Tailgate latch stuck
Discussion in '2nd Gen Tundras (2007-2013)' started by Dag3, Feb 6, 2022.
  1. Feb 6, 2022 at 7:13 AM
    Dag3
    Dag3 [OP] New Member
    Vail, Colorado
    2012 crew max limited
    This happened last night. Can’t get it open now and with my tonneau cover I can’t access the bed. thoughts?
    Stainlesst likes this.
  2. Feb 6, 2022 at 7:20 AM
    2mchfun
    Might be able to use a section of steel pallet banding material to craft yourself a slim tool for releasing bed cover. A hacksaw blade might also work if long enough.
    Dag3[OP] likes this.
  3. Feb 6, 2022 at 9:28 AM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    If the previous reply doesn’t work, it looks like you’re going to have to replace the handle anyway so might as well get rough with it… maybe spray some lubricant, heat it up, spray compressed air or a power washer into it, bang it, and if all else fails just drill or grind through it.
    You might order the replacement part first so you can immediately swap it out.
    2mchfun and Dag3[OP] like this.
  4. Feb 6, 2022 at 10:44 AM
    triharder
    triharder Sorry, Not Sorry
    Jake
    Southern, Maine
    2010 RWB Black
    Billstein 6112/5160's, coachbuilder spacer on driver side/ 20" rockstar wheels/ 33" nitto ridge grappers/SS Brake lines (or as most people write Break), Painted Calipers/Powercoated Tow hooks/pocket flairs/heated seats,bed leds/line-x liner/xtang trifold/tow mirrors/Stereo Work/Compustar Remote Starter/ retrofit Morimoto Minin H1 and switch back LEDs/ plenty I'm forgetting
    When mine did that it was broken.
    and they are 106 bucks from everywhere but Amazon (you can find them for $76) dollars.
    You need to destructively remove it from the outside in.
    Good luck. Sorry this happened to you. It happened to me when it froze but the tonneau was off thankfully to access mine.
  5. Feb 6, 2022 at 11:36 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    My handle/latch was frozen the other morning. Couldn't get into the bed.
    Luckily, I didnt really NEED to get in there and it just thawed and became useable later that day.
    I'll definitely remember not to force it, if/when it happens again.
    Seems to be the only major drawback to a tonneau cover. They dont seem to like ice.
  6. Feb 7, 2022 at 6:42 AM
    Dag3
    Vail, Colorado
    260A9C95-89BB-4E3E-B5D3-84877523D14D.jpg Good news is I got the handle down, bad news is it’s no longer attached to the truck.
  7. Feb 7, 2022 at 7:11 AM
    Stainlesst
    Stainlesst everybody loves an Inky. Inky Inky. go Inky go!
    going to the big D and don't mean Denver...
    09 trd crewmax, 13 TWReX stage III
    In the "Zone"...
    Use a rigid long flat tip screwdriver to push the tail gate catches in on both sides. Try not to scrape the paint on your tail gate. Make sure it is thawed out also your tonneau cover probably is frozen to the top of the tailgate has happened multiple times to me.
  8. Feb 8, 2022 at 9:38 AM
    FredB32
    FredB32 New Member
    Fred
    2011 TRD RW
    Success!
    Is it a hard tonneau cover? The first time this happened was when I was getting the tires swapped and they yanks on it and snap...but I (rather uncomfortably, mind you) was able to peel back the velcro on the side of my (soft) tonneau cover and squeeze my hand in there to release the latch. It's a tight fit and not as easy as regular access, but I did it.
    The handles can be had cheaply on Amazon and Ebay. I don't think (IMO) the OEM handles are any better than the cheap ones you'll find online, and they offer them with the camera hole as well so you should be able to get a replacement for $30-40. Between my two Tundras, I've replaced 3 broken tailgate handles. I actually bought an extra last time so I have one on hand. Also - pushing the tailgate IN slightly before you pull helps immensely to remove a lot of the tension the tailgate is under and minimizes the chance of breaking the handle.
    Dag3[QUOTED][OP] likes this.
  9. Feb 8, 2022 at 10:07 AM
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    Doh! Can you open it now at least?
  10. Feb 8, 2022 at 12:24 PM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    Protip
  11. Feb 8, 2022 at 12:31 PM
    FredB32
    FredB32 New Member
    Fred
    2011 TRD RW
    Learned the hard way from experience :D
    Although the couple times I've let other people use my truck, you might be surprised how difficult it is to actually explain that to people.
    "No...push it in a little before you pull it out." :monocle:
  12. Feb 8, 2022 at 12:36 PM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    Same here. I've broken 2 of them before I learned. And yeah I agree with buying the "cheapies"....one instance where buying OEM for double the price isn't warranted.
  13. Feb 8, 2022 at 8:09 PM
    Dag3
    Vail, Colorado
    No
  14. Feb 8, 2022 at 8:12 PM
    Dag3
    Vail, Colorado
    Luckily, my wife doesn’t have sausage fingers like me and she was able to squeeze her hand between the tonneau cover and tailgate and pull the cord. So now the cover is open but tailgate is still stuck closed.
  15. Feb 9, 2022 at 4:51 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    Remove the panel on inside of the tailgate.
