Grinding noise in wheel
Discussion in '2nd Gen Tundras (2007-2013)' started by Cg13055, Feb 14, 2022.
  1. Feb 14, 2022 at 6:57 AM
    Cg13055
    Cg13055 [OP] @yota.parts.distributor
    South Florida
    Mcfly Tundra @yota.parts.distributor
    2012’4.0 Tundra-2004’4.7 crewcab-2021 2.7 Tacoma
    Need some help diagnosing a noise I've had for a few months. At speed it sounds like a metallic chirp, we know it’s coming from the front right wheel on my 2012 Tundra. 2WD so to me it can only be the backing plate, brake components, or a bearing. When going slow it sounds like something is catching and rubbing but when you speed up it’s a chirp since the wheel is rotating at a faster speed. The noise is killing me, I have to time with the YouTube video so I am just about to run to a dealership and have them brake it down to find the noise. I don’t want to waste money knowing someone on here might know my solution. Thanks again guys
  2. Feb 15, 2022 at 8:17 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    1.) Jack up front right wheel off ground and secure with jack stands or other safety devices
    2.) spin wheel listen for noise / grab a hold of the wheel and shift it side to side in/out ward checking for bearing play
    3.) take wheel off
    4.) inspect brake pad to make sure they are not low and the squeal tab/low indicator
    5.) inspect back side of backing plate making sure its not bent into the rotor
    6.) spin rotor listen for noise
    7.) unbolt caliper and hang it on it on a caliper hanger or DIY hanger to insure its not hanging by the break line (there while be a few clips or bolts that hold line to the knuckle and the Wheel speed sensor wire recommend a L pick to slide in between the U over clip piece and the retaining triangle this will help when dealing with a stubborn connector as you can focus your hand on the sides to wiggle and pull out if need be with out breaking it, also do unbolt the psychical brake line from the caliper and when dealing with the small bolts that hold the line/wires to knuckle use a 1/4" ratchet very bad day if one of those bolts breaks)
    8.) rotor listen for noise
    9.) remove rotor and inspect for any witness marks or foreign derbies caught in between it and the backing plate I.E small rocks or road trash
    10.) spin hub and listen for noise
    At this point you should find it ;)
    Cg13055[OP] and Landodnal like this.
  3. Feb 16, 2022 at 4:18 AM
    Cg13055
    South Florida
    Thank you! I gotta go buy a new jack before this weekend so I can check this stuff off my list!!
    NueveTundra[QUOTED] likes this.
