HEADLIGHT REVOLUTION 2021 TUNDRA LED HEADLIGHTS
Discussion in 'Lighting' started by 251tundra, Feb 1, 2022.
  1. Feb 1, 2022 at 2:38 PM
    251tundra
    251tundra [OP] New Member
    Jonah
    2017 SR5 Tundra
    295/70/R18(35s) Yokohama Geolandar tires. 18” TRD off road rims. Aftermarket Lumen LED tail lights. All lights on vehicle are LED except headlights. Vivid lightbar strobe ditch light pods (amber/white) and vivid lightbar 31” strobe (amber/white). Westin HDX brushguard wuth winch tray. Smittlybilt 9,500lbs winch. NFab matte black step bars. 6” strip tint on top of windshield, 35% on driver and passenger and rest of back windows are 20%.
    Hey, I purchased these a little over a year ago… nearly $1000. I should not have to be putting up with issues paying that much. The blinker bulb socket is not the same as the factory halogen housing ones, so they gave me a different one that hold a different halogen bulb. My issues is it messes with the system causing a hyper flash when on the parking light/headlight position (only rear hyper flashes, front doesn’t even blink!) when on the “off” setting the front you can’t even tell is blinking vs the regular drl brightness. The rear acts weird almost as if hazards are on, the license plate lights blink and even the interior lights. When I put the regular drl/blinker plug on the harness and a regular sylvanya bulb the issue disappears but it won’t fit in the housing. Someone please tell me I’m not the only one having this issue. Were both the bulbs I was sent bad and don’t work well so the system things they’re out or what?
  2. Feb 21, 2022 at 3:52 AM
    redrum448
    redrum448 New Member
    Which headlights exactly? I dont see what brand you bought.....
  3. Feb 21, 2022 at 6:13 AM
    To start with, I assume you went from halogens to leds? I know for the 18 and newer, you need a harness. Not sure about the 2017.
  4. Feb 21, 2022 at 6:23 AM
    redrum448
    I have the morimotos v2
