  1. Feb 20, 2022 at 6:06 PM
    FireCpt
    FireCpt New Member
    Michael
    Vine Grove, KY
    2020 SR5 TRD
    TRD Pro grill swap. TRD Pro wheel swap. Go Rhino RB20 running boards.
    I may split it up if no one wants the set. I actually have an extra (used) black 4x4 badge I could send you for free that was given to me that I didn't use. Just needs new 3M mounting tape.
    Omohundro likes this.
  2. Feb 20, 2022 at 6:09 PM
    GatorBodine
    GatorBodine New Member
    Looks great. Were you able to take off the front door handles without removing the inner door panel? Unless you don't have the touch unlock feature...
  3. Feb 20, 2022 at 6:32 PM
    PaulROahu
    PaulROahu New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    2022 TRD peddles, only had to drill for the parking brakes right in the center and trim a little of the back side top rubber trim.
  4. Feb 20, 2022 at 7:10 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    Finally had an off weekend so I got to do truck stuff.
    Yesterday I redid the lighting in the bed since a bunch of the LED bulbs burned out. I had to redo all of it since the new lights strips had different connectors than the older lights despite being the same brand. Then rotated the tires and change the cabin air filter.
    Today I did my first oil change (dealership did all the previous ones) and thanks to the knowledgeable folks here I bought all the cool stuff to make it easier. Replaced the engine air filter and topped off the windshield wiper fluid. And finally installed the Valhalla Shield that I got in December. Some piece of mind with that installed.
    GAknight, pvn.beluga and AZTundra like this.
  5. Feb 20, 2022 at 7:10 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Bak Revolver, BedRug, Undercover Swingcase, PopLock, Bilstein 5160(rear), Firestone RideRite, TRD rear sway bar, Coachbuilder +2 rear shackles, Andersen 5” aluminum adjustable hitch, TRD dual exhaust, VLEDS interior leds including the footwell kit, TundraTex FRAC mod, VLEDS LPR backup tag mount led, Husky X-Act mats, Color matched cup holder bezel (silver), Ceramic 20% tint all around, 50% Ceramic windshield, Color Matched door handles & mirror caps, The “Stubby” antenna, AMP Research steps, VLEDS 6”step lights, ToyTec/5100 Bilstein coil overs, 700lbs red ToyTec springs (2.75” lift), 20x9 +18 Method 306 custom painted and custom fit center caps, Gorilla spline lugs, Bridgestone Revo 3s 285/60R20, TRD skid plate, RaptorLiner “Red” tow hooks, 19 Pro black LED headlights, VLEDS Triton V6 turns, Rigid SAE D series fog lamps, 19 TRD hood scoop, 2019 TRD Pro grille, Coachbuilder bumper shims, X-Pel protect under mud guards, Opti Coat Ceramic, Opti Coat Sealed. And some snakes and sparklers, because they are my favorite!
    I like, where did you get them?
    Retroboy1989 likes this.
  6. Feb 20, 2022 at 7:12 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I like those. There was a time they had similar ones for the Gen 2
  7. Feb 20, 2022 at 7:12 PM
    Omohundro
    Jody
    McMinnville TN
    Mounted the tri-color emblem here.
  8. Feb 20, 2022 at 7:55 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Ok cool. Keep me posted if you decide to spit them up.
  9. Feb 20, 2022 at 7:56 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Yup now that the new 22’ Tundras have them. It’s back in style…hehe
  10. Feb 20, 2022 at 7:57 PM
    Retroboy1989
    Northern Utah
    OEM? Can the Toyota ones be retro fit?
    PaulROahu[QUOTED] likes this.
  11. Feb 20, 2022 at 7:59 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    I’m sure the dealership has them, but might be $$$ versus Amazon $$. I had the same ones on my 07’ Tacoma
    Retroboy1989[QUOTED] likes this.
  12. Feb 20, 2022 at 8:02 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Amazon
  13. Feb 20, 2022 at 8:15 PM
    Retroboy1989
    Northern Utah
    I found what I think are the right ones, but it says Camry and Highlander?
