2022+ Gen 3 Turbocharger Failure List.
Discussion in '3rd Gen Tundras (2022+)' started by Coal Dragger, Feb 9, 2022.
  1. Feb 9, 2022 at 10:26 AM
    Coal Dragger
    Coal Dragger [OP] New Member
    Kung Fu Dick
    The purpose of this threat is to track Gen 3 2022+ model year Tundra’s that have turbocharger failures.
    Please keep posts brief and factual with the following format:
    1.) Build date.
    2.) In service date.
    3.) Mileage and date of failure.
    4.) Description of problem and resolution.
    Your build date should appear on the door frame sticker with your VIN number. To ensure your privacy I strongly suggest not posting a photo of this sticker, or listing your entire VIN #.
    To keep this thread organized please consider editing your original post when you have a resolution or update to post.
    Hopefully this can help us all keep track of this known issue.
    Alice123, mtcsr2000, jpedigo and 9 others like this.
  2. Feb 9, 2022 at 12:01 PM
    MaddMattTank
    MaddMattTank New Member
    Atlanta Area
    2022 Tundra Crewmax SR5 4x4 TRD Off Road Lunar Rock
    2" Front Level Kit Method 705 18" +18 offset Toyo Open Country AT3 295/70R18
    Adding to that list of 4 basics ; perhaps one should be Trim: SR/SR5/Limited/etc and powertrain 4x2; 4x4
    ¯\_(ツ)_/¯
  3. Feb 9, 2022 at 12:05 PM
    mass-hole
    mass-hole New Member
  4. Feb 9, 2022 at 12:14 PM
    mass-hole
    I just listed it in the comments column but I could break it out.
  5. Feb 9, 2022 at 12:18 PM
    mass-hole
    So far I added these two:
    I have not followed the other thread so if someone wants to post up other specific examples I can add them.
    pamtnman and ChiefG like this.
  6. Feb 9, 2022 at 7:11 PM
    R2theD2
    R2theD2 New Member
    Seattle
    2022 Tundra 1794 TRD Off-Road Lifted - Midnight Black
    TRD Lift Kit TRD Skid Plate TRD Running Boards Nitto Ridge Grapplers (35x12.5) OEM Bed Step OEM Toyota Tonneau Cover (Quad-Fold) 3M Window Tint (matched factory rear) Spray-On Bedliner
    1.) Build date: 12/15/22
    2.) In service date: 1/21/22
    3.) Mileage and date of failure: 606 miles on 2/6/22
    4.) Description of problem and resolution: Turbo replacement needed after receiving “Reduced Power - Visit Dealer” warning
    lovely.
  7. Feb 10, 2022 at 12:36 PM
    mass-hole
    Breathing Borla likes this.
  8. Feb 10, 2022 at 3:32 PM
    Breathing Borla
    AZ
  9. Feb 14, 2022 at 2:33 PM
    bruinrumble
    bruinrumble New Member
    1.) Build date: 1/22/22
    2.) In service date: 2/02/22
    3.) Mileage and date of failure: 192 miles on 2/12/22
    Parking brake assist malfunction - visit dealer
    updated: dealer reset lights and told me “not to floor it” ugh. I was told Toyota is building a new part for a fix and sees no value in replacing a faulty part (current part) with another faulty part (new and shiny). I see that logic, but dang.
    pamtnman, sd172, Dmon187 and 2 others like this.
  10. Feb 14, 2022 at 6:27 PM
    mountaingroan
    mountaingroan New Member
    Frank
    North Idaho
    2020 SR5 DC VooDoo 4WD Bench!
    Why or how the hell did a build date of 1/22/22 have this issue? I have to wonder if Toyota just basically said 'f*ck it build 'em anyway' and used the defective parts. This waste-gate issue was discovered weeks before that, was it not? How could this have happened??
    Has me really rethinking my upcoming build date, this company which I've always revered as the best out there is a complete farce right now.
    pamtnman and Dmon187 like this.
  11. Feb 14, 2022 at 6:39 PM
    Coal Dragger
    Kung Fu Dick
    I theorize Toyota calculated that failures wouldn’t be noticed by the buying public, and elected to build trucks anyway. Why not? Usually only the manufacturer is going to compile data on the failure, and they’re sure as hell not going make that information public.
    Hence my reason for starting this thread. We can compile data, and put it out there.
  12. Feb 15, 2022 at 7:13 PM
    SLVR6
    SLVR6 New Member
    i would be flooring it every chance I get to show that it returns.
    JRC, pamtnman, denor2d2 and 2 others like this.
  13. Feb 16, 2022 at 12:40 PM
    RangerMarsh
    RangerMarsh New Member
    2022 Tundra TRD
    1.) Build date.12/2021
    2.) In service date. 10/02/2022 & 16/02/2022
    3.) Mileage and date of failure. 250km. early Feb 2022.
    4.) Description of problem and resolution. check engine solid light+ braking support malfunction light. visit the dealer 2 times. first time they didn't have a clue. erase the code, test drive, no problem. but a week later the light goes on again. dropped off at dealer. They told me they'll order new turbos from Toyota and replace. was told parts will arrive 2 -4 weeks..... ughhh
    pamtnman likes this.
  14. Feb 16, 2022 at 1:32 PM
    Breathing Borla
    AZ
    turbo or turbos?
    I have only seen them replace one from what I've read.
    Tom likes this.
  15. Feb 16, 2022 at 4:27 PM
    Coal Dragger
    Kung Fu Dick
    All the ones I’ve seen are passenger side turbo assembly.
  16. Feb 16, 2022 at 4:54 PM
    RangerMarsh
    2022 Tundra TRD
    don't know yet. they told me they'll replace Both.
    But anything is possible. until they receive the order parts.
