BSM switch, Non-BSM Mirrors
Discussion in '2.5 Gen Tundras (2014-2021)' started by vokeydawg, Feb 16, 2022.
  1. Feb 16, 2022 at 12:30 PM
    vokeydawg
    vokeydawg [OP] New Member
    I recently bought a 2017 Tundra 1794 from a dealership. Apparently I failed to try out the BSM switch before the purchase because when I push it, I get BSM Error contact dealer message. Upon further inspection, the mirrors I have on both driver and passenger sides are not equipped with the BSM indicator lights.
    I guess my question is, is it possible that the vehicle (from factory) has a BSM switch but no BSM functionality? Or did the prior owner (clean CARFAX, btw) wreck/damage them and replace with non-BSM mirrors?
    First post on this site. I've enjoyed reading so far.
    Thanks in advance.
    reywcms likes this.
  2. Feb 16, 2022 at 12:56 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Sounds like someone replaced them with the wrong units.
  3. Feb 16, 2022 at 3:22 PM
    Tumbler
    Tumbler New Member
    2023 CrewMax Limited HV in MGM
    Are they standard mirrors or towing mirrors?
    and no, it would not have come from the factory like that
  4. Feb 16, 2022 at 3:46 PM
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    I agree with this comment. You could find a set of heated OEM mirrors with BSM under $200. I recently put out a WTB post and found one for just my passenger side at a great price.
  5. Feb 16, 2022 at 3:50 PM
    biebs96
    PA
    Are the towing mirrors?
    you can install LEDs in place of the mirror indicators. This creates the proper resistance for the system to work properly.
    Taco-Spike and Njmike13 like this.
  6. Feb 17, 2022 at 7:18 AM
    vokeydawg
    Standard mirrors.
    That's what I figured.
  7. Feb 17, 2022 at 7:22 AM
    vokeydawg
    Thanks! I will give those a look.
    I wonder if having the wrong mirror glass is what is causing the BSM warning light to come on. All of the parking sensors seem to work...I assume the BSM uses those to check for cars in blind spot.
    831Tun likes this.
  8. Feb 17, 2022 at 7:23 AM
    vokeydawg
    I'll look into this. This may be a cheaper solution that replacing the mirror glass.
    Thanks!
    biebs96[QUOTED] likes this.
  9. Feb 17, 2022 at 7:47 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I don't think BSM uses parking sensors. I believe there's something like a transducer in each rear bumper corner.
    g6t9ed likes this.
  10. Feb 26, 2022 at 1:37 PM
    vokeydawg
    O
    I’ve searched the site fo a straightforward way to do this but can’t seem to find one. I’ve bought the recommended lights but I’m unsure which pins(I think 9 and 14) and how to actually make the connections. Maybe wire taps on the wires going into the connector? Any tips?
  11. Feb 26, 2022 at 1:45 PM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    If it’s a 1794, the mirrors should power fold. Do they power fold? If not, I’d just bite the bullet and get the correct mirrors. Heat, bsm, puddle lights, power fold.
  12. Feb 26, 2022 at 1:52 PM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Also, before you go buying anything. Does it have an aftermarket rear bumper? If so, you’re going to need a whole lot more to get BSM working. If it doesn’t, I would crawl under the rear bumper and make sure the BSM modules are there on both sides. If they are, then you can proceed with either adding in the diode or replacing with new mirrors. Good luck!
  13. Feb 26, 2022 at 2:03 PM
    vokeydawg
    Stock bumper. The modules are there. The mirrors do fold, have heat, turn signals…just no bsm lights.
    Thanks for your replies.
    Mater[QUOTED] likes this.
  14. Feb 26, 2022 at 2:53 PM
    biebs96
    PA
    I left the pin connectors on. Striped the wires of the LEDs a little longer and wrapped them around the pin itself. Some shrink wrap and it’s been good since.
  15. Feb 26, 2022 at 3:10 PM
    vokeydawg
    So you pulled the pins out of the harness? Pretty easy to do?
  16. Feb 26, 2022 at 3:34 PM
    biebs96
    PA
    yes. Small safety pin or screwdriver. Easily removable
  17. Feb 26, 2022 at 3:40 PM
    vokeydawg
    Awesome. Thanks!
  18. Feb 26, 2022 at 4:46 PM
    biebs96
    PA
    let us know how it goes
  19. Mar 1, 2022 at 4:16 PM
    vokeydawg
    Well, I got in there to the connector and just wasn’t sure enough on which pins to remove and use. Pics I’ve seen of other peoples connectors have about half of the holes empty. Mine has every hole filled and wire colors in positions I don’t recognize from the pics.
    I can’t seem to find a pin out diagram.
  20. Mar 1, 2022 at 5:47 PM
    biebs96
    PA
    i will pull my panel tomorrow and photograph the wires I used.
  21. Mar 1, 2022 at 6:46 PM
    vokeydawg
    That would be great! Thanks so much!
  22. Apr 26, 2024 at 12:57 PM
    Drubikscube
    Drubikscube New Member
    2015 White 1794
    Did you ever move forward with the project? I crunched my passenger side mirror the other day and found that the proper replacement mirrors are now $500 . Would love to go this route if it’s pretty straightforward and successful
  23. Apr 26, 2024 at 4:47 PM
    vokeydawg
    I didn’t. I ended up buying two new mirrors. Sorry… got psyched out.
