door card looks good to me. Now the rest of the rainbow is a bit busy....
  29. Feb 24, 2022 at 6:46 PM
    20GR8 Super
    Corey
    PNW Outskirts
    I know! That’s why I don’t feel like introducing another color cause I know the black won’t be a perfect match. At least the exterior isn’t this way. :D
  30. Feb 24, 2022 at 6:48 PM
    Shanet421
    San Diego,CA
    I know they make every one of those parts in black except the switch bezels. So kinda stuck painting or wrapping those
