LED bed lighting, where did you get your 12v?
Discussion in 'Lighting' started by H22dx, Feb 16, 2022.
  1. Feb 16, 2022 at 3:03 PM
    H22dx
    H22dx [OP] New Member
    Trevor
    '18 Limited TRD Off Road
    I was wondering where you all got your hot from while installing. Tail light, wire from battery, etc? Looking for the best way to do it. Thanks!
  2. Feb 16, 2022 at 3:22 PM
    If you don't want to run a wire from. The battery or fuse box you can tap into the back of the trailer plug.
    #1 & #4
    H22dx[OP] likes this.
  3. Feb 16, 2022 at 3:27 PM
    H22dx
    Trevor
    I saw this earlier when I was looking. I looked at my wiring and I have two red wires. One is solid red and I think the other was red and black? I don't want to tap into the wrong one. The wires are pretty tight so it doesn't give you too much wire to use.
  4. Feb 16, 2022 at 3:30 PM
    Use posi-taps, just use that diagram and tap those 2 spots. All trailer plugs are the same.
    H22dx[QUOTED][OP] likes this.
  5. Feb 16, 2022 at 3:31 PM
  6. Feb 16, 2022 at 3:35 PM
    Willard
    Willard New Member
    2024 F250
    Battery so you can use the bed lights while the truck is turned off.
  7. Feb 16, 2022 at 3:47 PM
    biebs96
    PA
    Mine are wired to the cargo lamp switch. My bed lights work in whatever position the switch is in. On / Door / Off
  8. Feb 16, 2022 at 4:18 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Bak Revolver, BedRug, Undercover Swingcase, PopLock, Bilstein 5160(rear), Firestone RideRite, TRD rear sway bar, Coachbuilder +2 rear shackles, Andersen 5” aluminum adjustable hitch, TRD dual exhaust, VLEDS interior leds including the footwell kit, TundraTex FRAC mod, VLEDS LPR backup tag mount led, Husky X-Act mats, Color matched cup holder bezel (silver), Ceramic 20% tint all around, 50% Ceramic windshield, Color Matched door handles & mirror caps, The “Stubby” antenna, AMP Research steps, VLEDS 6”step lights, ToyTec/5100 Bilstein coil overs, 700lbs red ToyTec springs (2.75” lift), 20x9 +18 Method 306 custom painted and custom fit center caps, Gorilla spline lugs, Bridgestone Revo 3s 285/60R20, TRD skid plate, RaptorLiner “Red” tow hooks, 19 Pro black LED headlights, VLEDS Triton V6 turns, Rigid SAE D series fog lamps, 19 TRD hood scoop, 2019 TRD Pro grille, Coachbuilder bumper shims, X-Pel protect under mud guards, Opti Coat Ceramic, Opti Coat Sealed. And some snakes and sparklers, because they are my favorite!
    I came from the battery also, I wanted use of my lights at any time. Pretty sure the trailer plug goes dead with the key off.
  9. Feb 16, 2022 at 4:59 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    I now have a house battery and a bunch of other stuff. But I initially grabbed them from the middle of the harness on the frame going to the trailer tow connector. The harness is accessible where the cab meets the bed. I have the trailer charge relay jumped so I can plug a battery maintainer into the 7-pin when stored for a while, so this wire is now constant hot for me.
  10. Feb 16, 2022 at 5:07 PM
    H22dx
    Trevor
  11. Feb 16, 2022 at 5:09 PM
    :thumbsup:
