Front LED turn signal upgrade for '22s
Discussion in '3rd Gen Tundras (2022+)' started by dekeman, Feb 13, 2022.
  1. Feb 13, 2022 at 9:59 AM
    dekeman
    dekeman [OP] New Member
    Derek
    Ottawa, ON, CANADA
    2022 Tundra Limted TRD
    Unfortunately, 2022 Tundras without the premium headlights use 7443 or 7444 filament bulbs for turn signals. (Weird when just about everything else is LED.)
    On my 2018 Tundra, I used JDMS and was hoping to use same ones on the new truck; easy access via the wheel well, but the JDMs trigger hyperflash.
    I thought 30W and above was needed to avoid hyperflash. Even though the JDMs are advertised as 50W, they throw the error. Could buy a resistor, of course, but would rather find an another amber LED bulb with built-in resistor that will 100 per cent work.
    If anyone has found one and tested, please post.
    Thx!
  2. Jun 12, 2022 at 8:30 AM
    dekeman
    Derek
    Ottawa, ON, CANADA
    Anyone?
  3. Jun 12, 2022 at 9:31 AM
    vosaeroplane
    vosaeroplane New Member
    2022 Tundra SR5
    dekeman[QUOTED][OP] likes this.
  4. Jun 12, 2022 at 9:37 AM
    dekeman
    Derek
    Ottawa, ON, CANADA
  5. Dec 3, 2022 at 10:43 PM
    Jshep
    Jshep New Member
    22 Army Green Limited TRDOR 6.5
  6. Dec 3, 2022 at 11:59 PM
    4ToyotaTrucks
    4ToyotaTrucks New Member
  7. Dec 4, 2022 at 12:13 AM
    Jshep
    Jshep New Member
  8. Dec 6, 2022 at 10:57 AM
    wayne73
    wayne73 New Member
    Wayne
    Minnesota
    2022 limited crewmax trd offroad
    I just installed these as well last night. They worked perfect. No hyper flash or issues with the truck.
    took maybe 15 mins to install thru the wheel wells.
    I didn’t go with switch back. Just a low and high level amber depending on whether you are running turn signal or not.
    Mjm1984 likes this.
  9. Dec 6, 2022 at 2:32 PM
    mmasse
    mmasse Digital Forensics Cowboy
    Idaho
    2022 Magnetic Grey Tundra
  10. Dec 22, 2022 at 3:40 AM
    dekeman
    Derek
    Ottawa, ON, CANADA
    Picked up the Lasfits in a black friday sale. WAY brighter. Easy install. Pix illustrate the light during the signal flash. Passenger side is new LED; driver side is stock filament. Park lights are about the same brightness as stock bulbs, but when signalling the LEDS are significantly more noticeable, not nearly as washed out as the OEMs.
    FlyinBrian, Yaboy and porterbc like this.
  11. Dec 22, 2022 at 5:04 AM
    porterbc
    porterbc New Member
    Brandon
    2022 Tundra Crewmax Limited TRD OFF-ROAD
    Nice upgrade…
    A true Canadian… Blizzaks on the tundra!
  12. Dec 23, 2022 at 3:53 AM
    Space Wrangler
    Space Wrangler New Member
    2023 Tundra
    I just installed the LASFIT as well. Very happy with the results. I went through the wheel well but couldn't locate them at first. I had to go inside and look up a picture of the back side of the headlight then it was easy to reach up and feel where the turn signal lights were. Quick and easy installation.
    dekeman[OP] likes this.
  13. Mar 18, 2023 at 7:06 PM
    ColumbiaGorge
    ColumbiaGorge New Member
    Joe
    Columbia Gorge
    24 Limited
    I installed the Diode Dynamics switchbacks today. Resisters are required. The ground on each plug is on the left if you’re looking at the clip for the plug and signal light on the right, constant in the center.
    It is much easier to access the turn signals if you remove the 4 bolts on the front of the wheel well liner (10 mm) rather than fishing through the top. I tried both.
    Amber light isn’t as “amber” as I wanted it to be. Still much much brighter than stock and the white light matches the headlights well.
  14. Mar 18, 2023 at 9:10 PM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Watching this thread. N or upgrade!
  15. Oct 14, 2023 at 4:26 PM
    KA22TRD
    KA22TRD New Member
    Kevin
    2022 White Tundra SR5 TRD
    Level lift
    Old thread but still good info!! I just ordered a set.
  16. Oct 14, 2023 at 6:09 PM
    Black widow TRD
    Manuel
    Got a set for sale if anyone is interested. Diode dynamics along with the resistors.
    CHESSIEMAN likes this.
