Finally arrived.
Discussion in '3rd Gen Tundras (2022+)' started by hairychestedfrog, Feb 19, 2022.
  1. Feb 19, 2022 at 5:04 PM
    hairychestedfrog
    hairychestedfrog [OP] New Member
    Idaho
    22 Tundra SS Red Plt CM
    621CAB7E-3EDC-4CF7-882F-D2B316F0E657.jpg 6446F84E-8931-48F1-8F3D-73CB7FB4C0B3.jpg DB42C6B2-FA03-4BE5-8F5D-7038CAB689DF.jpg 2DD3F855-4141-4AE4-9970-FCA3809947D0.jpg
    Picked it up Friday after a 30 day delay. So far tint/ wheels, weld 20x9 +20, and tires are cooper rugged trek 275/60/20.
  2. Feb 19, 2022 at 5:06 PM
    Congratulations
    =JSG= and hairychestedfrog[OP] like this.
  3. Feb 19, 2022 at 5:08 PM
    hairychestedfrog
    Idaho
    Came from a 2016 Ram Laramie.
    Fit and finish is good, no complaints, no road noise no obvious problems. Butt dyno says this is as fast or faster than the hemi.
    It's very refined.
    What is absolutely driving me bananas is the infotainment. It's awful, not intuitive whatsoever. Every time I get in the car it's asking for a pin or it can't find the profile and reverts to a guest profile which I have to acknowledge. If carplay is on there's no way to switch to sat. radio from the touch screen you have to work through a 4 or 5 step process on the steering wheel. I'm still playing with it; it's my only complaint but it's truly aggravating.
  4. Feb 19, 2022 at 5:22 PM
    Supertech1
    Supertech1 New Member
    Great looking truck! Red usually doesn’t make my list of top colors, but I’m impressed with this look.
    Did you happen to weigh the wheels or tire/wheel combo?
  5. Feb 19, 2022 at 5:27 PM
    hairychestedfrog
    Idaho
    Thanks. I did weigh it. The new setup is 82lbs and the OEM were 74.
  6. Feb 19, 2022 at 5:33 PM
    stevj
    stevj New Member
    On a clear day, I can see Seattle from my house.
    Current RAM 1500 owner waiting for the new Tundra "hybrid."
    Poor quality pictures, but try this. It may work for you.
  7. Feb 19, 2022 at 5:35 PM
    hairychestedfrog
    Idaho
    Thank you, Steve. I will try that tonight.
    =JSG= likes this.
  8. Feb 19, 2022 at 5:58 PM
    stevj
    stevj New Member
    Also, you can check out this video, where this irritating guy talks about the same issue.
    Skip to just before 4-1/2 minute mark to get past all his ramblings to the meat of the matter.
    https://www.youtube.com/watch?v=CjotEq0DERg
  9. Feb 19, 2022 at 6:34 PM
    Minarets
    Minarets New Member
    Nashville
    2021 TRD PRO
    That may be the best looking one I have seen yet.
  10. Feb 19, 2022 at 6:40 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
  11. Feb 19, 2022 at 6:44 PM
    IsaiahCanada
    IsaiahCanada New Member
    Isaiah
    Calgary, Alberta
    2021 Tundra SR5 Crewmax 4x4
    2.5 inch lift, TRD front and rear sway bars, 33 inch Open Country AT3 305/55R20 and dual TRD exhaust.
    Watch pickup truck plus on YouTube. He had the same issues with the pin and got them resolved. You might be having similar issues.
  12. Feb 19, 2022 at 7:09 PM
    SLVR6
    SLVR6 New Member
    Doesn’t the “mode” button on the steering wheel rotate through the sources?
  13. Feb 19, 2022 at 7:11 PM
    Baldwin
    Baldwin New Member
    It's definitely not as easy as it should be. The other day I actually used the Hey Toyota feature to tell it to tune to XM radio and it worked really well. Felt awkward though.
