275/60/20 fit my stick ‘20 Tundra?
Discussion in '2.5 Gen Tundras (2014-2021)' started by BigRed20, Feb 12, 2022.
  1. Feb 12, 2022 at 5:06 PM
    BigRed20
    BigRed20 [OP] New Member
    2020 Barcelona Red TRD
    As the title says, will a 275/60/20 fit my stock Tundra?
    I plan on lifting the truck soon, but I’ve got to replace my OEM 275/55/20 tires. I know it’s backwards but it can’t be helped.
    TIA.
  2. Feb 12, 2022 at 6:06 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Got the same truck, I put on 275/65/R20, BFG KO2s. Zero rub and no trimming, looks great with the factory rims too. tire discounters treated me well, discount tire and TD should offer a fit test before you commit, ask them.
    BigRed20[OP] likes this.
  3. Feb 12, 2022 at 6:11 PM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    Try Falken Wildpeaks A/T3, let me know! :rofl: You know... for my next set.
  4. Feb 12, 2022 at 6:25 PM
    Bentarm13
    Bentarm13 New Member
    I put the cooper tires in this size on my 21 and love em. Front 2.5" level only.
  5. Feb 12, 2022 at 6:30 PM
    BigRed20
    Very nice!
    OHwendTrd[QUOTED] likes this.
  6. Feb 12, 2022 at 6:48 PM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    Thanks! No level btw either. I decided against it this go around.
  7. Feb 12, 2022 at 6:51 PM
    BigRed20
    Im going with a 2” level, and those tires look great.
  8. Feb 12, 2022 at 6:54 PM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    That will look great, have to post pics when it's all setup. Rubber isn't cheap these days
  9. Feb 12, 2022 at 7:23 PM
    BigRed20
    Thank you sir.
  10. Feb 12, 2022 at 7:36 PM
    bryan s
    bryan s New Member
    NEPA
    2016 202 tundra crew cab
    3 1/2 rough country lift 295/60/20
    There should be no problem with that size at stock height.. 285 would rub a bit i think at full lock.. I have a 3 1/2 lift 295/60/20 rubs a hair at full lock due to the bigger lugs on my tires I'm planing a body mount chop soon
  11. Feb 12, 2022 at 8:52 PM
    TNTundra16
    TNTundra16 YOU BIG DUMMY!
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    Here's some old pics of my truck from a couple years ago. 275/60r20 Falken Wildpeak at3w on stock suspension. No rubbing not even close. Still running these tires on different wheels. They are amazing in all types of terrain.
