Retrax issue with bed cleats
Discussion in '2.5 Gen Tundras (2014-2021)' started by GWill, Feb 10, 2022.
  1. Feb 10, 2022 at 11:20 PM
    GWill
    GWill [OP] gods gift to the internet
    Willis
    Don’t know what you’re talking about
    2020 MGM TRD Pro
    I just added the deck rail system under my retrax cover. The instructions indicate I should be able to put my cleats back in, but the rails just sit on top of the cleat. Has anyone else run into this? And am I just gonna have to move forward without the cleats?
  2. Feb 10, 2022 at 11:34 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    MT Madman likes this.
  3. Feb 11, 2022 at 12:02 AM
    GWill
    Willis
    2020 MGM TRD Pro
    Yeah I had to order the new clamps
    okay good to know. The instruction booklet made it sound like it could still have my cleats. Now I’m bummed but I have been eyeing up Chavonias stuff. Hope they’ll fit
    1lowlife[QUOTED] likes this.
  4. Feb 11, 2022 at 2:21 AM
    MT Madman
    MT Madman Just an ordinary guy
    Hawk Point MO
    2020 Silver Platinum
    TRD dual exhaust TRD Rear Sway Bar SnugTop Hi-Liner
    My ReTrax mounted right to the the rail system on my '15 and I was still able to use the cleats that came with the truck.
    1lowlife and Black Wolf like this.
  5. Feb 11, 2022 at 4:47 AM
    GWill
    Willis
    2020 MGM TRD Pro
    Same cleats as what i have pictured?
  6. Feb 11, 2022 at 5:14 AM
    PomDad
    PomDad we having snacks?
    Conrad
    Atlanta
    2021 Cement Limited
    My retrax rails have cut outs in the middle for the cleats to have the clearance needed. Is yours just straight all the way across?
  7. Feb 11, 2022 at 5:16 AM
    Same with my 14. Was still able to use the cleats with the ReTrax.
  8. Feb 11, 2022 at 7:36 AM
    GWill
    Willis
    2020 MGM TRD Pro
    Yup they are straight all the way across :frusty:
  9. Feb 11, 2022 at 10:39 AM
    PomDad
    Conrad
    Atlanta
    2021 Cement Limited
    Here's how mine look
    GWill[QUOTED][OP] likes this.
  10. Feb 11, 2022 at 10:51 AM
    GWill
    Willis
    2020 MGM TRD Pro
    Im wondering if the rails are also different when you tell them if you have the deck rail system or not.
    MT Madman and 1lowlife like this.
  11. Feb 11, 2022 at 11:12 AM
    SAGE63
    San Diego County
    Me too my cleats work just fine.
  12. Feb 11, 2022 at 11:13 AM
    PomDad
    Conrad
    Atlanta
    2021 Cement Limited
    Pretty sure they are - I specified that I had the deck rail system when I ordered these rails. I think the cut away sections are only included if you specify that.
  13. Feb 11, 2022 at 11:14 AM
    odin1701
    odin1701 New Member
    2021 Tundra LTD TRD OR MGM
    Possibly. I know with Bakflip ones they are or at least used to be. They have drop brackets that come with the one I got if you have a deck rail system. Probably don't include those otherwise.
    When I got one for my Taco it had different mounting brackets than if you didn't have the deck rails too.
  14. Feb 11, 2022 at 11:15 AM
    odin1701
    odin1701 New Member
    Another option you have is to cut the rails for your cover yourself.
    1lowlife likes this.
  15. Feb 11, 2022 at 11:16 AM
    GWill
    Willis
    2020 MGM TRD Pro
    Yeah I was thinking it was just the mounting hardware that changed but you are probably right.
  16. Feb 11, 2022 at 11:17 AM
    GWill
    Willis
    2020 MGM TRD Pro
    Was thinking that. Shouldnt be too hard, but I think I would rather go with those sweet Chavaria billet cleats. Pricey but look great
  17. Feb 11, 2022 at 11:17 AM
    odin1701
    odin1701 New Member
    I don't think those will clear your rail either, looking at the picture of yours vs. the other guy's who has the cutouts. I think either way you will have to cut the rails for the cover or get different rails from them.
    The other issue is - how do the clamps work for your unit? The other members picture shows a clamp that looks to use a t-nut and slide into the deck rails.
  18. Feb 11, 2022 at 11:25 AM
    odin1701
    odin1701 New Member
    Actually, looking more at these pictures I don't think yours will work with a deck rail at all. It appears you have an extra lip below the ribbed section of the rail which isn't present on the other one with the cutouts. It looks as if that would be resting on your deck rail and raising up the rails whether there is a cleat in there or not. I think you would need some pretty extensive modification to your retrax rails to work at all.
  19. Feb 11, 2022 at 11:30 AM
    PomDad
    Conrad
    Atlanta
    2021 Cement Limited
    What's the PN on the rail?
  20. Feb 11, 2022 at 11:35 AM
    GWill
    Willis
    2020 MGM TRD Pro
    It seems to lay pretty flat, but Ill inspect it more. I havent attached the clamps back on yet, Ill make some time this weekend to check and see.
  21. Feb 11, 2022 at 11:35 AM
    GWill
    Willis
    2020 MGM TRD Pro
    Im not sure, any idea where I would find that?
  22. Feb 11, 2022 at 11:45 AM
    GWill
    Willis
    2020 MGM TRD Pro
    looks like it should be fine, i haven’t tightened down yet though
  23. Feb 11, 2022 at 11:47 AM
    odin1701
    odin1701 New Member
    If you look at the other picture, that rail doesn't sit over the top of the rail track like yours does. Is it flush against the side of the bed? I'd be concerned that tightening it down may be affected, or the cover might bind, but I don't know.
  24. Feb 11, 2022 at 11:52 AM
    GWill
    Willis
    2020 MGM TRD Pro
    I see what you're saying. It really doesnt look like itll be an issue though. It does however look like it will be an issue with ANY cleats, which sucks. Ill tighten down and report back.
  25. Feb 11, 2022 at 11:54 AM
    odin1701
    odin1701 New Member
    I think you could do an eye bolt with a t-nut. There's someone who made something like that. I'll have to see if I can find it.
  26. Feb 11, 2022 at 12:12 PM
    odin1701
    odin1701 New Member
  27. Feb 11, 2022 at 12:15 PM
    GWill
    Willis
    2020 MGM TRD Pro
  28. Feb 11, 2022 at 12:40 PM
    PomDad
    Conrad
    Atlanta
    2021 Cement Limited
    You might actually be okay with how close yours is to the rail.
    Full disclosure is that I bought a canister that was previously on a RAM1500 and I think it's a little more narrow/longer than ours (the length is why I bought new rails).
    Looking at how close yours is looks more right to me as mine is farther from the side than I think it should be.
    Edit: I can definitely say that my rails are correct though for the bedrail system as the replacement rails I ordered allowed me to specify that.
  29. Feb 11, 2022 at 10:04 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    I would contact Retrax and tell them you added the deck rail system to your truck.
    Let them know in your email (in a nice way) the results will be posted on your Tundra forum(s)..
    They will either:
    1. Sell you just the bed rail Retrax rails you need
    2. Send you a set of bed rail Retrax rails for free
    It doesn't hurt to ask..
    Undercover has gone above and beyond in customer service with my Undercover Flex.
    Including replacing my 23-month-old Flex (2 year warranty). and sending me rail clamps for free when I bought my bed rail system (after 3 years).
    Good luck...
  30. Feb 12, 2022 at 4:11 AM
    MT Madman
    Hawk Point MO
    Yep.
