2011 Transmission Fluid Change Question
Discussion in '2nd Gen Tundras (2007-2013)' started by Scottyp857, Feb 4, 2022.
  1. Feb 4, 2022 at 4:46 AM
    Scottyp857
    Scottyp857 [OP] New Member
    Scotty
    2012 Tundra 4.6l
    I have a 2011 Toyota Tundra and it has 200,000 miles and question is can you change the transmission fluid. I was told you don't change the transmission fluid on these Tundra. Thanks
  2. Feb 4, 2022 at 4:58 AM
    fixnfly
    fixnfly New Member
    08 double cab 5.7
    Of course you can but toyota made it a complicated process on purpose so people can screw it up be required to take it to a dealer.
  3. Feb 4, 2022 at 5:29 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    If it's never been done yet, at 200k dont do a flush...honestly I'd almost say do nothing.
    But if you really deem it necessary, do a pan drain/refill now and then again another in 5 to 10k. Then again another in 5 to 10k.
    Retroboy1989 and Black Wolf like this.
  4. Feb 4, 2022 at 8:07 PM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    I did 3 drain and fills using exactly this method. The most important thing is to make sure is to do it when the trans in cold and the temperature of the fluid that came out and the fluid you’re putting in are the exact same temperature. My truck had around 170K when I did the first one. I plan on doing it one more time at the next oil change. The pic attached is what it looked like at the first change.
    https://youtu.be/NX3WRAPJ0Aw
    coastaldesert likes this.
  5. Feb 10, 2022 at 4:57 AM
    Scottyp857
    Scotty
    2012 Tundra 4.6l
    Do you recommend dropping the pan and changing the filter also? Thanks for all the replies.
  6. Feb 10, 2022 at 5:01 AM
    Danny3737
    If it were an actual filter and not a screen I would. What scares me about pulling the plan are all the posts I've read about broken bolts.
    WVI and Scottyp857[QUOTED][OP] like this.
  7. Feb 10, 2022 at 6:12 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    How is your truck currently shifting?
  8. Feb 10, 2022 at 7:32 AM
    Landodnal
    Landodnal New Member
    2008 Toyota Tundra Limited Slate Grey 4WD
    2" Leveling Kit
    Does anyone know which ATF WS we should use for our Tundra's? I'm finding multiple part numbers for Toyota ATF WS fluid.
  9. Feb 11, 2022 at 6:30 PM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    2007 Tundra CrewMax 4x4 5.7L V8
    @Landodnal IIRC there is only one Toyo ATF WS fluid. It may have different SKU's depending on the container size or something. If you are very paranoid just call the dealership and ask them for the part number.
    Landodnal likes this.
  10. Feb 11, 2022 at 8:14 PM
    Jchetty
    Jchetty New Member
    No. Do not drop the pan. You will break the bolts.
  11. Feb 12, 2022 at 2:52 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    No need to change the filter, I changed mine at 176k? And it had virtually no material in it
    It has a filter, not a screen. I cut mine open and posted the results on several different threads.
    Retroboy1989 likes this.
  12. Feb 12, 2022 at 2:55 PM
    Retroboy1989
    Northern Utah
    Seems like most Toyotas just have a screen. Several members have posted pics of their tundra filters that really do look like traditional trans filters.
    I would drop mine if the risk of breaking bolts wasn't so high. There are tons of 300k+ mile transmissions out there...some on original fluid. I don't feel too bad just changing the fluid to keep fresh additives.
    WVI likes this.
  13. Feb 12, 2022 at 4:00 PM
    Sumo91
    TN
    You can search my threads and see where I cut mine open, I was the first to do so. There filters are good for the life of the transmission, and can easily handle 20 or 30 times the amount of material mime had at 176k miles. So 176k multiplied by 20 is 3.5 million miles. Thatd be a record lol
    Retroboy1989[QUOTED] likes this.
  14. Feb 12, 2022 at 4:03 PM
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    My wife’s Sequoia 5.7 had 194,000 mikes when we got it
    it has over 250k now
    I’ve changed the trans fluid multiple times without issue. I use Valvoline MaxLife Synthetic ATF which costs about $17 a gallon.
  15. Feb 12, 2022 at 4:24 PM
    Borgunit
    Borgunit New Member
    JR
    Ohio
    2013 Black Rock Warrior
  16. Feb 12, 2022 at 4:27 PM
    Borgunit
    Borgunit New Member
    JR
    Ohio
  17. Feb 13, 2022 at 10:42 AM
    poop_bubbles
    poop_bubbles New Member
    I would recommend having the dealer do a fluid change at 200k, do not do a flush. I had mine done a couple years back and it wasn't bad, maybe $250? That's a full drain and fill. They have to get the transmission to a specific temp range in order to fully drain it. It's the only thing I did not DIY.
