Bump stops 2020 sr5 tundra TSS
Discussion in '2.5 Gen Tundras (2014-2021)' started by Sasquatchlives, Feb 3, 2022.
  1. Feb 3, 2022 at 12:57 PM
    Sasquatchlives
    Sasquatchlives [OP] New Member
    2020 toyota tundra sr5 with tss package
    2020 tundra sr5. TSS.
    20 inch rims.
    Question my bump stops are located on my struts not the frame. Is that normal. ????
    Reason looking to upgrade to a sumo stop. I tow alot
  2. Feb 3, 2022 at 1:20 PM
    TundraMidwesterner
    TundraMidwesterner What?
    Northern Illinois
    2019 Magnetic Gray Metallic CrewMax TSSOR 4x4
    Katzkins, Rostra heated seats(4), Tint (all), TRD rear sway bar, TSS wheels, OEM black lug nuts and wheel locks, OEM LED black fog lights, Driver side grab handle, Rough country LED Bumper bar, Rough Country Hard tri fold tonneau cover, AVS ventshades, Bilstein 5100's on top setting in front, Ready lift 1 inch ready block in the rear with Bilstein 5100's. Fluid Film. ESP under seat storage. LED interior lights and cargo lights swapped. Rear USB charger port swapped for 12v port. Remote start. Leather wrapped steering wheel kit. TRD shift knob. Kenwood dmx1037s. Hertz K170 door speakers/ tweeters, Infinity Reference 7005A 5 channel amp, 2 JBL WS1000 10 inch subs. DDI Seat Jackers. RCI engine Skid and Vahalla's Shields (front and rear) 1/4 aluminum. Stillen intake. LED Pro Headlights with iHacker harness. Cartrimhome auto up and down window switches. Coupe's aluminum battery tie down. Color matched mirror caps. Color matched door handles. Chalk bag cup holder. NFab podium step bars, herculined. Powerstop z36 drilled slotted brake discs w/ceramic pads.
    Not sure what you are referring to. I'm assuming you mean the rear leaf springs? The rear leaf springs have a pyramid looking block above the leaf pack. its attached with the ubolts that go around the rear axle and leaf pack and sits on top.
    this picture is with a 5100 strut and a 1 inch block between the axle and the leaf pack but otherwise yours should look similar:
  3. Feb 3, 2022 at 1:21 PM
    TundraMidwesterner
    Northern Illinois
    the sumo springs would replace the bump stop on the top of the leaf pack
    Sasquatchlives[OP] likes this.
  4. Feb 4, 2022 at 6:11 AM
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
    Here you go!!!
  5. Feb 4, 2022 at 6:14 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    So would some Timbrens...mounted the same as the Sumo springs!
  6. Feb 4, 2022 at 6:20 AM
    Suprafantx
    Suprafantx New Member
    2020 4X4 White Tundra TSS
    TundraMidwesterner,
    From picture of your rear differential, is it leaking?
  7. Feb 4, 2022 at 6:31 AM
    Mobeyk
    Mobeyk New Member
    Oshawa Ontario Canada
    2012 Tundra TRD pro, 2018 SR5
    Vland headlights, LED fogs, Rough country lower bumper LED bar, third light switch to LED, ICL ceramic coating, hood fender
    Can one run sumos and Roadmaster Active Suspension together? I think room wise there is no issues. Sumos do little to nothing for axle wrap.
    2mchfun likes this.
  8. Feb 4, 2022 at 6:33 AM
    TundraMidwesterner
    Northern Illinois
    I'm not sure why it looks like that, its dry though, looks like that all the way around and has since I bought it. Not sure if it is some kind of sealer from the factory?
  9. Feb 4, 2022 at 5:27 PM
    bjp
    bjp Hello, kitty……
    Ben
    White ‘21 Double-cab Tundra SR5 w/TRD off-road
    GoFast Camper, TRD skid plate, Valhalla cat plates, LT265/70r18 Nokian Rotiivas, buncha shit under the seat, you know how it is
    You sure can. I added sumo springs a couple of months ago, got my RAS installed yesterday. The Sumos are so tall, I was almost touching the frame on the driver side, and was only about 1/2” off on the passenger side. I got the HD RAS, set at the higher of the two recommended starting settings (40%?) when installed, and now have about an inch and a half clearance above the sumo springs. Funny to me that, even though I had only maybe a quarter tank of gas when the shop installed the RAS, they managed to set it so that the driver side and passenger side are perfectly even with each other after I filled the tank up.
    I did the sumo springs myself (very quick and easy) and was going to do the RAS myself, but I was afraid I wouldn’t be able to get the shackle out back together - it was still under considerably more load than I expected when I went to take it apart. It only cost me a couple hours labor to have the RAS installed, so I’m not too upset over that. Would rather have the $ in my pocket, but, hey, them’s the breaks.
    Mobeyk[QUOTED] likes this.
  10. Feb 13, 2022 at 7:50 AM
    Sasquatchlives
    Thanks. That was excess after I refilled. Next time I'll clean off better. Good eyes
  11. Feb 13, 2022 at 2:09 PM
    2mchfun
    Mine have been together for nearly a year now.
