2021 TRD Pro - fog light loose and pushes in
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by kevinrath, Feb 22, 2022.
  1. Feb 22, 2022 at 6:24 AM
    kevinrath
    kevinrath [OP] New Member
    Kevin
    2021 Lunar Rock Tundra TRD Pro
    295/70R18 Nitto Ridge Grapplers
    Hey everyone.
    My 2021 Tundra TRD Pro rigid fog light is loose and pushes in sometimes. I just got the truck back from a body shop (hit a deer) and I noticed it. They did a great job on everything and I can't remember if it was an issue before the deer collision and fix or not. I'm just not sure if it's something I should contact the body shop about or maybe mention to the dealer when I'm there for service next. The shop did replace the plastic housing around the fog light but not the fog light itself.
    This isn't the entire housing that's loose, it's the fog light itself. It wobbles up and down, and if I push on the right side of the light, it pushes in. The left side of the light seems fine and sturdy.
    Patch999 likes this.
  2. Feb 22, 2022 at 6:30 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    It’s a pretty common issue with plastic front end caps. Get under the truck with some zip ties. You can tie them to the inside of the bumper to keep them from falling out or bouncing around as you drive down the road.
    Pull up to your garage door when you do it because when you tighten the zip ties, you will probably mess up their aim a bit. One will be pointed a little higher than the other. Just get back under the truck and make adjustments until they’re shining level on the door.
    Njmike13 and Patch999 like this.
  3. Feb 22, 2022 at 7:53 AM
    kevinrath
    Kevin
    Were you able to do it without taking the fender liner off?
  4. Feb 22, 2022 at 7:58 AM
    Patch999
    Kyle
    2017 Bad@$$ TRD Pro
    I had to pull mine off but its a pretty quick fix. As mentioned above try to get them aimed right before you tighten everything down. I have one that's a little tilted after. Need to fix it at some point.
    Terndrerrr likes this.
  5. Feb 22, 2022 at 8:00 AM
    kevinrath
    Kevin
    Thanks, I'll probably mess with this at some point. I have a service appointment at the dealership for my 15k mile check-up so I'll just mention it to them too. I've read on here that they usually don't acknowledge or fix the problem, but worth a try.
    Patch999[QUOTED] likes this.
  6. Feb 22, 2022 at 12:22 PM
    cp44
    cp44 New Member
    Aaron
    NoVA
    Tundra TRD Pro
    If the dealer doesn't fix it, follow this https://www.youtube.com/watch?v=2-AtzjszTNQ. Just be careful of pulling the front inside fender off the bracket, its a little brittle. Mine broke off and had to buy that bracket at the dealership.
    bulldog93 and Njmike13 like this.
  7. Feb 22, 2022 at 12:34 PM
    kevinrath
    Kevin
    Thanks! I did come across that but was going to wait to see what the dealer says. I'll definitely do this if the dealer doesn't have any ideas
  8. Feb 22, 2022 at 1:34 PM
    Bad Cow
    Bad Cow GOD Bless The USA
    Georgia USA
    2019 TRD PRO - SUPER WHITE
    Leather Steering Wheel, +1.5" Shackles
    I had to perform this mod back when I bought my truck. Shame on Toyota; This truck is not cheap; The RIGID lights are not cheap. The engineers that designed the mounts need their asses kicked. It's BS that you have to crawl under your $60K truck with F***ing zip ties to fix these lights from bouncing around. Now days you DO NOT get what you pay for. Nothing is built to last anymore.
    nasher75 and kevinrath[OP] like this.
  9. Feb 22, 2022 at 2:27 PM
    Tundra21NS
    Tundra21NS New Member
    2021 Black Tundra limited Nightshade Edition
    Same problem here. My moves around everytime you go over a rough bounce on the road!
  10. Feb 22, 2022 at 2:36 PM
    Terndrerrr
    Music City
    6UR-FE
    It isn’t a problem on the chrome end caps. Anyone want to buy my old ones? :D
    Sierradevil likes this.
