Devil Horns Emblems
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by Andres, Feb 1, 2022.
Thread Status:
Not open for further replies.
  1. Feb 1, 2022 at 6:31 PM
    Andres
    Andres [OP] Devil Horned Member Vendor
    Gang,
    After securing an agreement with Toyota's legal department I'm offering these gems for Tundras, Tacomas and many more!.
    • Precision CNC-machined
    • Direct install onto your factory or after-market grille
    • Installation hardware included
    • Custom-finished options (hand polishing, 3-color anodize, powder coat)
    Available Options:
    Polished with clear anodize
    Black Powder Coat
    Red Powder Coat
    White Powder Coat
    Horns on Fire
    Natural Aluminum (Good option for spray painting)
    Installation:
    *Gently remove the factory emblem by un-clipping it from the grille
    *Locate Devil Horns emblem onto the cavity of the grille, install provided hardware and finger-tighten by hand
    *Snugly tighten all four bolts with a 5/32" Allen wrench also know as hex key
    *Take your truck for a spin to display your newly installed horns :mudding:
    Order direct thru my website: Diazfabrication.com
    Contact me by PM or email: Andres@diazfabrication.com
    Follow me on Instagram: @Diaz_Fabrication
    PM me and ask for a coupon code available for Tundras members only!
    -Andres
    bulldog93 and LarryDangerfield like this.
  2. Feb 1, 2022 at 6:31 PM
    Andres
    Other goodies available for consideration:
    Custom emblems (Front grille or rear hitch)
    Other logos available at Diazfabrication.com
  3. Feb 1, 2022 at 6:47 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I assume these don't work with grilles w safety sensors?
  4. Feb 1, 2022 at 6:51 PM
    Taco-Spike
    Two Trucks
    Correct. You’ll need a relocation
  5. Feb 1, 2022 at 6:58 PM
    2mchfun
    Not certain, but IIRC the size is also different.
  6. Feb 1, 2022 at 7:27 PM
    MadMaxCanon
    Damn safety crap...
    Retired...finally and 2mchfun like this.
  7. Feb 1, 2022 at 8:12 PM
    Andres
    Great question and thanks for asking.
    I doubt the sensor will continue to work with an aluminum emblem in front so for that reason it was designed so it wouldn't be installed with the sensor in place.
    There are sensor relocation brackets available that you may purchase and relocate it underneath the emblem.
    Quite a simple solution.
  8. Feb 1, 2022 at 8:13 PM
    Andres
    :thumbsup:
    Taco-Spike[QUOTED] likes this.
  9. Feb 1, 2022 at 8:16 PM
    Andres
    They're actually the same size but the tabs in the rear for installation is different.
    On the Tacomas the emblems with sensor is bigger but Tundras they're the same size.
    2mchfun[QUOTED] likes this.
  10. Feb 1, 2022 at 8:17 PM
    2mchfun
    Depending on bumper design (baja loop) relocate may or may not work.
  11. Feb 1, 2022 at 8:24 PM
    Andres
    Good point
  12. Feb 22, 2022 at 9:03 PM
    Andres
    Batch closes February 28
Thread Status:
