Best tune for heavy towing
Discussion in 'Performance and Tuning' started by Everything G3 n Yota, Feb 6, 2022.
  1. Feb 6, 2022 at 7:27 PM
    Everything G3 n Yota [OP] New Member
    Kevin
    2015 super white tundra ltd double cab
    Firestone air bags. DS grab handle. Toyo 10 ply tires
    Hello all, new to the forum, lots of great people/info here! Have a 2015 tundra ltd 5.7, and towing a 28 ft 5th wheel half tonner. Tows good, but when I put the fishing boat behind, could use more power in the hills. Love this truck ,it tows better than any other trucks I've had other than a diesel ton truck. But with cost of fuel, maintenance, etc. I just can't make a diesel pay for itself (and don't like all the new emissions, I'm old school I guess). Really just looking mainly for better transmission control and gear lock capabilities , as gear hunting is a pet-peave of mine,lol.
    -OVT sounds great. Like the shifting capabilities. Where do I buy? Is it plug and play I'm not real computer savvy, definitely not a tuner myself! Website alone is confusing. Any OVT experience anyone?
    -DAP ? Sounds good on their website, not a real good of description of benefits other than normal hp gains.
    ...Even for daily driving, I dislike the constant torque converter unlocking everytime you give it just a little more throttle while cruising.
    ... Would like to be able to lock in chosen gear, not just have a gear limit is "S" mode, I find it sort of meaningless in stock form.
    Any input would be great , thanks in advance!
  2. Feb 6, 2022 at 7:33 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Get the vftuner, or Bullydog.
    Vf is the ultimate solution. more $$ and harder to install, but worth it.
    on a budget, bulludog specifically makes a rune for towing. It’s inexpensive, works well, and is relatively easy to install.
  3. Feb 6, 2022 at 7:38 PM
    Kevin
    Thanks dirty deeds, I will look at the bulldog. I like simple... The OVT sounds great, but it doesn't sound like plug and play, and I'm not a tuner myself. Thanks again ,I now have some research to do!
  4. Feb 6, 2022 at 8:40 PM
    dirtydeeds
    Keith
    USA
    Gimme a call with any questions. And to order a Bullydog. 760-877-4234
    cowboyjack likes this.
  5. Feb 6, 2022 at 10:15 PM
    I would suggest a 3/4 or 1 ton tune. You can purchase it at any Ram/Ford/GM dealership, no downloading and you will find the towing experience is greatly improved.
    Pulling doubles with a half ton....
    Thankfully you live on flat land.
  6. Feb 7, 2022 at 5:31 PM
    Kevin
    Lol! I know. But two things in my favor: I'm right within the towing capacity of the tundra , and I have been towing heavy equipment my whole life.... Yes I know a lot of people personally that should not be allowed to tow one trailer much less two hahaha. Two...if you have ever mechanically worked on or seen how the other half ton trucks are built(especially Chevys,drove them my whole life before switched to toyota) ,,,,,, you could understand why I will only do it with a tundra. There is a reason why many forums say the tundra is built heavier than some of the other 3/4 ton trucks. The brakes alone are much bigger than most other 3/4 tonners.
    That being said, it is not for the inexperienced tow personell. Firestone air bags also make the truck sooo much more stable; benefits more for the left right swaying than the rear end sagging. Not to knock other brands, but try putting a couple 50 pound bags of sand , softener salt , etc in the back of a new ram with the coil suspension... That truck sways so bad its dangerous. The company I worked for bought a whole fleet of them for the salesmen. They were scared to drive them with any payload In the back. We put firestone air bags on them and it made them a totally different truck!!!! Actually loved the ram after that, has many more amenities than my tundra. Wished tundra would step up in that area compared to the big three.
    P.s. we could not find any shop to install the air bags on the 1500 rams. They sold them to us but would not install. Apparently dodge holds licensed shops liable for any accident if overloaded. No shop would tell us exactly why but, it was a very touchy subject with every shop we went to. Ended up installing them ourselves. Shame , they are a great truck once they are slightly enhanced. Thanks and any suggestions to help beef the tundra more greatly appreciated.
  7. Feb 7, 2022 at 5:38 PM
    Kevin
    Also TJ, we are along the Mississippi river between Iowa and Wisconsin, it's a lot of hills!!!! Can't believe how this tows in "beast" mode. Just wish I had better gear selection control. And so far, I've gotten better mpg than the diesels in our group. But they walk away from me in the steep hills.so much more torque with a diesel.