  14. Feb 19, 2022 at 7:14 PM
    autcash
    autcash New Member
    Signal Mountain, TN
    2022 SR5 4x4 Celestial Silver 2020 SR5 4x4 Cement Grey
    Black Rhino Odessa wheels 295/70/18 Coopers
    I used to not like red. Your truck totally changed my mind. Very nice!
  15. Feb 19, 2022 at 7:50 PM
    hairychestedfrog
    Idaho
    Thanks all. I did what steve posted and everything is working perfectly now. Thanks for the help. It even has the option onscreen now to go to the sat radio. Wow.
    At this point I would be challenged to find something critical about this truck now. I was having some reservations after reading dome of the threads here but not anymore.
    standing by for my wastegate failure now
    and i know this is wanted info: the payload sticker along with another very specific sticker warning my payload is 10lbs less for a reason unknown to me.
    Mattedfred and Malinois38 like this.
  16. Feb 19, 2022 at 7:54 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Congrats, that looks real nice
  17. Feb 19, 2022 at 7:58 PM
    Congratulations! Looks great. Color match that grill surround asap!
    =JSG= likes this.
  18. Feb 19, 2022 at 8:00 PM
    20GR8 Super
    Corey
    PNW Outskirts
    2007 Super White CM Limited
    Nice looking truck! Love the red and black. Where in Idaho? I’ve yet to see one up north.
    hairychestedfrog[OP] likes this.
  19. Feb 19, 2022 at 8:08 PM
    1310 lbs cargo? Not so great. My little Frontier is 1290.....
    Ruggybuggy likes this.
  20. Feb 19, 2022 at 8:10 PM
    hairychestedfrog
    Idaho
    Eagle, but if one more californian moves in I'm headed your way.
  21. Feb 19, 2022 at 8:16 PM
    20GR8 Super
    Corey
    PNW Outskirts
    I grew up in Eagle and my parents are still there. I know exactly what you mean.
  22. Feb 19, 2022 at 8:39 PM
    TRD VO
    TRD VO Fix It Again, Tony
    Louisiana
    2015 Inferno CrewMax TRD Pro
    Looks great on that Red! Congratulations.
  23. Feb 19, 2022 at 8:50 PM
    sportrider
    sportrider New Member
    Stephen
    2017 White Crewmax Limited
    Nice truck! That shade of red looks sweet!
  24. Feb 19, 2022 at 8:52 PM
    hairychestedfrog
    Idaho
    It does but it would require an input on the touch screen and then it wouldn't go to Sirius, it would go to 'radio' and then you had to again Choose the Sat radio. It was ridiculous.... I know 1st world problems.
  25. Feb 19, 2022 at 9:23 PM
    WingedHussar
    WingedHussar New Member
    Midwest
    2015 4Runner Limited
    This is one nice looking truck, congratulations !
    How loud are your tires ? I've seen some reviews where people say they're loud and others where people say they're quiet.
  26. Feb 19, 2022 at 9:31 PM
    mountaingroan
    mountaingroan New Member
    Frank
    North Idaho
    2020 SR5 DC VooDoo 4WD Bench!
    Beauty! Congrats, looks like she was worth the wait.
  27. Feb 19, 2022 at 10:36 PM
    hairychestedfrog
    Idaho
    A little louder than stock but not at all bothersome. Ride is much nicer than the OEM; absorb bumps, etc. They're the standard load tire, not the Erated 10 ply. I'm very happy with them so far.
  28. Feb 20, 2022 at 2:41 AM
    1eyedclyde
    1eyedclyde New Member
    Clyde
    NewCastle CO
    21 SC Pearl Platinum
    CLEAN looking!
  29. Feb 20, 2022 at 5:07 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Congrats! Nice looking truck!
  30. Feb 20, 2022 at 5:22 AM
    Retired...finally
    Same here. Talking to inanimate objects makes me think of one of the signs of insanity. That and addressing someone or something starting with "HEY" isn't the way this old boy was raised.