  14. Feb 20, 2022 at 8:18 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Yes make sure the gas peddles are the same type and only the parking brakes needs slight mod to it, nothing complicated just drill the center using the back center hole as template and drill to the size of your bolt. I found the same size as the rubber circles and got the black hex bolts
  15. Feb 20, 2022 at 10:16 PM
    jhardy1979
    jhardy1979 New Member
    Justin
    MGM 2015 Tundra Crewmax Limited 4x4
    Where did you get the TRD badge?
    AZTundra[QUOTED] likes this.
  16. Feb 21, 2022 at 12:48 AM
    montez25
    montez25 New Member
    2020 toyota tundra platinum 4x4
    Behind you? Come on man. Just do it. You deserve it:bananadance:
    r1-superstar and Brettstation37 like this.
  17. Feb 21, 2022 at 6:23 AM
    Brettstation37
    Brettstation37 New Member
    Brett
    Catskills NY
    2020 Tundra CrewMax TRD Sport
    @Beer Man its never too late to turn it up!
  18. Feb 21, 2022 at 7:10 AM
    AZTundra
    Paul
    Phoenix, AZ
    I bought the TRD badge from @twintundra31719 maybe he can chime in where he bought it from. It's very nice quality and I'm really happy with it.
    jhardy1979[QUOTED] likes this.
  19. Feb 21, 2022 at 7:13 AM
    Taco-Spike
    Two Trucks
    jhardy1979 and AZTundra[QUOTED] like this.
  20. Feb 21, 2022 at 7:18 AM
    AZTundra
    Paul
    Phoenix, AZ
  21. Feb 21, 2022 at 7:42 AM
    AggiePhil
    College Station, TX
    Seems extremely counter-intuitive.
    2mchfun, AZBoatHauler and Do58 like this.
  22. Feb 21, 2022 at 7:50 AM
    twintundra31719
    twintundra31719 New Member
    NV
  23. Feb 21, 2022 at 7:51 AM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    so what did you do with the SDHQ sliders ;)
  24. Feb 21, 2022 at 7:59 AM
    AZTundra
    Paul
    Phoenix, AZ
    @DuneShoot took the SDHQ sliders back in November.
    BiggHertz[QUOTED] likes this.
  25. Feb 21, 2022 at 9:47 AM
    poheller
    poheller 2018 Platinum
    Scot
    The great state Ohio
    2018 platinum
    Installed replacement running boards so the wife can get in easer, plus they look better then the last ones. New ones are Steelcraft. Plus added assist handles in the back. Seat jackers next up on the block. No pun intended.
  26. Feb 21, 2022 at 9:48 AM
    Taco-Spike
    Two Trucks
    Time to empty the trash can ;)
    looks good though
    AZTundra likes this.
  27. Feb 21, 2022 at 9:48 AM
    poheller
    Scot
    2018 platinum
    Lol, did that after the pictures.. lol
    Taco-Spike[QUOTED] likes this.
  28. Feb 21, 2022 at 9:50 AM
    NyteRyder3
    NyteRyder3 New Member
    Birmingham, AL
    Yes, the door handles were super easy to take off. Just one t30 screw and then they slide and come off. The badges were a different story
  29. Feb 21, 2022 at 12:55 PM
    PapaSmurf20
    PapaSmurf20 New Member
    Alex
    2020 Cavalry Blue TRD Sport
    Fox 2.5 remote reservoir DSC Icon tubular UCA Morimoto gen 2 amber DRL headlights ESP long box under seat storage Meso Customs Cabin/Dome lights HRS tail lights
    Finally had time to put the Morimoto fog lights on.
    D3Tundra, nhw544, GAknight and 14 others like this.
  30. Feb 21, 2022 at 1:10 PM
    Mobeyk
    Mobeyk New Member
    Oshawa Ontario Canada
    2012 Tundra TRD pro, 2018 SR5
    Vland headlights, LED fogs, Rough country lower bumper LED bar, third light switch to LED, ICL ceramic coating, hood fender
    Got puddle lights installed. Tapped them into the useless little footwell light, so they turn on unlocking and when doors open, fading out with the dome light. Discovered that the dome light fuse is always under power as I had first tabbed into that fuse, so seems the dome lights are switched on the ground end. Easy access from cab to underbody via gromet that sits straight under the white holders of the door jamb panel.
    Can't wait for it to get dark so I can check them out. Don't mind all the salt, has been a rollercoaster of deep freeze and snow recent days.
