SS3 fitment
Discussion in '2.5 Gen Tundras (2014-2021)' started by danno266, Feb 18, 2022.
  1. Feb 18, 2022 at 7:25 AM
    danno266
    danno266 [OP] n00b
    2016 White CM SR5/TRD OR
    Mounting up the SS3s in the bumper pod, but finding a gap all around the bracket and pod. Is this normal or do I have the wrong bracket?
  2. Feb 18, 2022 at 7:28 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Normal, mine have a slight gap. I've noticed the factory mounting layout leaves a bit to be desired. On the plus side the light performance is amazing.
    danno266[OP] and Juanjoolio007 like this.
  3. Feb 18, 2022 at 7:38 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    A small gap all the way around is normal. It is to allow for adjustability up/down. One other thing you can do to tighten that gap a bit would be to loosen the side screws and push the light forward in the bracket a bit. However, it will limit your ability to aim the lights down. So there's a delicate dance there.
  4. Feb 18, 2022 at 8:36 AM
    danno266
    danno266 [OP] n00b
    I will try this, it's likely that I previously adjusted them in the exact opposite direction.
  5. Feb 18, 2022 at 2:19 PM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    I went off the diode instructions and aiming them down a little. A little gap at the bottom but man what a difference between the Pro Rigid that come in the Pro.
    memario1214 likes this.
  6. Feb 18, 2022 at 5:41 PM
    danno266
    danno266 [OP] n00b
    Spot on advice right there! Now I’m happier with the fitment. I appreciate the tip!
    memario1214[QUOTED] likes this.
  7. Feb 18, 2022 at 5:54 PM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Glad that worked for you. I also recommend using zip ties to more securely hold it to the bumper, made mine more flush as well
    danno266[OP] likes this.
