2021 with headliner issues
Discussion in '2.5 Gen Tundras (2014-2021)' started by 1015K9, Feb 18, 2022.
  1. Feb 18, 2022 at 7:37 AM
    1015K9
    1015K9 [OP] Austin
    Temecula, California
    2013 Rock Warrior
    Anyone else have this issue with their headliner? (See picture)
    It's a 2021 TRD PRO with less than 8k miles.. getting entire headliner replaced now under warranty. 281D08F7-7F30-4390-B27A-4E53C0FBC5BA.jpg
  2. Feb 18, 2022 at 7:40 AM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    Looks like it was poorly cut for the upper console.
    no, I haven’t seen this. Did that become visible after purchase or was it always like that and you missed it?
  3. Feb 18, 2022 at 7:43 AM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Bak Revolver, BedRug, Undercover Swingcase, PopLock, Bilstein 5160(rear), Firestone RideRite, TRD rear sway bar, Coachbuilder +2 rear shackles, Andersen 5” aluminum adjustable hitch, TRD dual exhaust, VLEDS interior leds including the footwell kit, TundraTex FRAC mod, VLEDS LPR backup tag mount led, Husky X-Act mats, Color matched cup holder bezel (silver), Ceramic 20% tint all around, 50% Ceramic windshield, Color Matched door handles & mirror caps, The “Stubby” antenna, AMP Research steps, VLEDS 6”step lights, ToyTec/5100 Bilstein coil overs, 700lbs red ToyTec springs (2.75” lift), 20x9 +18 Method 306 custom painted and custom fit center caps, Gorilla spline lugs, Bridgestone Revo 3s 285/60R20, TRD skid plate, RaptorLiner “Red” tow hooks, 19 Pro black LED headlights, VLEDS Triton V6 turns, Rigid SAE D series fog lamps, 19 TRD hood scoop, 2019 TRD Pro grille, Coachbuilder bumper shims, X-Pel protect under mud guards, Opti Coat Ceramic, Opti Coat Sealed. And some snakes and sparklers, because they are my favorite!
    My 18 is like this, not quite that bad but still. I don’t think the headliner needs to be replaced but rather moved forward a bit. They have some movement and I think an adjustment will fix my issue.
    NikNoid likes this.
  4. Feb 18, 2022 at 7:48 AM
    Njmike13
    Njmike13 New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    Same problem not as bad 2021 Pro.
  5. Feb 18, 2022 at 7:55 AM
    1015K9
    1015K9 [OP] Austin
    2013 Rock Warrior
    I think it may have always been like this but I missed it. The service advisor said they've had same issues with the land cruiser but not as commonly with the tundra. They went ahead and ordered an entirely new headliner and they're replacing the whole thing.
  6. Feb 18, 2022 at 8:26 AM
    Rocko9999
    Rocko9999 New Member
    You may be able to loosen the console and move it to the rear enough to cover the seam.
  7. Feb 18, 2022 at 8:40 AM
    1015K9
    1015K9 [OP] Austin
    2013 Rock Warrior
    Too late. Haha. Toyota probably has the headliner removed already.
    Rocko9999[QUOTED] likes this.
  8. Feb 18, 2022 at 8:46 AM
    Njmike13
    Njmike13 New Member
    2021 PRO Lunar Rock
    This is what I was going to attempt before going to the dealer.
  9. Feb 18, 2022 at 8:48 AM
    LR23
    LR23 New Member
    NC
    2021 TRD Pro
    2021 Pro here too. Now I'm going to have to go outside and check.
  10. Feb 20, 2022 at 2:50 AM
    1eyedclyde
    1eyedclyde New Member
    Clyde
    NewCastle CO
    21 SC Pearl Platinum
    21 here and mine was the same, just took it out and put it back and it covered it better than from factory. Seemed like it just wasn't lined up
  11. Feb 20, 2022 at 4:32 AM
    Njmike13
    Njmike13 New Member
    2021 PRO Lunar Rock
    You adjusted the overhead console to fix it?
  12. Feb 20, 2022 at 5:34 AM
    1eyedclyde
    Clyde
    NewCastle CO
    correct, I took it down and just repositioned it and it pushed the headliner up towards the roof the 1/8" it was off. Take it down and put it back up in place and see if that works. That's all I did
    bulldog93 and Njmike13 like this.
  13. Feb 21, 2022 at 10:57 PM
    1015K9
    1015K9 [OP] Austin
    2013 Rock Warrior
    Wish I would have tried to self adjust. The new headliner they put in look way worse in the back now.. but the rear window. And my passenger side seatbelt isn't retracting as it should.
    needless to say, they're ordering another new headliner and going to try this again.
  14. Feb 22, 2022 at 4:27 AM
    Njmike13
    Njmike13 New Member
    2021 PRO Lunar Rock
    That sucks. That is my concern with taking it to the dealer. I don't have a lot of faith in my dealer.
    AZBoatHauler likes this.