  8. Feb 7, 2022 at 6:44 PM
    art64
    art64 New Member
    I have VF Tuner with Direct Shift and Gear Lock. The best feature in my opinion. You can use most of the torque available for that gear i.e. 6th gear, 5th gear before you down shift. There's a safety low RPM limit of 1500. If the RPM falls below 1500 and you did not manually downshift, then, the ecu will take over and downshift the transmission.
    You can go the VF Tuner website and check their products or you can find a VF Tuner authorized Pro Tuners in your area and they can load the tune for you. This is probably the fastest route cause they already have the laptop registered, they get updates regularly. They just need to buy credit for your VIN, the cost of the tune pack and of course, the shop will charge you for their service.
  9. Feb 7, 2022 at 7:02 PM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    As the owner of a tundra powerstroke and duramax…and recently traded Cummins…try again!
    My power stroke gets better mpg towing a 13k pound trailer than the tundra gets empty. Hand calculated repeatedly. The duramax is in constant regen so towing is comparable to the tundra empty. All three trucks have 35” tires with stock gearing and stock tunes.
  10. Feb 7, 2022 at 7:58 PM
    Kevin
    Seriously,it ain't by much, but 2mpg better than the 6.0 power stroke, and .5 better than the 2005 Duramax. I'm sure the newer ones may be better, and also with an tune they probly would reverse scenario. But stock its still alot better than you would think. No one in the group has a Cummins. I'm sure the 5.9 would probly walk circles around all of us. Mileage wise too.... Inlaw just traded Duramax in for newer gasser, he is not happy with it after coming from the diesel.
    Too bad tundra never put in the hino diesel. When they built the plant in Texas, it was supposed to roll out dually's too, until the big three stepped in...... Thats a whole nuther thread for discussion.lol
  11. Feb 7, 2022 at 8:04 PM
    Kevin
    20210916_073847.jpg the boat+trailer actually weighs only 2700 package weight. But still can feel it behind the tundra with the camper!!!!
  12. Feb 7, 2022 at 8:05 PM
    2mchfun
    I don't care to argue on your towing capacity, but as for pulling hills and such, have you considered 5.29 diff gears? That would certainly help with gear hunting.
  13. Feb 7, 2022 at 8:10 PM
    2mchfun
    :monocle:
    BuckWallace likes this.
  14. Feb 7, 2022 at 8:13 PM
    ScenicRoute
    Pretty cool. I’m surprised the camper frame is capable of a tow rating. A bike rack maybe but a trailer?
  15. Feb 7, 2022 at 8:15 PM
    Kevin
    I have, but most of the time this truck is my daily driver. I am also working on an international 4700 truck that I bought with a coolant issue on the dt466 diesel. When I get the overhaul complete I'm hoping to shorten the frame and possibly use that on the long trips, just for fun. And yes no sense arguing mpg's. I also have driven them all. I only go by penciling it out at the pump. Some trucks ive driven were so far off it should have been illegal to display it.hahahaha. dealers all blame it on break it time. To each his own is all I have to say. More than anything I want the reliability, that far outweighs anything else in my book.
  16. Feb 7, 2022 at 8:18 PM
    Kevin
    Bought camper from family.mhe actually towed and 18 foot. The rear structure is actually very well built compared to many others I've seen. Rest of the structure is aluminum. Only one slide out, so it's not as heavy as many newer half tonner campers.
  17. Feb 7, 2022 at 8:21 PM
    2mchfun
    Daily driver?? Hell yeah, 5.29's means daily good times! :thumbsup:
    Retired...finally likes this.
  18. Feb 7, 2022 at 8:25 PM
    Kevin
    mileage would have to to go down wouldn't it?? I know tundra and mileage don't go together, but fuel is sooo high right now.
    Me driving= 14.5 mpg
    Wife = 19 ... Don't ask me how, just doesn't sound as fun though!
  19. Feb 7, 2022 at 8:30 PM
    2mchfun
    Not as much as you might think because the engine doesn't get "loaded" much. There is a slight increase in RPM's but this is a DOHC v8, born to rev a bit. I'd research the benefits at the very least.
  20. Feb 7, 2022 at 11:23 PM
    You might be right in the maximum limit. I would have to see the CAT scale slips and the door sticker to be sure.
    Since I have nothing to do and...why not....
