Stock vs 33" MPG
Discussion in 'Wheels & Tires' started by Asetchko, Feb 20, 2022.
  1. Feb 20, 2022 at 12:27 PM
    Asetchko
    Asetchko [OP] New Member
    Hey guys, anyone have any MPG insight on going from stock 32" tires up to 33"s? My truck is a 2013 4x4 base model 4.6L. Thanks
  2. Feb 20, 2022 at 12:29 PM
    The difference is so small at that size that you won't notice it.
  3. Feb 20, 2022 at 12:56 PM
    Tundra1D6
    Tundra1D6 Well that escalated quickly…
    My situation with 33’s leveled on a 2wd; LT tires and 20” oem wheels weighing in at nearly 96lbs on each corner, lost about 2mpg over my almost 1200 miles.
    Now for reference I’m lowered 3/5 on an oem wheel and passenger Goodyear’s and average slightly more. Weight was my largest issue I believe.
    Asetchko[OP] likes this.
  4. Feb 20, 2022 at 2:21 PM
    Welcome from NY.
  5. Feb 21, 2022 at 9:07 AM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    shitty to shittier, probably
    PonyMan, Sean492, 15whtrd and 4 others like this.
  6. Feb 21, 2022 at 9:18 AM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    If you have to ask you can’t afford it.:D
    welcome.
    Hbjeff and Tundra18overland like this.
  7. Feb 21, 2022 at 9:20 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Depends mostly on tire weight and, at lesser degree, on compound softness and thread pattern.
    Same tire, just inch bigger? Unluckily you'll see anything different. Aggressive LT AT, soft compound? -2 MPG.
  8. Feb 21, 2022 at 9:47 AM
    Asetchko
    Hahahaha thanks guys, love the honestly.
  9. Feb 21, 2022 at 10:02 AM
    Yotaholic
    Yotaholic Amateur Professional
    Lone Star Republic
    2011 TRD DC 4.6
    I'm on 33" (275/70/18) BFG KO2's with the stock TRD 5-spoke wheels. No idea the weight but I am averaging 16.1MPG on the trip computer combined city and highway driving with my 4.6L. I have a ranch hand bumper on the front so I imagine I'd do better on the highway with a stock bumper. I also drive like a grandpa.
    D4x4TRD and Asetchko[OP] like this.
  10. Feb 21, 2022 at 12:12 PM
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    The tire design/construction is a far more important factor... so which are they?
    All else being equal (same tire model and load rating) the larger diameter will make your gearing 3% higher and raise your truck .5 inch. No measurable difference.
    Asetchko[QUOTED][OP] likes this.
  11. Feb 21, 2022 at 12:49 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Welcome. I swapped out my 20" OE Sport rims and Bridgestone Dueler Alenza HL tires for 18" SCS rims and 305/65-18 Wildpeaks. The Falkens are HEAVY tires. So...depending on tire weight, your MPGs will vary. I lost 2-3 MPGs on average.
  12. Feb 21, 2022 at 1:03 PM
    rruff
    rruff New Member
    It isn't the weight; that has a tiny affect. Thick tread and AT tread, E load rating, contribute. Did you get a lift too?
  13. Feb 21, 2022 at 1:25 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    The extra tire weight had a little bit of an effect, put that with a 2-2.5" list in the front and you'll notice the drop.
  14. Feb 21, 2022 at 2:43 PM
    ohreary
    ohreary Party!
    2020 Platinum
    I went from 31” to 34” tires and lost 1 or two mpg. My new setup is 1.5lbs lighter at each corner so the mpg loss was likely due to the change in gearing and 3in lift.
    Hbjeff likes this.
  15. Feb 21, 2022 at 2:56 PM
    r1-superstar
    DB
    UTAH
    Hmmm, so rotating mass has no effect on MPGs? I'm pretty sure it does as it will take more revs to get the truck moving. I do know that the wider tire and more aggressive treads also affect MPG. My MPG did not change when I was level vs 3/2" lift with the Wildpeaks. My MPG was mostly changed with the tire change. The difference in diameter doesn't help with MPGs either. lol
    As for the lift. When I leveled the truck and then when I went to the top setting on the 5100s, I didn't notice a drop in MPGs at all.
    Txexplorer23 likes this.
  16. Feb 21, 2022 at 3:06 PM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    I replaced my stock tires with 275/70 18's. I'm on my third set.
