Tire size help please
Discussion in 'Wheels & Tires' started by JDVann, Feb 20, 2022.
  1. Feb 20, 2022 at 8:40 AM
    JDVann
    JDVann [OP] New Member
    2016 Tundra
    3" lift
    2016 SR5 4x4. 3" lift 20" rims. Currently running 285/65r20. Can I go any bigger on the tires without further modifications?
  2. Feb 20, 2022 at 9:08 AM
    Seafury
    Seafury Kickin names, and takin ass!
    Agent K
    SC Low Country
    2014 White 1794 "SnowWhite aka the Frost Queen"
    Bilstein 6112/5160, 3 CB front shims, SPC UCA's, CB +3 rear Shackles, total 3/2 lift, Dif drop, CB Carrier bearing drop, Fortin Evo One remote start from Tech12volts PnP, AMP research Powersteps PnP, Vent shades, Tinted windows, Black/Red lined cupholder inserts, Proclip USA dash phone mount with Scosche Magic Mount wireless magnetic phone charger, Stock wheels/tires for now.
    Not really.
    Unless you are ok with modifying your front plastic, BMC, and/or spacers or new wheels with the proper +20 offset.
    I am on 3" lift with 275/65R20 because I also have SPC UCA's and had not enough clearance to the UCA to go wider, so I ended up having to add spacers anyway with these tires just to get a safe gap between tires and UCA.
    SPC UCA top ball area sticks out more than stock UCA but I can get a better alignment with my adjustable SPC UCA.
    Also try searching and reading the tire/wheel section threads.
    This is the general section.
  3. Feb 20, 2022 at 9:16 AM
    thedonn
    thedonn New Member
    what is the offset of your wheel?
  4. Feb 20, 2022 at 9:30 AM
    JDVann
    2016 Tundra
    3" lift
    Offset is -12mm. XD Monsters.
  5. Feb 20, 2022 at 9:36 AM
    thedonn
    thedonn New Member
    i would look at custom offsets.com. they have a huge gallery and you can drill down to tundra 20" etc. thats a lot of poke and i dont want to point you in the wrong direction
  6. Feb 20, 2022 at 2:14 PM
    Seafury
    Agent K
    SC Low Country
    That was important info you should have started with.
    With that much offset your likely to need to cut several things from front wheel well to BMC if you go much bigger tire wise.
    But I have never tried to run that sort of combo so I'm not for sure.
    Again, the wheel/tire section would give you the answers you seek.
  7. Feb 20, 2022 at 2:15 PM
  8. Feb 20, 2022 at 2:15 PM
    Welcome from NY.