    I have came to the conclusion that a lot of my words on here go to deaf ears. If you look in our towing section we have some pretty good stickied threads. Not sure I have made much of a difference. I do admit that I have probably helped 40-50 members (at least) into bigger trucks and why that was a good idea. Most of them already knew it was a good idea and just had some simple questions. Most of them are still on here and active members.
    So let's hit the numbers shall we?
    Your 2015 Limited DC specs, off the Toyota website but your door sticker is the final say:
    9900 lbs tow rating
    16000 lbs combined tow rating
    7100 gross vehicle weight rating
    ~1425 lbs payload (hopefully higher)
    You have a Cruiser Aire fifth wheel. Pretty nice camper if I don't say so myself.
    Specs:
    I'm just going to assume you have a typical non-sliding 5th wheel hitch. Those are around 100 lbs.
    1425-100=1325 lbs left for your capacity
    1325-1250 pin/hitch weight empty= 75 lbs left
    Now you and the wife/girlfriend (or both) jump into the cab. Now I'm going to be nice and say everyone has an average weight of 150 lbs or 450 lbs total.
    75-450= -375 lbs. We haven't even loaded the trailer yet.
    Now let's get to the trailer. The pin weight is 18% of the weight of the trailer (6950x.18=1251 lbs) Little light for 5th/GN towing but hey, how else are these manufactures going to get away with "1/2 ton towing"? Depending on what GN trailer I take, 20-22% pin weight.
    I'm just going to make another assumption that you tow dry (hopefully) and don't do dispersed camping. To go out for a weekend, but no longer than a week....supplies probably are going to rack up to 800-1000 lbs (food, drinks, bottled water, clothes, supplies/propane, toiletries). That's what it averaged out for myself and my family. I also found out the dry weight wasn't with options like A/C and upgraded items. So let's add that up into the equation:
    6948+1000=7948 lbs
    7948x.18=1430.6 lbs. So the hitch weight went up a tad there. So another 180 lbs in the hole or -555 lbs. Hope you don't like campfires and take wood.
    Now besides being overweight on the capacity, let's dive into the rest. Not sure what your rear axle empty weight is, but I assume it is still under the maximum axle rating of 4150 lbs. A small portion of the weight is transferred to the front axle as well.
    Truck weight is around 5600 lbs. 1430 pin weight, 450 for occupants, 100 for hitch=1980 lbs. That means you are over on GVWR as well at 7580 lbs. Here is some good news. You are still within the GCWR at 13648 lbs....until we hook the boat.
    The boat looks like a Lund or some kind of fishing boat (I want). So the axle looks to be 3200 lbs, so maximum trailer/boat weight has to be under that. Call it 3000 lbs due to adding a class 3 hitch on the rear of the camper with supports. That will take you over the GCWR of 16000 lbs.
    Good thing is you are not doing this with your Tundra:
  21. Feb 8, 2022 at 12:51 AM
    I had to split this up a bit so one post didn't flood the thread. I'm not sure why people compare any 1/2 ton to a domestic 3/4-1 ton truck. Keep in mind you are towing with the same drivetrain from 2007. Well, that's not totally true. If you had a 2019-2021 the front mounted transmission cooler was removed and replaced with a different system. Seems to work for most people that are not towing max/overloaded. Otherwise the same strong 1/2 ton drivetrain. I loved my 2012 CM Tundra. Towed and worked the hell out of it. It started showing signs that maybe I should be buying something else around 60K miles. By 89K miles it was gone before I needed to sink some serious repair money into it.
    No secret here, I have a 2016 GMC 3500HD SRW truck. This 5 year old truck is leap years behind current technology and towing experience. That's crazy right? 5 years isn't that long right? Well not in the HD truck market. Next year the Duramax is coming out with 505 HP and 1085 pound feet of torque. I'm sure Ford and Ram will try and one up that. I've done a few things to my current truck to make it more dependable in the long term (almost 75K miles now without serious problems) and keep up with the L5P trucks in the 2017-2019 years. 2020 and newer....I can't even come close without spending some serious money and risk reliability. I'm probably at 445HP and close to 9-930 # ft tq. Respectable, but I can't keep up with the 10 speed transmissions of today. Hell, even my buddies 2021 Ford F350 Tremor with the 7.3L/10 speed will give diesels a run for the money.
    https://www.tundras.com/threads/5-years-of-hd-gm-diesel-ownership-cost.100998/#post-2585200
    Differences in your 2015 vs my 2016 trucks:
    -Frame is definitely a huge difference.
