Tow mirror issue
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mat1018, Feb 1, 2022.
  1. Feb 1, 2022 at 4:01 PM
    Mat1018
    Mat1018 [OP] New Member
    Mat
    2016 Super White platinum CM 4x4
    4" lift, spyder headlights and tail lights, LT headers. Carven exhaust, and XD series monsters II wheels.
    So picked up some tow mirrors they appear to be trail ridge brand with BSM. So everything works but the bsm I don't have any dash warning and it acts like it's working but the light on the mirror doesn't come on. So here's the crazy thing, the outside parking light on the mirror is acting like the bsm light. It turns on when someone is next to me and flashes when I turn on my signal, but can't see it from the drivers seat. My wife saw it driving next to me and took a video to show me. So could it have been wired incorrectly and could I open it up and fix it myself? I contacted trail ridge about it but didn't buy them new so probably won't help me out but shall see.
  2. Feb 15, 2022 at 4:37 PM
    Everything G3 n Yota
    Everything G3 n Yota New Member
    Kevin
    2015 super white tundra ltd double cab
    Firestone air bags. DS grab handle. Toyo 10 ply tires
    Hello Matt. I just got the trail ridge two mirrors today. My BSM lights (in the corner of the mirror) come on when ever the the parking lights or headlights are on. And Im getting an error on my dash to contact dealer regarding BSM. I will research the correct pins And let you know what i find. I also need to figure out the power fold option. I bought an oem Toyota switch with he power fold button. But it doesn't work either. Not a lot to figure out, but very time consuming.
  3. Feb 15, 2022 at 4:43 PM
    Mat1018
    Mat
    I was able to fix it just had to swap around 2 pins to get it to work. Mine are the non power folding type.
  4. Feb 15, 2022 at 5:15 PM
    Kevin
    Mine are pobly different then, mine are power fold heated,BSM, puddle lights, marker lights, spotlights. how did you "unpin" them. They are sooo small. Thanks again mat.
  5. Feb 15, 2022 at 5:44 PM
    Mat1018
    Mat
    Yeah mine are just the turn signal, side markers, heated and BSM ones.
    So have to release the Retaining bar then I used a safety pin, Push it in the upper small square/rectangle slot. It goes in relatively far then you can pull the wire out easily.
  6. Feb 15, 2022 at 8:18 PM
    Kevin
    Thanks a million mat. I will give it a shot tomorrow night after work. Hopefully I can figure out the wires. Many are pinned wrong from what I've seen.
  7. Feb 15, 2022 at 9:38 PM
    Mat1018
    Mat
    I know for BSM light pins it's swap 9 and 18. I have the oem wire diagram for the BSM system if you need it
  8. Feb 16, 2022 at 3:56 AM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    Any chance you can post the pic of diagram? How do you like the mirrors otherwise? Any shake?
  9. Feb 16, 2022 at 7:49 AM
    Mat1018
    Mat
    I would prefer the stock mirrors but the tow ones came with the truck. They do have alittle shake to them but not to bad.
  10. Feb 16, 2022 at 5:48 PM
    Kevin
    Got my BSM working by swapping pin 9 and 18 on each mirror. Thanks Mat. Also figured out the power fold , side marker and puddle light pins. Just have to run wires now. The upper mirrors do have a little shake as Mat said. The lowers do not. I believe the glass is shaking in the frame. I don't think it's he entire mirror. Will have to experiment once completed.
    I have my oem regular mirrors for cheap $ if anyone is interested. Power, heated, BSM. Chrome. thanks all
  11. Jun 29, 2023 at 11:32 PM
    Rsolano87
    Rsolano87 New Member
    Randolph
    2024 tundra trd off road
    Westcott design pre load collar lift
    maybe silly question, but are you swapping the pins in the trucks mirror harness or in the new tow mirrors harness you’re going to install?
  12. Jun 30, 2023 at 7:54 AM
    Mat1018
    Mat
    You can do either one. It's been a while ago since I did it so I can't exactly remember if I did the mirror side or truck side, i want to say i did the truck side. Either way it's the same process.
  13. Jun 30, 2023 at 7:57 AM
    Rsolano87
    Randolph
    awesome thanks
  14. Jun 30, 2023 at 8:51 AM
    RobertD
    Robert
    DFW, Texas
    @Rsolano87 make things easier on your future self and leave the truck harness alone incase you change mirrors again.
  15. Jun 30, 2023 at 9:01 AM
    Rsolano87
    Randolph
    yeshbthats what I was thinking. Thanks!
    RobertD[QUOTED] likes this.