  11. Feb 22, 2022 at 3:29 PM
    Bad Cow
    Georgia USA
    Chrome? Just like there's No Crying in baseball, there's No Chrome on my TRD Pro. You almost made me throw up in my mouth. ;)
  12. Feb 22, 2022 at 3:37 PM
    mikesTundra77
    mikesTundra77 BRAAAAP BRAAAP
    M_i_k_e
    earth, sol system
    BLOOD,SWEAT+BEERS
    4 " ready lift kit General grabbers 35" Rock warrior wheels 17" Leather Clazzio seat covers KN intake StartX remote starter HRS sequential tails Custom grille+badge ME-SO map lights+dome light Lots of CHROOOOME
    I did this without removing front wheels due to sheer laziness.... I am fairly thick and had a super hard time squeezing my body in-between the wheel and wheel well. I suggest you take the wheels off it wouldhave been much easier. Also I used about 10 zip ties per fog light. That shit ain't moving. Sorry no pictures.i was so done with it that I refused to have any photos to remind me of how much it sucked.
    Bad Cow likes this.
  13. Feb 23, 2022 at 8:07 AM
    kevinrath
    Kevin
    So it turns out the front fog light is broken and insurance didn't notice so they just re-used the broken one. It should have been completely replaced, but the body shop reused the broken one -- not their fault, insurance fucked up.
  14. Feb 24, 2022 at 5:46 AM
    kevinrath
    Kevin
    Body shop ordered a new fog from toyota and is going to let me know when it arrives so I can get it replaced :amen:
  15. Feb 24, 2022 at 7:18 AM
    Njmike13
    Njmike13 New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    I've been putting this off waiting for a nice weather day. It drives me nuts
  16. Feb 24, 2022 at 9:17 AM
    Big Papi
    Big Papi New Member
    Massachusetts
    2021 Tundra TRD Pro Black
    Mine are loose hard to believe they put them out this way.
    Bad Cow likes this.
  17. Feb 24, 2022 at 10:26 AM
    Chowdah
    Chowdah New Member
    Oceanside, CA
    2020 MBM Tundra TRD Pro
    A.R.E. Truck Cap HD Method Grid Wheels Mickey Thompson Baja ATZP3s
    Yeah mine have always been loose. Super annoying thing about the Pro.
  18. Feb 25, 2022 at 3:05 PM
    kevinrath
    Kevin
    When you say loose, does the entire housing move (the bulb and the plastic bezel)? Or just LED itself?
  19. Aug 24, 2022 at 9:17 AM
    Tundra21NS
    You need to go around it with zip some ties. Mine used to do that also.
    drewpweinerMD likes this.
  20. Aug 24, 2022 at 12:24 PM
    drewpweinerMD
    drewpweinerMD MPG’s are for your moms Prius.
    Jeremy
    2024 Limited TRD OR
    RB20 Slims, BAK X4s, Fabtech Level, Cooper 35's
    Zip ties - Use the good polyurethane ones....
    TrdPro89 likes this.
  21. Aug 25, 2022 at 8:35 AM
    TrdPro89
    TrdPro89 New Member
    Did you have yo remove the wheel well liner to do this?
  22. Aug 25, 2022 at 8:50 AM
    PomDad
    PomDad we having snacks?
    Conrad
    Atlanta
    2021 Cement Limited
    Not the person you replied to, but I'd think you have to. Just be extra careful with the little 'clips' that hold the liner to the housing. They snap super easy!
  23. Aug 25, 2022 at 8:53 AM
    TrdPro89
    TrdPro89 New Member
    Thanks man. I might give it a try this weekend. It is annoying driving at night and the fog lights bouncing all over the place.
  24. Aug 25, 2022 at 12:22 PM
    cp44
    cp44 New Member
    Aaron
    NoVA
    Tundra TRD Pro
    Yes, you have to take of the wheel liner. Look at the youtube video I posted above in post #6 and be careful of the clips mentioned by PomDad. I'd get a flat head screwdriver and gently slid it under the clip to pop it off the bumper then pull to the side to remove the liner slowly. Don't yank it off like he did the video, I've broke mine and it was a $30 piece.
    bulldog93 and drewpweinerMD like this.
  25. Aug 25, 2022 at 12:28 PM
    drewpweinerMD
    Jeremy
    2024 Limited TRD OR
    There is some unbolting and flap removal involved. The youtube video above is perfect for you to follow along. The task is super simple and you'll be done in 10 minutes and be much happier driving down the road at night.
  26. Aug 25, 2022 at 6:09 PM
    TrdPro89
    TrdPro89 New Member
    Thanks. I will review this video and see how it goes.