    If mpg decreased at all, it was negligible.
  17. Feb 21, 2022 at 3:56 PM
    jhardy1979
    jhardy1979 New Member
    Justin
    MGM 2015 Tundra Crewmax Limited 4x4
    I bet if you calculate it manually you aren't getting that high.
  18. Feb 21, 2022 at 4:00 PM
    Arminius
    Arminius New Member
    2019 Tundra Crewmax Limited OffRoad
    2.5 Kings OEM, no adjusters, ICON RXT Leaf Pack - Option 1, Fuel wheels, 285/60/20 Nitto Ridge Grapplers E load rating Light Truck, TRD duel exhaust, TRC cold air intake, TRD Pro grill
    Here is a copy/paste of a comment I made in another thread. The difference in mpg was drastic (IMO) when comparing lifted with bigger tires and OEM.
    I recently put my 2019 Limited back to the stock suspension and wheels/tires. My avg fuel economy was 12-13 mpg with the 34" 285/20 Nitto Ridge grapplers, 1" lift in rear, and 3" lift in front. Since putting everything back to stock, I now have an average fuel economy of 16.5-17.5 with a best of 19.3 while cruising about 70 mph. My truck doesn't look as cool anymore but it drives so much better and with gas at almost $5/gallon where I live, I can livewith an ordinary looking truck again. LOL!
    Jpd0144, Saltyhero13 and r1-superstar like this.
  19. Feb 21, 2022 at 4:11 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I dont think a 2 inch lift would matter. The TRD Pros come with a 2 inch lift and I think their MPG numbers are the same as a non Pro, right?
  20. Feb 21, 2022 at 4:16 PM
    Arminius
    Arminius New Member
    I can only tell you about my results. I don’t think the TRD Pro is a full 2 inches lift in the front. The tires on the Pro are 275/65/18 Michelin ATX. Increasing the height, width, and weight from that will impact fuel economy. Tread design will also affect it.
    r1-superstar likes this.
  21. Feb 21, 2022 at 4:27 PM
    jonclark96
    jonclark96 Not so new member
    Jon
    Maryland
    2021 Army Green SR5
    I have similar results as @Arminius. I added a 3/1 lift and 275/70r18 rugged treks and went from 15.7 mpg to 13.
    r1-superstar and Arminius like this.
  22. Feb 21, 2022 at 6:23 PM
    rruff
    rruff New Member
    Very little. Tire rolling resistance (internal friction) is the main thing at slower speeds. There can be a big difference depending on the compounds used, thread thickness, how robust the sidewalls are, etc. The big fat heavy tires I put on mine actually do better in town, but that is unusual. It's about the same on the freeway because aero is worse. I don't have a lift yet. Most "offroad" tire makers don't care about mpg, and some are truly awful. If you want to find a tire that doesn't suck too bad, look at the speed rating. High speed is usually good, because the main limiter is temperature, caused by internal friction.
    weihenstephaner likes this.
  23. Feb 21, 2022 at 6:50 PM
    Yotaholic
    Lone Star Republic
    2011 TRD DC 4.6
    Last time I topped off the tank I reset the trip odometer so I can check it manually and I’m going to the gas station tomorrow so I’ll report back.
    jhardy1979[QUOTED] likes this.
  24. Feb 21, 2022 at 9:01 PM
    jhardy1979
    Justin
    I have noticed with my truck it can either be higher or lower than what the truck computer claims its very frustrating.
  25. Feb 22, 2022 at 7:19 AM
    Yotaholic
    Lone Star Republic
    2011 TRD DC 4.6
    According to my own math, I got 16.7 on this last tank. That’s pretty accurate when compared to the trip computer given that I don’t reset the computer every fill up. In theory, the MPG would be a couple percentage points higher than indicated because the tires are a slightly larger diameter than stock which yields a greater distance traveled for a given odometer reading. The tire diameter between what I’ve got and what was stock are close enough that I’ll be conservative and not factor that in.
    5C735FF4-4A1F-4637-B810-F5287311987D.jpg 40011BBC-563A-4D79-B604-CC9A48868221.jpg
  26. Feb 22, 2022 at 11:03 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    2016 4wd w 5.7. Moved from stockers to 275/70-18 E load AT. Between the heavier weight, more aggressive tread, etc I lost 1-2 MPG with normal driving. So yes, you will take a little hit on MPG going larger.
