Im a dumbass!!
Discussion in 'General Tundra Discussion' started by tundratoofun, Feb 22, 2022.
  1. Feb 22, 2022 at 3:20 PM
    tundratoofun
    tundratoofun [OP] Yall better rednekonize
    Glendale
    Beast
    Son of a motha that is way too tight. I hope I can get auto correct ( did my last oil change) to own up to this nonsense and just make it right. I knew I shouldve just done it myself but I was in a hurry and didnt wanna mess with it. Anyone else have this shit happen? Can it even be removed at this point? How screwed am I?
    Cpl_Punishment likes this.
  2. Feb 22, 2022 at 3:22 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Can you take off the actual housing with the removal tool or is that stuck as well?
  3. Feb 22, 2022 at 3:23 PM
    tundratoofun
    Glendale
    Beast
    I was able to get that plug out and drain it the notches on the tool broke the tab off the housing if that makes any sense
  4. Feb 22, 2022 at 3:28 PM
    MadMaxCanon
    Ah i see, i thought I was looking at the stripped smaller cap thats metal colored. Since its already broken, you can try to jimmy it loose somehow or if that doesnt work you can cut it since its plastic. Luckily since its facing down, you dont really have to worry about getting anything into your engine. Order a metal one right away so its ready when you finally get that plastic one out.
  5. Feb 22, 2022 at 3:29 PM
    tundratoofun
    Glendale
    Beast
    Aluminum housing for the win
    15whtrd, GODZILLA and Patch999 like this.
  6. Feb 22, 2022 at 3:30 PM
    MadMaxCanon
    The broken one in the pic is plastic though right?
  7. Feb 22, 2022 at 3:38 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Bak Revolver, BedRug, Undercover Swingcase, PopLock, Bilstein 5160(rear), Firestone RideRite, TRD rear sway bar, Coachbuilder +2 rear shackles, Andersen 5” aluminum adjustable hitch, TRD dual exhaust, VLEDS interior leds including the footwell kit, TundraTex FRAC mod, VLEDS LPR backup tag mount led, Husky X-Act mats, Color matched cup holder bezel (silver), Ceramic 20% tint all around, 50% Ceramic windshield, Color Matched door handles & mirror caps, The “Stubby” antenna, AMP Research steps, VLEDS 6”step lights, ToyTec/5100 Bilstein coil overs, 700lbs red ToyTec springs (2.75” lift), 20x9 +18 Method 306 custom painted and custom fit center caps, Gorilla spline lugs, Bridgestone Revo 3s 285/60R20, TRD skid plate, RaptorLiner “Red” tow hooks, 19 Pro black LED headlights, VLEDS Triton V6 turns, Rigid SAE D series fog lamps, 19 TRD hood scoop, 2019 TRD Pro grille, Coachbuilder bumper shims, X-Pel protect under mud guards, Opti Coat Ceramic, Opti Coat Sealed. And some snakes and sparklers, because they are my favorite!
    You can unscrew that, you just may have to get creative. I have had oil filters so tight I had to run a big screwdriver through them to get them off. May need one of these..
  8. Feb 22, 2022 at 3:46 PM
    MadMaxCanon
    That would definitely make short work of it.
  9. Feb 22, 2022 at 4:09 PM
    ptat
    ptat New Member
  10. Feb 22, 2022 at 4:10 PM
    MadMaxCanon
    Brute force for the win!
    toyofan87 likes this.
  11. Feb 22, 2022 at 4:31 PM
    TommyTundra
    TommyTundra Oh God the anger’s changing me
    Long Island NY
    2019 PRO
    Klick Wrench Torque Limiting Oil... https://www.amazon.com/dp/B0977XMWL9?ref=ppx_pop_mob_ap_share
    Picked this up on Amazon a few weeks ago
    Solid piece of billet aluminum. Use a standard 3/8 extension and ratchet. Its gauged at 18.2 ft/lbs which is what Toyota specs are and its stamped right on the face also. It came with a certification card attesting to the torque adjustment. For shits and giggles I put my old plastic cap in a vice and tested it with my good torque wrench. Dead on balls. It can also be used to loosen the caps without causing any damage to it. I like it so far
    bulldog93, cran2, RickC and 3 others like this.
