2nd Gen Toyota Sequoia Toyota C0210 Right Rear Wheel Speed Sensor Signal Malfunction
Discussion in 'General Tundra Discussion' started by SprinterAE86, Feb 22, 2022.
  1. Feb 22, 2022 at 2:31 AM
    SprinterAE86
    SprinterAE86 [OP] New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Bilstein 5100 2.3/1.5, TRD sway bars ft/rr, Cooper Tires Discoverer AT3 XLT 295.70.18, Vision Manx 2 18x9 +12, APS side armor steps, TRD-Pro Grill and Bulge, de-chromed, blackout emblems, OEM mirror caps and flares, TRD shift knob, Leather wrapped steering wheel, All weather mats
    Shy of 230K on the odometer. Code just came up when I was warming it up before leaving work. Managed to erase the code a couple of times, but lately it just stayed on. I crawled underneath and wiggled the connector and wire, and it did look pinched a bit. Reset the CEL, but as soon as I drive, it comes back on. Wiggled the connector and wire, reset, CEL turned off, but as soon as I roll, turned back on again. Thinking I might need a new harness. But does the speed sensor go bad?
    Before I start ordering a new harness and speed sensor, are there other areas I need to diagnose that may have caused this code to pop up? I did read that on Tundras, the oil seal was the culprit. Would it be the same with the Sequoias. That would mean, replacing the wheel bearing and hub, or pressing out the hub and replacing the wheel bearing. The last time it cost me $800CAD bearing, hub and seal since I did not want to bother pressing out the old hub.
    TIA!
