LED Headlight Help
Discussion in '1st Gen Tundras (2000-2006)' started by 1stgenkid, Feb 2, 2022.
  1. Feb 2, 2022 at 11:18 PM
    1stgenkid
    1stgenkid [OP] Just a kid ballin on a budget
    Abilene, Texas
    2002 SR5 Tundra
    Weather Guard Toolbox Cooper ALT Tires 10’ Kicker CompRT Sub with custom Box
    Howdy Y’all, I just have a question because I absolutely know nothing about LED headlights but I know I want to switch over to them. Do I need a new headlight housing? what bulbs do I use? What about fog lights? All that jazz if someone could help that would be awesome.
    2002 Forest Green
    SR5 Tundra
  2. Feb 2, 2022 at 11:35 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    What's your reasoning for upgrading? Feel you don't have enough light output or just keeping up with the cool kids?
  3. Feb 2, 2022 at 11:39 PM
    1stgenkid
    Abilene, Texas
    2002 SR5 Tundra
    So I replaced the headlights due to the build up and sun damage and the bulbs that came with it just don’t do justice so I’ve been thinking about switching over just don’t have enough info to do so
  4. Feb 2, 2022 at 11:47 PM
    NickB_01TRD
    KY
    Aftermarket headlight housings are just not great. They scatter light everywhere. Sometimes it's better to sand and re clearcoat the factory ones so they won't fade as badly. That's what I did with mine following the chris fix method.
    https://youtu.be/UEJbKLZ7RmM
    I'm not big on LED headlights myself. I just recently did the headlight harness upgrade which uses thicker gauge wire and relays to allow your headlights to get a higher voltage. It also allows you to run higher watt halogen bulbs. You can swap out your fog lights for brighter bulbs too (same wattage but more science to make them brighter).
    Or if you just want a bunch of light with your hi beams try a light bar bumper.
    Here's a link to my thread about my install.
    https://www.tundras.com/threads/bumper-cutout-light-bar-install-early-1st-gen.100198/
    If you search around with it set to only look for 1st gen threads you may find some good info if you're dead-set on LED.
  5. Feb 3, 2022 at 12:46 AM
    KK6PD
    KK6PD 2 1 yr. retired . . . after 42 yrs
    ROAD
    Upper Los Angeles Foothills
    2003 AC Tundra . . . . 7th owner
    New Tires, Stereo & Speakers,Uni-Strut Tie Down Continue watching THIS SPACE FOR FUTURE DEVELOPMENTS
  6. Feb 3, 2022 at 7:49 AM
    The big beef I have with these is inevitable failure/lack of reparability. One other member was saying on here if they ever die, you're sending it back in for service, what do you do in the meantime, just drive around with one headlight? (ugh, I hate Jakob Dylan)
    I genuinely thought about going that option and ended up getting a brand new pair of OEM for about 25% less.
    @1stgenkid it sounds like LED won't do you a bit of good if you've got hazy housings. You either need to do as Nick said to polish and re-clear your housings (3M's kit and Cerakote's kit are both super easy) or replace your housings. Just know, if you go LED headlights, there are at least two other side effects you are likely to find, one is hyperflash (super fast turn signal flash), and potential loss of usage of your fog lights.
  7. Feb 3, 2022 at 8:02 AM
    WXman
    WXman New Member
    Kentucky
    2016 Tundra SR5 Crew Max 4x4 5.7L
    Headlight Revolution has a great website and YouTube channel also. They can hook you up with quality stuff. I'm not affiliated with them in any way, but through experience I can attest that they sell only top notch quality stuff that is in a totally different league from eBay/Amazon lighting.
  8. Feb 3, 2022 at 1:33 PM
    Grumpy74
    Grumpy74 New Member
    2005 White Tundra SR5
    I bought some cheap headlight housings on eBay and they're....meh. I also bought some LED headlight bulbs and I've been pretty satisfied with them. I can certainly see better at night now over the old setup...
  9. Feb 3, 2022 at 1:44 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    I gave up on the whole headlight upgrade for my 2006.
    I ended up just wet sanding and using 2K Clear and they are better than new, and it helped a ton.
    As far as modifying the housings, bulbs, resistors, harnesses, LED, projectors, buckets, looms, relays, adjustments, etc. etc. etc. . . . might as well be speaking Chinese to me.
    So I through up the surrender flag.
    If I need more light down the road, I'll just 'add' some lights rather than trying to decipher and chase the lighting-voodoo.
    I'm over it.
    shifty` likes this.
  10. Feb 3, 2022 at 1:51 PM
    Mobeyk
    Mobeyk New Member
    Oshawa Ontario Canada
    2012 Tundra TRD pro, 2018 SR5
    Vland headlights, LED fogs, Rough country lower bumper LED bar, third light switch to LED, ICL ceramic coating, hood fender
    I polished the haze off on my 2012 and put LED's in. The output is brighter but the light is not as focused. Depending on what your main aim is. Im would not be so worried about Led light kit failing that quickly as they usually keep long time. For sure they lasted longer then the darn halogens.
  11. Feb 18, 2022 at 11:19 PM
    niteman
    niteman New Member
    Greg
    2006 Tundra SR5 D/C
    2018 Tacoma Limited wheels, Rear below converter dual exhaust and K/N filter
    I used Beam Tech on my 06 dc around $40. dollars, u will probably need the resistors, but if you write beam tech through Amazon they will send you a pair of plug and play. Just make sure to mount them on metal near the headlight because they get hot. Changed everything in my truck to led. if you change the turn signals you will need the flasher for use with led. Bought mine from Advance auto parts for $12.00