  15. Jun 27, 2022 at 10:12 PM
    Vincecas13m
    Vincecas13m New Member
    I have a 2021 Tundra TRD Pro and my headliner is coming unglued at the rear window and is just sagging there. Took it to local dealer which had to determine it wasn’t my fault it was coming down?! It’s been three months and I’m still waiting for the replacement OEM headliner. They are telling me the usual supply chain issues. Meanwhile, the headliner keeps coming down
  16. Jun 28, 2022 at 7:41 AM
    Sciosh98
    Sciosh98 ¯\_(ツ)_/¯
    Stephen
    Tennessee
    2020 Black Tundra 1794 TRD
    My 2020 has a fracture from the factory where the headliner meets the windshield right behind my sun visor. Dealer said they’d replace it under warranty, I’m concerned that they’ll just make it worse, so I’m sitting on the fence like an idiot.
  17. Jun 28, 2022 at 12:54 PM
    rocsteady
    rocsteady New Member
    Dave
    New Jersey
    2021 Super White SR7 Double Cab SX
    Mine, 2021 SR5, doesn't connect or tuck into anything at the rear glass. Just sort of comes to an end, looks a little unfinished. But it seems secure, doesn't sag that I notice.
    kz6O5Ygwe4OVhB3g8LU_fZqfERIlYcyv7Rt2uFXx_81e3cff01107dadd92f99d445082e260f2abc282.jpg
    Tundrastruck91 and Vincecas13m like this.
  18. Jun 28, 2022 at 12:59 PM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    When I put in my Meso map lights I had to take that whole upper console off and when I put it back on it looked like that. So I loosened it up a bit and the key is to use a piece of paper and push it under the edge to keep the fabric tucked and then when you have pressure on the upper console slide the paper out and it somehow keeps it tucked. Then keep pressure with one hand and tighten with the other and viola....unsightly seam gone.
  19. Jun 28, 2022 at 1:01 PM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    This is what makes me fearful of putting on my LED third brake light. It's been sitting in my garage for months. You have to pop the rear seat belt panels and then lower the headliner a bit. I'm afraid it's going to make this seam look so much worse. I've read some people have no problem with it going back the same way and others not so much...
  20. Jun 28, 2022 at 1:04 PM
    rocsteady
    Dave
    New Jersey
    Yeah, I'm not sure what keeps it up; seems the cloth part is stuck to a more rigid "frame" underneath but that underneath, maybe molded part, doesn't seem to be secured to anything along the entirety of the back glass.
  21. Jun 28, 2022 at 1:12 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    I would be taking that in for a fix or replacement. That is not how it is supposed to be.
  22. Jun 28, 2022 at 2:26 PM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    There's some type of plastic underneath and there are four plastic pins that are glued to the liner that push into the frame. Those are what you pop out to get to the bolts for the 3rd brake light.
  23. Jun 28, 2022 at 3:45 PM
    theyellowbear
    theyellowbear New Member
    2021 Tundra SX
    Just bought it…
    First time replying or anything else.
    Hello... 2021 SR5 with the same issue where the headliner meets the windshield pillars.
  24. Jun 28, 2022 at 11:04 PM
    Vincecas13m
    I’m also having issues with my windshield. It’s been replaced already but the replacement windshield had the same distortion on the whole right side as the original. Now waiting on third windshield replacement and new headliner. Also had door edgings all come off that had to be replaced too. I wonder if they rushed assembled the last year of the V8 truck ? Just seems the Toyota attention to detail is kinda lacking with my new truck
  25. Jun 29, 2022 at 6:42 AM
    rocsteady
    Dave
    New Jersey
    Anyone have a picture of what it's supposed to look like where the headliner meets the back glass?
  26. Dec 9, 2022 at 8:44 PM
    Kentucky22
    Kentucky22 New Member
    21 Tundra Limited 4x4
    Same issue with my 21 limited
    Took mine to dealer. They ordered another it was worse. Put old one back in. New one one came in it failed badly. At dealer again they tried again failed again they’re putting in the 2nd failed POS until they can get another headliner.
    This headliner issue has been a train wreck. From hell. Needless to say this will be my last toyota purchase. I never took pictures of the original headliner. Mine looked just like the original post.
  27. Dec 9, 2022 at 9:20 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Looks normal. Asked about that on a 2014 Tundra back in 2013, as I thought it was a design error for the refresh ... turns out they are all like that.
    Still seems a bit unfished to me, but nobody ever did notice it (besides me)
  28. Dec 10, 2022 at 2:34 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    There’s I think 4 push clips that hold the headliner to the roof by the rear glass. These should pop in place and hold it up. The end of the headliner is essentially unfinished and curves up into the corner there. The headliner has some level of movement and adjustment.
  29. Sep 29, 2023 at 4:57 PM
    Spoon AZ
    Spoon AZ New Member
    2020 Tundra Ltd
    Our headliner has pulled away from the windshield on both the driver and passenger sides. 2020. Warranty has expired and the dealership is quoting up to $3k to repair. Extremely frustrating.
  30. Sep 30, 2023 at 1:05 PM
    Dukhnt
    Dukhnt New Member
    A locally owned upholstery shop who has been in business a long time with good reviews is who you need to find. They will fix you up!
    Tundrastruck91 likes this.
