Tyco radiators - good bad or ugly?
Discussion in '2.5 Gen Tundras (2014-2021)' started by IowaGuy, Feb 15, 2022.
  1. Feb 15, 2022 at 6:58 AM
    IowaGuy
    IowaGuy [OP] New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    I am going to have to install a new radiator and a Tyco brand from Rock Auto is all I could find in stock. Does anyone have any experience with these or the brand? I really want a Denso so I might have to try and haggle with Sparks but they wanted @ $300 for just the shipping.
  2. Feb 15, 2022 at 8:20 AM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Is yours repairable? I had a small hole in mine and I got it fixed for like 40 bucks. Been holding for 2 years now.
  3. Feb 15, 2022 at 8:22 AM
    IowaGuy
    In Process
    Nope, I broke off the return / overflow nipple and it is one plastic piece at the top. I tried doing a tube insert with some JB weld and it still leaks.
  4. Feb 15, 2022 at 8:23 AM
    IowaGuy
    In Process
    Sparks doesnt even have it in stock and it is like a unicorn to fine the OEM one from Denso.
  5. Feb 15, 2022 at 8:24 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
  6. Feb 15, 2022 at 8:24 AM
    Sumo91
    TN
    You should be able to get a denso from any auto parts place, but I'd go factory simply for the fact that it's gonna be in there 20 years from now. Don't skimp on cooling
  7. Feb 15, 2022 at 9:01 AM
    IowaGuy
    In Process
    I thought the factory is a denso?
    I called my local Toyota parts dept and there are 300 of them backordered and not one available nationwide. I cannot find a Denso in stock anywhere either.
  8. Feb 15, 2022 at 9:20 AM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Have quite a bit of experience with Tyco! Drove the Fast Traxx many times over at a friend's house and always wanted one. It revolutionized RC cars for sure. Never got to drive the Tyco Rebound but heard through the grapevine at Fiske elementary that it was a decent product. Had the Tyco Typhoon hovercraft and while it overall was a good product, it had two shortcomings: 1) the rubber skirt ripped pretty easily and 2) the run time on it was so short because the 3 fans drained the battery so quickly. Solve those two problems and its be a 10/10 for sure.
    ..As for their radiators.. not sure
    Sumo91, AZTundra and e30cabrio like this.
  9. Feb 15, 2022 at 9:39 AM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
  10. Feb 15, 2022 at 9:43 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
