New here. looking for input on wheels,tires,lifts and or levels...
Discussion in 'New Member Introductions' started by RJ82, Feb 11, 2022.
  1. Feb 11, 2022 at 5:23 AM
    RJ82
    RJ82 [OP] New Member
    just picked up 2016 tundra trd offroad crewmax . already have 275/70R18 cooper tires on the factory alloy rims. wanting to lift/level the truck roughly 2.5-3 inches and if possible have the stance .5"-1"out passed the factory fenders. any suggestions on lifts or levels as ive been think about the rough country 3' bolt on with the upper controls arms and rear shocks .. or if i jsut leveled it would i need upper control arms ?? open to all input . thanks
  2. Feb 11, 2022 at 5:39 AM
    Welcome from NY.
  3. Feb 11, 2022 at 5:48 AM
    RJ82
    Thanks, really hoping for all kinds of responses to these matters. not sure how this works , guess its just leave it and see what happens ahah
  4. Feb 11, 2022 at 5:50 AM
    bryan s
    bryan s New Member
    NEPA
    2016 202 tundra crew cab
    3 1/2 rough country lift 295/60/20
    Welcome from PA
    Depends on what your willing to spend... I just bought a new house so didn't have a lot to spend so.
    I got the 3 1/2 Rough Country lift ($1000)so far i have no problems with it.
  5. Feb 11, 2022 at 5:51 AM
    Kanobi13
    Kanobi13 New Member
    Welcome top left click forums entire sections on what you are looking for. Most will go coil over lift with bilstein,fox, and kings up front. 295 70 18 +25 offset. Good luck
  6. Feb 11, 2022 at 5:54 AM
    RJ82
    something like this ??
  7. Feb 11, 2022 at 6:02 AM
    bryan s
    bryan s New Member
    NEPA
  8. Feb 11, 2022 at 6:04 AM
    Kanobi13
    Kanobi13 New Member
    You could do that most do not like spacer lift or blocks as they are rough riding. I have bilstein 6112 set at 1.9 perch and shackles in rear for 1.75 lift. 20201108_115758.jpg
  9. Feb 11, 2022 at 6:07 AM
    RJ82
    why not?? they perhaps just ride harder or just personal preference ?? seems decently priced though . Thanks
  10. Feb 11, 2022 at 6:10 AM
    RJ82
    Ok so coil overs would be a better option if lifting . but if one was to just level the truck guessing then they no choice but to use spacers ??
  11. Feb 11, 2022 at 6:11 AM
    RJ82
    And are upper control arms necessary ?? with lift and or level ??
  12. Feb 11, 2022 at 6:12 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Official welcome for your first post.. Lots of options for what type lift, wheels and tires applications. Budget too.
    Take a research under the Garage section of the forum to see other members pros and cons about their lift.. I'm a big fan of Toytec Coilovers complete lift and I used JBA's UCA to dial in my alignment... No issues at all and drives better than stock.
    Again, pay once, cry once for a solid setup... Good luck.
    bryan s likes this.
  13. Feb 11, 2022 at 6:16 AM
    RJ82
    Right on , ill do just that , thanks
    toyofan87 likes this.
  14. Feb 11, 2022 at 6:21 AM
    Kanobi13
    Kanobi13 New Member
    Preference you can find some bilstein 5100 for same ball park and have options on what lift height. Uca are not necessarily needed i am only 1.9 and at full droop minor contact on the springs not enough to pull trigger on uca
  15. Feb 11, 2022 at 6:23 AM
    bryan s
    bryan s New Member
    NEPA
    Like
    Kanobi13 said spacers make your truck ride rough and wear parts out quicker, and UCA no you don't need them but them make a big difference..
    toyofan87 said it,, if you have the funds spend once.
    Read threw the forums first tons of great info
  16. Feb 11, 2022 at 6:27 AM
    Kanobi13
    Kanobi13 New Member
  17. Feb 11, 2022 at 6:35 AM
    RJ82
    Sweet , thanks again all . really appreciate the input here .
  18. Feb 11, 2022 at 7:48 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! Make sure to post pics once you've made up your mind and installed!
