2006 SR5 DC starter replacement ?
Discussion in '1st Gen Tundras (2000-2006)' started by growit, Feb 8, 2022.
  1. Feb 8, 2022 at 4:34 PM
    growit
    growit [OP] New Member
    2006 Dbcb SR5
    Looking for some opinions about weather to replace the starter myself or have the dealership do it. I just received a 25% off service and parts coupon in the mail.
    I usually do my own work but the thought of being bent over in the engine bay for hours has me
    thinking twice. The starter is actually working fine but with 300k plus it's just a matter of time before it fails. Any advice would be appreciated. Thanks
  2. Feb 8, 2022 at 4:39 PM
    If it hasn’t failed, don’t mess with it. Preventative maintenance should be used on maintenance items. A starter is a pass or fail for me. These are highly durable units. Mine has 265k miles on it. Original starter with new contacts at 112k or so. Original owner must have twisted that key a lot before I got it. Still strong like Bull.
    bmf4069, N84434 and speedtre like this.
  3. Feb 8, 2022 at 4:47 PM
    I would leave it alone unless it started to act up on you. I don't think a starter fails instantaneously unless you do something seriously wrong and burn it out prematurely.
    That said, I would avoid engine bay cleaning and getting any water in there that could pool and corrode the starter contacts.
  4. Feb 8, 2022 at 5:00 PM
    ^^ 1st answer, also the best answer.
  5. Feb 8, 2022 at 5:00 PM
    The contacts I’m referring to are internal. The starter has to be removed, the cap taken off the back and the contacts are accessed inside.
  6. Feb 9, 2022 at 6:55 AM
    terrward
    terrward New Member
    2004 DC SR5
    I’m still on the original starter on my truck at 465,xxx Kms. No plans on replacing it until it fails.
    KNABORES and HBTundra like this.
  7. Feb 9, 2022 at 7:09 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    If, and that's a big if, your truck was sold with the "Cold Weather" package, it would have the Heavy Duty starter.
    HD = Stronger...
    speedtre likes this.
  8. Feb 9, 2022 at 8:23 AM
    speedtre
    speedtre New Member
    Inland Northwest
    D
    Yes, what @N84434 said. Check it on toyota.com/owners....if it has the HD starter I would not even consider replacing preventatively unless you had to have that intake manifold off for another reason altogether.
  9. Feb 9, 2022 at 10:56 AM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    I hope its just a glitch on the website, but I just tried to pull up my window sticker on Toyota Owners under vehicle specs and the website just blinks but doesn't load the sticker. I guess I should have saved a screen shot years ago.
  10. Feb 9, 2022 at 11:51 AM
    Remember to scroll down. If you don't, it looks just like that: Like it's giving you the box back. It took me a few before I realized it. I also notice they changed up the link or something, or maybe Google has the Owners login area URL cached. Or they're updating the website. Strange, I got to it the other day without having to login, now it wants me to login, and I can't find the URL I used for whatever reason
  11. Feb 9, 2022 at 1:04 PM
    speedtre
    speedtre New Member
    Inland Northwest
    I think there is something going on with the website...several things are screwed up at the moment....this is not unusual for toyota.com/owners unfortunately.
    I just typed the above and then tried to login to toyota.com/owners before I hit send and just got this...so, yea, it's having problems. :(
  12. Feb 9, 2022 at 5:09 PM
    growit
    2006 Dbcb SR5
    There is no cold weather package on my truck, sounds like I should just let it be.
    I appreciate everyone's input.
  13. Feb 9, 2022 at 5:10 PM
    Timing belt and ball joints in good shape?
  14. Feb 9, 2022 at 5:20 PM
    growit
    2006 Dbcb SR5
    All in good shape. Timing belt was done around 270k and did front end refresh at 250k. OEM ball joints and tie rod ends, ACdelco pro upper and lower control arms.
    I really enjoyed doing that stuff. It was many years before the truck really needed anything. Also center bearing and ujoints.
    des2mtn and shifty` like this.
  15. Feb 9, 2022 at 5:26 PM
    That 25% off coupon may be best left alone then. You save 100% of the money you don't spend.
    des2mtn, bmf4069 and speedtre like this.
  16. Feb 9, 2022 at 5:42 PM
    growit
    2006 Dbcb SR5
    I think my wife might use it, she has a 2015 Highlander with seat heaters that work intermittently. I'd rather not mess with them.
  17. Feb 9, 2022 at 8:46 PM
    1stgentundradriver
    1stgentundradriver Each sticker adds at least 5hp
    Josh
    Silverdale Washington
    2006 DC 4x4 Limited
    A few
    Do I just enter my vin into toyotaowners.com to see if I have the cold weather package?
  18. Feb 9, 2022 at 8:54 PM
    speedtre
    speedtre New Member
    Inland Northwest
    Register, then add your vin, then click on "View Specs" to see how it was delivered when new...easy peasy...once they get the website working 100%. Right now "View Specs" is not working...:thumbsup:
  19. Feb 10, 2022 at 6:23 AM
    You may also want to assign your truck to yourself over there if you haven't already. Not like Toyota is actively issuing recalls much for our trucks at this point, but ... at least you'll know if there are any open recalls on your truck, and you'll be alerted if anything else comes up.
    1stgentundradriver likes this.
  20. Feb 10, 2022 at 2:36 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    As of right now it's still not working. Wanting to see the specs on the 2006 the fellow posted about the other day....oh well !