  17. Feb 17, 2022 at 4:14 PM
    cemetz3
    cemetz3 New Member
    Chuck
    West Lebanon New Hampshire
    2022 Tundra SR5 4x4 with Options
    What would be nice to know is what is the most milage of the turbo (waste gate) failure. What I'm getting at is if your over a certain milage you should be improving your odds that your in the clear?
    doublethebass likes this.
  18. Feb 17, 2022 at 4:32 PM
    Coal Dragger
    Kung Fu Dick
    Not enough data to tell at this point.
  19. Feb 18, 2022 at 12:46 PM
    mountaingroan
    Frank
    North Idaho
    I just called and talked to my salesman to check to see if my build is on time, so far so good. T- minus four days. 2/22.
    We discussed the wastegate issue, the Lewiston dealership hasn't had an issue with any of the trucks they sold, although that number is probably small. He informed me that Toyota had discussed the issue with dealers, the 'official' total of affected trucks is 1% of past sales. He also stated that there are no February dates affected with wastegate anomaly.
    It's anecdotal and the words of a salesman, so take it for what's it's worth, but he's been a 100% square dude to deal with. He has a Limited model being built, he shared that he's as frustrated as the rest all of us with waiting.
  20. Feb 20, 2022 at 7:01 AM
    Laffingas
    Laffingas New Member
    '22 Tundra Limited - Army Green
    10% failure is complete BS. This is the result of social media blowing something completely out of proportion. So far, there are 5 documented on the spreadsheet.
  21. Feb 20, 2022 at 7:10 AM
    Toyota1234
    Toyota1234 New Member
    Jack
    2022, army green limited, off road, DC
    But if 1% is true then that number will climb as miles get put on trucks. It takes some guys months to put a 1000 miles on a truck. So where does that number end? Higher then 1%
    RGSIII and Breathing Borla like this.
  22. Feb 21, 2022 at 6:21 AM
    Laffingas
    Yes, the percentage failure will climb as miles are put on the trucks, however, your speculation that the percentage will end up higher than 1% is pure conjecture on your part. It's too early for sales figures for any 2022's, but one UNOFFICIAL number I found was 4952 Tundras so far in 2022. I don't know if that's model year, fiscal year, year to date, or what. If even half of those are 2022's, then 5 documented failures doesn't even come close to 1%. You can keep being negative, but my 2022 is doing great so far.
  23. Feb 22, 2022 at 4:34 PM
    nodak67
    nodak67 New Member
    JR
  24. Feb 22, 2022 at 4:54 PM
    Coal Dragger
    Kung Fu Dick
    Oh cool a video from the same moron who can’t accurately describe turbocharger operation or what a wastegate does.
    theripper and Mattedfred like this.
  25. Feb 23, 2022 at 12:40 PM
    jtp960
    jtp960 New Member
    2022 White Tundra SR5
    240 miles on my tundra and I have gotten the parking brake support malfunction, check engine reduced power, and advanced ultrasonic detecting and ranging system malfunction. Have appointment with dealer in a couple days.
    cw4 and ryanwgregg like this.
  26. Feb 23, 2022 at 12:41 PM
    jtp960
    jtp960 New Member
    **Update**
    Confirmed turbo failure-
    Build date: 1/12/2022
    In service date: 1/29/22
    Turbo failure at 240 miles
    No estimate yet on repairs or time frame
    **update #2**
    Dealer kept the truck for a week. Cleared the codes and then drove it for 60ish miles and could not replicate the turbo failure so it was returned to me.
    1 week later after putting another 150 miles on the vehicle it went into failure again. Returned to dealer and the turbo was replaced in less than a week.
  27. Feb 25, 2022 at 12:36 PM
    Jasonstein
    Jasonstein New Member
    2022 Tundra 4x4 LMT Crewmax
    none
    build 12/2021
    purchase 2/22/22
    engine light 2/23/22 @ 84 total miles!
    in service dept 2/24/22
    Picked up my new Tundra after much resistance because of the wastegate issue. I wanted it enough to believe the engineer on you tube who stated it's likely 1/10 of 1% of the trucks. My color was coming in (hard to get) so I jumped on it assuming these issues were all but gone. WELLLL I got 84 miles before I got the light. They have no idea how long the wait for parts will be but the "hope" it will be a few days. This of course is after paying 6,000 over MSRP. Now I have the lowest trim package 4runner for who knows how long? Looks like around 30 days from what I'm seeing.
    pamtnman, sd172 and (deleted member) like this.
  28. Mar 2, 2022 at 7:35 AM
    amilaw
    amilaw New Member
    2022 Tundra Platinum
    Tacotunes catalytic converter shield, OEM bed cover
    Well add me to the list, Platinum built at the end of Nov 2021 gave the check engine light and a parking system malfunction yesterday at ~250 miles. Took to dealer today and they said the wastegate on the bank 1 turbo failure. Parts on order, no ETA, getting setup with a loaner later today.
  29. Mar 2, 2022 at 10:31 AM
    Coal Dragger
    Kung Fu Dick
    If you have a chance can you put your info into the standard format for reporting on this? Just for ease of compiling data.
    Sorry this happened to your new truck.
  30. Mar 4, 2022 at 3:31 PM
    -Mike-
    -Mike- New Member
    2022 Tundra SR5 TRD Off-Road
    TRD Air filters. New pass side turbo : )
    New guy here but felt my first post should document the repair mine had already.
    Prod Date 1/18/2022
    DOFU 2/09/2022
    CE light 2/11/2022 @ 212mi
    Part ordered on 2/14/22
    Part Arrived and installed on 2/21/22.
    500mi since then of absolute punishment and zero residual issues.
    Truck runs terrific and after owning one of every gen is by far my favorite.
