Brake controller on a 1st gen?
Discussion in '1st Gen Tundras (2000-2006)' started by savagefen, Feb 7, 2022.
  1. Feb 7, 2022 at 1:34 PM
    savagefen
    savagefen [OP] New Member
    Jon
    2002 Toyota Tundra
    LED lighting, back up camera, 2021 Tacoma TRD wheels
    I recently purchased a BigTex dump trailer. Unloaded it weighs around 2,500 lbs. so when it's loaded with rock it will be a nice, heavy load so I need a brake controller on my 2002.
    Has anyone done this? Any suggestions on a controller and advice on installation? Is it easy to do yourself or should I have a shop do it?
  2. Feb 7, 2022 at 7:12 PM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    Any chance your truck has the factory tow package? If so it’s pre-wired for a brake controller, if not you’ll need to run a few wires to the controller location and to the hitch and change the plug for the trailer hookup to a 7 pin plug.
    I have a Tekonsha Prodigy controller, I had it in my T100, worked fine, I haven’t used it with the Tundra yet, but worked fine in the T and had good reviews.
    KNABORES and savagefen[OP] like this.
  3. Feb 8, 2022 at 11:00 AM
    savagefen
    Jon
    2002 Toyota Tundra
    Thanks for the info! I got the 7 pin already but never thought about it being pre-wired for a brake controller.
  4. Feb 8, 2022 at 11:04 AM
    1stgentundradriver
    1stgentundradriver Each sticker adds at least 5hp
    Josh
    Silverdale Washington
    2006 DC 4x4 Limited
    A few
    Go on YouTube and look for brake co trollers on 1st Gen tundras. eTrailer has a lot for our trucks. Mine is prewired and I bought a plug and a controller and it works great! Curt discovery or something like that.
    savagefen[OP] likes this.
  5. Feb 8, 2022 at 11:13 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Tekonsha P3 is the best I know of for the $. Used them on a few vehicles and they are one of the best.
    KNABORES and tvpierce like this.
  6. Feb 8, 2022 at 11:24 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Crawl under the rear of your truck and see where the wires go. In addition to the turn signal and brake wires (which are probably wired to a 4-pin connector) there should be two beefy wires (or 1 beefy cable with 2 conductors in it) that go to the front of the truck -- one for line is for brake control, the other is for constant 12V.
    savagefen[QUOTED][OP] likes this.
  7. Feb 8, 2022 at 11:32 AM
    PenderBen
    2003 Tundra AC 4x4
    My truck has the tow package so came pre-wired, it has a plug under the dash for the controller and came with a harness that plugs in to it with pigtails to wire up to the controller of your choice. If you’re lucky the harness with pigtail is kicking around in your truck somewhere, I found mine in the glovebox.
  8. Feb 8, 2022 at 1:14 PM
    ezdog
    ezdog New Member
    Gateway To The West
    2001 RCLB V8,4WD 2015 RCLB 5.7,4WD
    P3 here too,nothing bad that I have ever read about them at all!
    Like has already been said check to see if your 7 pin is already connected and has voltage on the charge line and either wire it up or pay someone else too depending on your skills.
  9. Feb 8, 2022 at 2:37 PM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
  10. Feb 8, 2022 at 3:31 PM
    I had a friend who works at an RV shop install mine on my 2000. Towed a 28' TT that weighed around 7k pounds. Quite a bit of wiring involved if yours isn't pre-wired. Not rocket surgery but enough of a pain that I would consider having someone else do the install again if needed. Some new fuse blocks under the hood. Power wires run along the frame to the back of the truck. Some wires run up into the cab, mounting and adjusting the brake controller properly.
