Coolant change - do I need to open the drain valves on the side of the engine?
Discussion in '2.5 Gen Tundras (2014-2021)' started by IowaGuy, Feb 6, 2022.
  1. Feb 6, 2022 at 10:00 AM
    IowaGuy
    IowaGuy [OP] New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    I am at 60k miles and am planning to do a complete coolant flush / change as I do not know if it has ever been done.
    Is it necessary to open up the petcock drain valves on the side of the engine? Is there an easier way to do a flush and replace all the coolant? IF I need to open these up and drain that way can it be done without taking the wheels off?
    It was expensive but I ordered this.
    Here is the video where he drains the coolant from the block
    https://www.youtube.com/watch?v=OivwKhMyLxs
  2. Feb 6, 2022 at 10:07 AM
    SpeshulED
    SpeshulED New Member
    Sandy Eggo/Chula Vista, So Cal.
    2015 Mag Gry Ltd. CM TRD Tundra
    TRD Pro Grill | AMP Steps | Husky Floor Mats | SnugTop Sportsman Super Sport Shell | 55w 5k HID Headligts | Method Racing NV Bronze 18x9 | BFG KO2 35x12.5r18
    I would like to know this as well
  3. Feb 6, 2022 at 11:13 AM
    Not IMO. When I bought my truck new, after the 3rd year I decided to perform a coolant change and loosen the brass plugs on the sides of rhe block. Block was cold but they wouldn't budge. Unfortunately in the process I twisted off the top of the plug. Thankfully it never leaked and since then I just drain the radiator and refill twice by driving for a week, about 350 miles, before I repeat so I can dilute the remainder in the block after its mixed. Might not be the best method but it works for me and the dealer tells me they ignore the block plugs because they don't always come free.
    I've been driving my truck for 20 years and change the coolant every 30k miles as recommended.
    WAtundra4x4 and 831mic like this.
  4. Feb 6, 2022 at 12:17 PM
    SpeshulED
    so pretty much just drain the radiator, fill accordingly, start the motor, fill accordingly?
    koditten likes this.
  5. Feb 6, 2022 at 12:31 PM
    IowaGuy
    In Process
    After the trouble I had with the frozen front diff. drain plug I am really hesitant and gun shy to try and loosen a brass engine drain plug. I think I will just drain and fill it a couple times with distilled water before a final fill with new coolant.
    koditten and SpeshulED like this.
  6. Feb 6, 2022 at 12:43 PM
    I usually fill it before and not after I start the motor. Basically I use two 5 gallon buckets and a fill funnel. One for draining and the other bucket for the 50/50 mix which equals what I've drained. Oh, and always open the cap before pulling the plug or it'll get everywhere from glugging out.
  7. Feb 15, 2022 at 7:38 PM
    Tundrapwr16
    Tundrapwr16 Best Toyota made ever
    Rob
    California
    2000 RC 3.4 liter white work truck .
    Pioneer radio and intermittent wiper switch and led lights. I also use AMZOIL Products only..
    I think I’ll try pulling the bottom hose off get all of what’s in the system after the thermostat. Thanks for the advice on brass drain plugs won’t touch em for sure now. My truck just hit 30k I’ll grab 3 gallons of the Toyota 50/50 and fill it up all the way and fill rest accordingly as thermostat opens. Then a month out drain it and do it again. Idk ‍♂️ If there’s a better way I’m all ears guys. Thank you
  8. Feb 15, 2022 at 8:02 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    I did my truck this past summer. I did loosen the brass drains. One of them let a decent bit of coolant out, the other not so much.
    FWIW, I was surprised at how clean my coolant looked. I had 105k on it when I did it. As I recall, 3 gallons should get you there.
  9. Feb 15, 2022 at 8:06 PM
    Tundrapwr16
    Rob
    California
    Thank you that’s helpful ..
  10. Feb 15, 2022 at 8:31 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    How about tapping a coolant line with a t connector with a hose fitting? Clamp the hose on and let the water flush everything out your lower radiator hose.
  11. Feb 15, 2022 at 8:48 PM
    AZBoatHauler
    So.Arizona
    I had no issue using the block drains. Both sides let out a 2-3 quarts of coolant. :notsure:
    Henry1jg and LS3 like this.
  12. Feb 15, 2022 at 8:55 PM
    Ericsopa
    Ericsopa Old man and the sea
    Open the drains on the engine. It's not hard. Don't have to remove the wheels. You'll need a long extension for the socket and maybe a u-joint, I really done remember for sure. But opening those drains in the only way you're going to get all the old coolant out. I refilled with premixed 50/50 coolant.