  12. Feb 22, 2022 at 4:40 PM
    Omohundro
    Jody
    McMinnville TN
    That’s cool, I ordered one. Tried to order straight from the (Klick Wrench) website but they are sold out, oh well guess Bezos gets a little more cash.
    Elevatormatt likes this.
  13. Feb 22, 2022 at 4:41 PM
    tundratoofun
    Glendale
    Beast
    I have a Dorman on hand. Just gotta get that plastic crap off.im thinkin
    Cpl_Punishment and TommyTundra like this.
  14. Feb 22, 2022 at 4:46 PM
    2mchfun
    Big channel locks usually work well for this type of problem.
    patterson.walter likes this.
  15. Feb 22, 2022 at 4:47 PM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    Damn you tundras.com! I want to be able to retire some day!
    RickC, Omohundro and Cpl_Punishment like this.
  16. Feb 22, 2022 at 4:47 PM
    2mchfun
    Don't forget to swap the screen tube, so don't destroy it in the process.
    Casper3 likes this.
  17. Feb 22, 2022 at 4:54 PM
    tundratoofun
    Glendale
    Beast
    Nope. Im done. Bite the bullet and have it towed to the idiots who cranked it down. They can listen to all my bitching and moaning while they fix the shit
    hagrid likes this.
  18. Feb 22, 2022 at 4:55 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    This ^^^ This ^^^ This ^^^
    Then get something made of metal. Rrrr. Aluminum.
  19. Feb 22, 2022 at 4:55 PM
    Bergy24
    Bergy24 New Member
    I just bought this too. I also just bought the MotivX kit with the funnel and oil filter drain. I plan to use the MotivX filter tool to remove the cap and then the Klik tool to tighten it. Even though they state it’s made to remove it, I don’t want to chance screwing up the torque setting. I don’t loosen bolts with my torque wrench either. I still need to get the metal housing too. Haven’t done my first oil change on my 21 yet.
  20. Feb 22, 2022 at 4:55 PM
    tundratoofun
    Glendale
    Beast
    The Dorman is metal and has a new tube
  21. Feb 22, 2022 at 4:57 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    It needs to be the same length as the stocker. There are shorter tubes that are used on the smaller Toyota cartridge filter engines like the 3.4 liter V6. Most folks have to swap over their stocker into their Dorman or Toyota aluminum cap. Be sure sure sure of the length.
    Radarninja, Toyotoholic and 2mchfun like this.
  22. Feb 22, 2022 at 4:58 PM
    tundratoofun
    Glendale
    Beast
    Thanks for the heads up
  23. Feb 22, 2022 at 4:58 PM
    Bergy24
    Bergy24 New Member
    Not sure about the Dorman but the Toyota metal one has a shorter screen which won’t work correctly with the tundra which is why they need swapped over
    2mchfun likes this.
  24. Feb 22, 2022 at 5:05 PM
    tundratoofun
    Glendale
    Beast
    I just wanna know what the hell I did to deserve the bad luck. 2 steps forward and 50 backwards
  25. Feb 22, 2022 at 5:06 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Been changing my own oil for thousands of years , always installed oil filter hand tight, never have I had one back off, sometimes i have to use the cap wrench to get them off. Now the cartridge type i just torque to spec...why does this have to be so difficult?
    twotrack likes this.
  26. Feb 22, 2022 at 5:07 PM
    tundratoofun
    Glendale
    Beast
    Its not but these damn lube monkeys... When I get it right I will never have this problem again.
  27. Feb 22, 2022 at 5:08 PM
    Roborob70
    Robert
    Oh, btw you are by no means a dumb ass, especially due to someone else's incompetence...
  28. Feb 22, 2022 at 5:09 PM
    tundratoofun
    Glendale
    Beast
    I was just gonna take it to em but try to save $40 and this is what I get.
  29. Feb 22, 2022 at 5:17 PM
    Tundra14Platinum
    Tundra14Platinum I love reading the CoC in my spare time
    2014 Platinum CM Sky Silver
    TRD PRO Grill/Headlights, Swaybar, Eibach
    I see you also put some lube on your O-ring what do you use? I just cover mine in some fresh oil.
  30. Feb 22, 2022 at 5:19 PM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Strap wrench?
    Not sure if there's enough swing space to be effective tho.
