Trd sway bar grommets
Discussion in '2.5 Gen Tundras (2014-2021)' started by Oregon 1 Toyo, Feb 19, 2022.
  1. Feb 19, 2022 at 2:47 PM
    Oregon 1 Toyo
    Oregon 1 Toyo [OP] New Member
    2014 Tundra sr5 double cab 4x4
    32C4E89D-9BF9-408D-B1CF-70B4FC5CFC6A.jpg Anyone know how to get rid of this space on the front sway bar grommets. I just installed it and I can’t get rid of it, is it normal? I installed one on my last tundra and it closed up after driving it but this one won’t close up…torqued the bolts to 51 ftlbs.
  2. Feb 19, 2022 at 2:49 PM
    Bergy24
    Bergy24 New Member
    What about them?
  3. Feb 19, 2022 at 3:16 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Did you just swap in the TRD bar? It’s a bigger OD bar than the stock black one, so you need to use the TRD bushing.
    hANNAbONE and Saltyhero13 like this.
  4. Feb 19, 2022 at 4:05 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Good eye.
    Danman34[QUOTED] likes this.
  5. Feb 19, 2022 at 4:26 PM
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    Same thing happened to me when I put mine on. Check the other side. You are missing a plastic spacer that goes in between the from and the bushing. It looked like it had been missing from the factory. Here is what I order. Not sure why it's sideways. 20220219_192252.jpg
  6. Feb 19, 2022 at 11:28 PM
    Oregon 1 Toyo
    The spacer is there It’s hard to see in the picture. It’s just strange that on my previous 2014 Tundra the original bushings actually closed all the way around the trd sway bar. Where did you order the trd bushings?
  7. Feb 20, 2022 at 3:23 AM
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    I didn’t know there were TRD specific bushings. I used normal ones when I put on my TRD front sway bar lol
  8. Feb 20, 2022 at 3:39 AM
    Bergy24
    Bergy24 New Member
    Swapped my originals. I don’t think the sway bar comes with new bushings.
    Hbjeff likes this.
  9. Feb 20, 2022 at 5:14 AM
    Vizsla
    Vizsla 2 = 2.5
    No TRD/new bushings supplied or required with the sway bar, uses original bushings.
    https://www.sparksparts.com/p-trd-sport-front-sway-bar-frsway
  10. Feb 20, 2022 at 5:15 AM
    Radarninja
    Radarninja New Member
    Ca
    Why swap the sway bar? Is it just looks?
  11. Feb 20, 2022 at 5:16 AM
    Danman34
    Danman34 New Member
    Danny
    I have a sport. So it’s always had the TRD bar, so I may be wrong on the bushing. But here’s the part # for reference. No gap either.
  12. Feb 20, 2022 at 5:17 AM
    Danman34
    Danman34 New Member
    Danny
    Bigger. Heavier. More solid than the stock black one. Translates to less body roll, or “sway”.
    Radarninja[QUOTED] likes this.
  13. Feb 20, 2022 at 7:42 AM
    Oregon 1 Toyo
    Thanks for all the help everyone, my bushings must be wearing out for some reason. May put new ones on just to see if it helps. Like I said I had the same issue with my previous Tundra but it resolved itself just by driving it…
  14. Feb 20, 2022 at 7:53 AM
    ravingndrooling
    ravingndrooling New Member
    2021 Gray TRD
    Swapped my stock bar for a TRD a couple weeks ago, same bushings used and no gap-torqued to 51ft-lbs. I added the rear a few months ago as well. The rear made more of a difference but the front bar was still a significant improvement. I’m pretty sure I read somewhere on this forum that both bars have the same OD, with the TRD being made with heavier stock.
  15. Feb 21, 2022 at 1:10 PM
    PonyMan
    PonyMan Old Man
    Central, Louisiana
    2021 Tundra CrewMax 4WD Limited Nightshade Special Edition MGM
    So the little square plastic spacer is in there?
  16. Feb 21, 2022 at 1:17 PM
    Oregon 1 Toyo
    Yes, and I pulled the grommets off today and regreased them and made sure the open end was towards the front of my truck this time tightened it up and it’s all good nowE3C83FF3-F51D-4107-A060-A9F9C8071F84.jpg
    PonyMan likes this.
  17. Feb 21, 2022 at 1:19 PM
    Oregon 1 Toyo
    If anything make sure the open end of the grommet is towards the front and you don’t need special sized grommets for the trd sway bar.
  18. Feb 21, 2022 at 1:26 PM
    PonyMan
    PonyMan Old Man
    Central, Louisiana
    Oh yea! Got it now!
  19. Feb 21, 2022 at 1:31 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    What did you use for grease??
  20. Feb 21, 2022 at 4:14 PM
    Danman34
    Danman34 New Member
    Danny
    You’re not supposed to grease the sway bar bushings. The bushing is supposed to deform, grip and prevent the sway bar from moving or rotating. Greasing the bushings, especially the oem rubber ones completely defeats the purpose of the deform bushing.
    Hbjeff likes this.
  21. Feb 21, 2022 at 4:22 PM
    Bergy24
    Bergy24 New Member
    This is for the rear, but per the instructions you are to lube the bushings.
    bulldog93 and snivilous like this.
  22. Feb 21, 2022 at 4:38 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Just using logic, the grease on the bushing shouldn’t matter. You want the sway bar to pivot as the suspension cycles together, the sway bar itself will twist in a corner for example limiting the independent cycling
    snivilous likes this.
