2015 with 37" tires BDS 6" lift / offset questions
Discussion in 'Wheels & Tires' started by SRPoor, Feb 10, 2022.
  1. Feb 10, 2022 at 9:44 AM
    SRPoor
    SRPoor [OP] New Member
    I just bought a used 2015 with a BDS 6 lift. The truck came with 37x13.5R22LT tires on it and they stick out quite a bit. I don't like the look of this and even with flares they would still stick out too far for my tastes.
    1. Could these tires be used on a rim with a different offset to bring them in some? It looks like the front would be tight due to the lift components but could come in a few inches. The rear looks like plenty of room.
    2. Would I be better off just buying new rims/tires and selling these off? I want something that looks appropriate for the lift/truck but would be ok with 35" tires/rims.
  2. Feb 10, 2022 at 9:56 AM
    Henry2019
    Henry2019 N/A
    Houston, Texas
    2019 SR5 CM CEMENT GREY
    3/1 Lift Kit 20X9 Fuel Assaults +1 295/60R20 Falken Wildpeak A/T3W
    measure the clearances between your front tires/wheels and the suspension components etc.. that’ll help determine how much more you can tuck in your wheel/tire setup before making a decision.
