4 wheel drive not working flashing 4 hi center diff lights
Discussion in '2nd Gen Tundras (2007-2013)' started by 1982 minority, Feb 22, 2022.
  1. Feb 22, 2022 at 4:44 AM
    1982 minority
    1982 minority [OP] New Member
    Scott
    2010 Toyota sequoia
    I recently purchased a 2010 Toyota Sequoia. I know it's not the tundra but I believe my issue could also be an issue with the 2nd gen tundra. When engaging 4 wheel drive my 4hi and center diff lights flash and no 4 wheel drive engagement. Took it to a shop and they scanned it and said 4 wheel drive ECU needs replaced. They only scanned and did not actually troubleshoot further. A remained ECU is $700. And ideas on if I should replace ecu, or troubleshoot elsewhere. I did tap on center and front diff actuators to hopefully get lucky, but to no avail. Any help is appreciated!
  2. Feb 22, 2022 at 4:48 AM
    1982 minority
    Scott
    2010 Toyota sequoia
    Some pictures of the lights and code #
  3. Feb 22, 2022 at 4:57 AM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    Had that replaced like 4x in our 2004 sequoia. It’s $400 less than it was way beck then!
