Exhaust help
Discussion in 'Performance and Tuning' started by Tundy14, Feb 11, 2022.
  1. Feb 11, 2022 at 7:46 AM
    Tundy14
    Tundy14 [OP] New Member
    2014 SR5 Tundra
    Ok I want to get a muffler for my tundra but my issue is I don’t know what I want. I’ve read through the forum and have done tons of research but everybody has a different answer, so I’ve decided to just ask. I don’t want to be very loud and really trying to get as minimal drone as possible. I just want the sporty you hit the petal and you can hear it but not super loud in the cab. I’ve heard the flowmaster super 50 and I do like that and I’ve heard the flowmaster 50 hd. So I really don’t know between those since they are significantly different on the sound scale and I’ve only heard them through video and so everyone knows you just can’t get that same sound through a video and I feel like the 50 hd would drone badly so I want y’all’s opinion on it. Or if there is a better muffler which I know of dirty deeds but I haven’t heard it yet and also do y’all think I should remove the second cats or just leave them and put in the exhaust. So just tell me what y’all think.
  2. Feb 11, 2022 at 8:02 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Keep your cats, they are there for a reason. Search here and youtube, there are dirtydeeds vids. Even the stock exhaust has some drone if you listen for it, so aftermarket mufflers will too unless the system is designed to address that- so just a muffler swap will not address the drone potential. Dirtydeeds uses a resonator on the tailpipe and it works as designed.
    I use the DD 10 inch standard stainless steel system with resonator. Not obnoxious, never buzzy or raspy, cold starts are not going to bother your neighbors. It has a nice, deep, tuned sound.
    Did a quick search for you- enjoy https://www.youtube.com/results?search_query=dirtydeeds+tundra+exhaust
    1lowlife and 808Tunderer like this.
  3. Feb 11, 2022 at 8:54 AM
    Tundy14
    2014 SR5 Tundra
    Ok so I've looked at the dirty deeds exhaust and yeah i do like them. And yeah I know that even that stock exhaust has drone i just didn't want the really bad drone that some exhaust have that I've heard about. But now my situation is price I'm really not trying to spend that much on a exhaust. Now I do know that you get what you pay for type of situations so ill spend the money on a good exhaust but i just don't want to spend that much. So I did some more looking on the dirty deeds website and see that they sell just the muffler alone but there no real description or anything so what do you recommend I get for the size and inlet/outlet size and do you know if that's for the pair or just one cause if its just one i might just get the weld on.
  4. Feb 11, 2022 at 9:03 AM
    frichco228
    Frank
    Virginia
    If you are looking for a muffler only, a mild flowmaster may not be too bad, 50 series. May want to check out Magnaflow. And if you didnt know dirtydeeds can set you up with a muffler too. Give Keith at DD a call, he is very informative and knows about tundras, exhaust and related performance.
  5. Feb 11, 2022 at 9:10 AM
    Tundy14
    2014 SR5 Tundra
    Ok I’ll try and give him a call today and see what he thinks thank you for the help
  6. Feb 11, 2022 at 9:15 AM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    Dirty Deeds.
    Dirty Deeds!!!!
    10” with resonator sounds like what you want.
    keep the cats.
    1lowlife likes this.
  7. Feb 11, 2022 at 9:17 AM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    If you want to go the less expensive route look at mufflers with a straight through design which are magnaflow and I think the flomaster 50 series as well. I prefer the sound and performance of a non baffled muffler and supposedly there’s less drone. You can always add a resonator as well to help with drone after the fact. I had a Nissan Titan that I added a 22inch magnaflow muffler to. Loved the deep sound but had a bit too much drone so I added an aftermarket resonator that needed welded on and it sounded great after that. Lots of guys on here selling their hemholz resonators which is a non weld option. That’s going to be a cheaper route than a whole system.
  8. Feb 11, 2022 at 9:29 AM
    aussieaarons
    aussieaarons die with memories, not dreams
    2019 Cavalry Blue TRD
    2” level, roof mount DVD, interior LED bulbs, sumosprings out back, OEM folding cover, Blackout emblems
    I have had the flowmaster 50 on for about 2 months now. I think it is a good mix of growl and quiet. I find it Comes alive when your accelerating up to speed and if you hold it in the 2500rpm range (around town) but back to being quiet when cruising and at idle. No “drone”, can slightly hear it more than the stock when cruising on the highway but it doesn’t bother my kids (6 and 4) or wife.
    If you were wanting a louder or more aggressive tone I would probably go with the flowmaster 40 because the 50 is on the milder side in my opinion
    justcuz and Nbab23 like this.
  9. Feb 11, 2022 at 10:13 AM
    Tundy14
    2014 SR5 Tundra
    Which 50 series do you have the heavy duty or the delta flow
  10. Feb 11, 2022 at 10:19 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Give Keith from Dirty Deeds Industries a call at 760-877-4234!! You will get the exact sound you want and the price you will be stoked over.
    Thanks, Shawna, DDI
    1lowlife and panicman like this.
  11. Feb 11, 2022 at 10:36 AM
    poheller
    poheller 2018 Platinum
    Scot
    The great state Ohio
    2018 platinum
    Carven exhaust, no resonators needed.
  12. Feb 11, 2022 at 10:04 PM
    aussieaarons
    Flowmaster 524553 Super 50
  13. Feb 11, 2022 at 10:13 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    ^ This..
    The ONLY exhaust upgrade for Tundra..
    Direct bolt-on into existing exhaust system.
    If you want the Helmholtz resonator, drill a 2-inch hole and mount it.
    Drone minimized, lower than stock..
    You buy a Magnaflow, Flowmaster, Carven, etc, and you don't like it?
    You're stuck with it.
    And good luck calling them personally and discussing your wants and needs.
    I first had a Flowmaster on my 2014 and it gave me the DRONE FROM HELL on the highway.
    Call Keith @dirtydeeds and get personal attention.
    Dirty Deeds Industries - Performance Without Drone
    Products Archive - Performance Without Drone (dirtydeedsindustries.com)
    You can search this forum and find a TON of positive experiences with Keith.
    I'm one of them.
    dirtydeeds[QUOTED] and panicman like this.
  14. Feb 12, 2022 at 5:33 AM
    justcuz
    justcuz 2.5 Gen Member
    I went with the Flowmaster 50 series delta flow. Agree with the post above. Not as loud as 40 series but much better than stock. Nice growl to it. No regrets. AB73465A-36F4-4890-9715-29AC1955ECD2.jpg
    aussieaarons[QUOTED] likes this.
  15. Feb 12, 2022 at 9:58 PM
    Tundy14
    2014 SR5 Tundra
    Talked to Keith and definitely getting a muffler from him.
  16. Feb 13, 2022 at 4:10 AM
    1eyedclyde
    1eyedclyde New Member
    Clyde
    NewCastle CO
    21 SC Pearl Platinum
    Super friendly and knowledgeable dude. He sold me.
    dirtydeeds likes this.
  17. Feb 13, 2022 at 6:07 AM
    dirtydeeds
    Keith
    USA
  18. Feb 15, 2022 at 9:04 PM
    vipgs3
    vipgs3 New Member
    CA
    2015 Toyota Tundra 4x4
    If you decide to switch up the muffler in the future, check out black windows race venom muffler. Nothing too aggressive or drone.
