How to fix / what to do
Discussion in '2.5 Gen Tundras (2014-2021)' started by Spielightdude, Feb 18, 2022.
  1. Feb 18, 2022 at 2:14 AM
    Spielightdude
    Spielightdude [OP] New Member
    Joseph
    2019 Tundra TRD off road and towing package
    I have 2 photos attached 1 is of the interior panel down by the left driverside lock panel.
    The top of the panel keeps popping put and I have had it at the dealership and they flipped the clips that hold it in place but it keeps.popping lose.
    I'm concerned for.water and debris getting behind it as its by thr door and there's a bunch of electrical behind it including circuit boards.
    How.can I fix this so it doesn't keep popping lose?
    The other is the driverside door on the outside top right corner the rubber seal is peeling.
    What would / should I do to fix this?
    Thanks everyone
  2. Feb 18, 2022 at 3:19 AM
    pursuit2550
    pursuit2550 New Member
    The kick panel has a clip that comes off and stays on the truck. You have to take it off and put it back on the panel. It’s a tricky panel but it’s do able. Your other issue, can’t comment. Never had that happen.
  3. Feb 18, 2022 at 3:49 AM
    Fourknights
    Fourknights Goin Coastal
    Georgia/Florida
    2019 sr double cab 4x4 5.7
    Coverking ballistic seat covers, dipped 4x4 emblem, intermittent wiper mod, Toyota bed mat, Toyota rear under seat storage, dirty deeds budget, icon rebound 17”, bfg ko2s 285/70/17, matte black uws low profile toolbox, grill surround painted matte black
    Could try 3M black weather strip adhesive on other issue.
    patterson.walter and omgboost like this.
  4. Feb 18, 2022 at 3:55 AM
    1eyedclyde
    1eyedclyde New Member
    Clyde
    NewCastle CO
    21 SC Pearl Platinum
    for sure 3m tape on the weather strip. I had to redo mine when I took it off for the clearbra. easy fix
    omgboost likes this.
  5. Feb 18, 2022 at 5:36 AM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    Remove and replace the little pice of gray tape. Carefully with a razor. Will be easier if you drop the window and pull more of the run channel free. Replace with 3M tape. Use an adhesion promoter wipe on the rubber and the paint side. On the kick panel the clips will lose their holding power with repeated removal and installation. That’s assuming they’re all even installed correctly. Easily dislodged. Might be best to put new clips in. A good body shop will be able to help with both. Skip the dealer.
  6. Feb 18, 2022 at 5:40 AM
    timsp8
    NY
    Mines been like that for years. I hate that clip.
    ljburns likes this.