    JLS in WA and AZBoatHauler like this.
  13. Feb 16, 2022 at 2:34 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Wasn't the 30k recommendation for old school Toyota red coolant. I know new corollas (which use the same pink coolant) call for coolant change after 100k then every 50k after. I understand wanting to keep things clean but every 30k seems like a bit much especially if the truck isn't very old.
  14. Feb 16, 2022 at 3:58 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Warm the engine up completely (or right after you come in from the driving the truck). Drain at the bottom of the radiator. Refill with distilled water. Run engine with heater turned on to hot and the fan turned up. Let circulate for a couple of minutes. Drain from the bottom of the radiator. Refill with your favorite PINK. Turn engine on and monitor your coolant level (don't space out on the overflow tank). Are you super anal? Can do the distilled water sequence a 2nd or 3rd time.
    I really like the OEM Tools No Spill Coolant Funnel Kit for the refilling operation. Works flawlessly. https://www.amazon.com/OEMTOOLS-87009-No-Spill-Coolant-Filling/dp/B01A2CQSU6
  15. Feb 16, 2022 at 4:30 AM
    Fourknights
    Fourknights Goin Coastal
    Georgia/Florida
    2019 sr double cab 4x4 5.7
    Coverking ballistic seat covers, dipped 4x4 emblem, intermittent wiper mod, Toyota bed mat, Toyota rear under seat storage, dirty deeds budget, icon rebound 17”, bfg ko2s 285/70/17, matte black uws low profile toolbox, grill surround painted matte black
    Above method will result in diluted coolant. Drain radiator and engine drains, then refill.
    AZBoatHauler likes this.
  16. Feb 16, 2022 at 6:44 AM
    AZBoatHauler
    So.Arizona
    If you do this, you’ve diluted your new coolant by quite a bit compromising both cooling and freeze protection. Flushing with distilled water is fine, but drain completely from radiator and engine before putting in your new coolant.
    JLS in WA likes this.
  17. Mar 25, 2023 at 3:43 PM
    Andrew_Tress
    Andrew_Tress New Member
    Andrew
    2014 Tundra SR5 5.7l
    If I crack both engine block drain valves and drain the spigot on the radiator, will that drain 100% of the coolant thats in the system? or is there still some hiding in there after
  18. Mar 25, 2023 at 5:32 PM
    Ericsopa
    Maybe not quite 100%, but as much as you're going to get. Some will probably linger in the heater core, but you don't need to fret over what little is left.
    omgboost likes this.
  19. Feb 10, 2025 at 5:24 AM
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    What diameter hose do I need to fit on the drains? Thanks!
  20. Feb 10, 2025 at 6:16 AM
    Ericsopa
    If I recall, 1/4" ID.
  21. Feb 10, 2025 at 8:38 AM
    TundraPHX
    TundraPHX Ryan started the fire.
    Jared
    That’s how me and pops did it on the 64 dart. Many moons ago.
    MadMaxCanon[QUOTED] likes this.
  22. Feb 12, 2025 at 7:57 PM
    lr172
    lr172 New Member
    07 DC
    No. Sadly no one but Toyota really knows exactly how much is left in there. For those of us doing it properly, it doesn’t matter, just like it doesn’t matter if you get every drop of oil out. Not knowing should absolutely scare you from the water flush method mentioned above, especially if you live in a cold climate.
  23. Feb 13, 2025 at 8:02 AM
    CasperTheFriendlyTundra
    CasperTheFriendlyTundra New Member
    I used the drain valve on the radiator and the two on the block. The passenger side drained much more than the drivers side.
  24. Feb 13, 2025 at 9:48 AM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    Does anyone know the size of the hose needed to fit on the block drains?
  25. Feb 13, 2025 at 10:33 AM
    AZBoatHauler
    So.Arizona
    Guessing 3/8 ID but honestly I just opened them and let them pour into a bucket.
    LS3 likes this.
  26. Feb 13, 2025 at 5:24 PM
    MadMaxCanon
    5/16 ID fits rad and block drains
  27. Feb 13, 2025 at 6:47 PM
    Tundra1988
    Tundra1988 New Member
    Cody
    17 Trd Pro White CrewMax
    295/70/18 Tires
    What I did at 100k was disconnect coolant hoses at top and bottom of radiator, heater core, and at transmission cooler underneath the truck and take a ridgid small type blower and blow everything out that did not drain to avoid leaking brass fittings on engine. See picture if it uploaded or something similar. It was a much easier task to me. Hope this helps! I am at 128k and going great no signs of needing water pump yet. I am an outside salesman and drive quite a bit. Trd pro so the skid plate sucks to take off to do this lol.