    -Brakes are a big difference. The Tundra has good brakes for what it's designed to do....but they don't look like this:
    Hell, my 2002 Dodge 2500 had better/bigger brakes. We would have to get into the 90's trucks to compare brakes (mid 90's Dodge 3/4 ton brakes were a joke).
    Since we are on the topic of brakes, the tundra has some grade braking capabilities but nothing like HD trucks. In the event a diesel option is purchased, the exhaust brake is amazing. Check out the link I put in about 5 years of diesel ownership. At this rate, I might not have to change brakes until the truck is 10 years old or 120+K miles.
    -Axle ratings. There just isn't a comparison. My buddies F350 tremor can almost put a Tundra in the bed weight wise. Dually...definitely. My truck is reduced due to diesel and having certain packages. Still 2.5x the capacity.
    -Transmission. I'm going to give Toyota a pass on this. Anyone that says Aisan isn't a good HD trans really is just talking out their ass.
    -Motor. Another pass. In 2016, the 6.0L offered in the GM HD truck was lacking. Diesel...not so much.
    -Fuel economy. My Tundra with 8K lbs behind it would do 6-9 mpg. Not bad actually since a lot of the reduced fuel economy was at over 9K feet of elevation. At 25K lbs I still get 11+ mpg. So tripple the weight and still getting better fuel economy. I just don't see the argument here. Even the guys with gas powered GM/Ford/Rams are doing pretty good in this department. You can ask any of the guys I have talked with about diesel vs gas and what I recommend. Gas every time unless they have a big trailer and tow often.
    Anything else we should compare? Think that pretty much covers it.
    This isn't supposed to be discouraging for Tundra owners. I have made the same mistakes in the past and had to remedy them with a bigger truck. Is the Tundra a tow rig? Hell yes it is....and a damn fine one within the safe limits it was designed to do.
  22. Feb 8, 2022 at 1:01 AM
    Last section:
    I can almost guarantee you will not run out and buy a different truck or trailer on the sole recommendation from this guy. If you want more ass and towing performance I would look into what @dirtydeeds has to offer. Bang for your dollar, long tube headers, full exhaust, and tune should really improve what you have. If you really want to go "full in", a set of gears for towing performance would do wonders for you...even some 4.88's. That would be some very noticeable towing performance.
    Down side to this is the cost unless you can perform all of these tasks. Most people can install some long tube headers in a day with some cussing and beer, gears will be a weekend, and depending on how savy you are with electronics a tune can be installed rather quickly.
    I had to make the decision to keep my Tundra, get a SuperCharger, LT headers, big brake kit, etc for a pretty large cost (around 10K). Instead of doing that I used the incredible resale value that Toyota has, saved my 10K and put that towards a bigger truck. In the end, had I stuck with the Tundra and spent the money...still have a fast overweight tow rig.
    There are a lot of people with tons of towing experience. This does account for something for sure. What it doesn't account for is complacency. In my life, all the work related deaths and injuries were one of two groups:
    -Young men lacking experience, but eager and didn't have seasoned experienced personnel on site...you know...the grumpy old farts that would always talk about the "old days..."
    -Older, very experienced journeyman level techs that were just a couple years away from retirement.
    Out of these two groups, I have seen two young men electrocuted to death and burn and surprisingly three older men die due to complacency. The last one was just the worst luck I have ever seen. That still haunts me from time to time seeing someone pinned in a vehicle and burning to death. When you get comfortable and it doesn't concern/scare you anymore...better take a step back. This is from 1997 to 2019. Six human lives. I didn't even lose that many in the Iraq war.
    I'm now that "old guy preaching" and have to check myself from time to time...especially towing. It's hard. I know my truck can tow way over what I'm rated at. Last year I had a landscaping yard take material off my trailer since I was overloaded. We were only around 4 miles from home (neighbor across the street). Could we have made it? Most likely. Could we have not....possibly. I don't want to be responsible for changing anyones quality of life due to my poor decisions.
  23. Feb 8, 2022 at 3:30 AM
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    If you want to keep the Tundra go with @dirtydeeds recommendations.
    However, and I have owned 2 tundras, they are not the same as a 3/4 or 1 ton. Are they heavier built than the other 1/2 tons? Good god yes. There is not argument from me that the tundra is the best half ton on the market. But when you start putting 5th wheels and towing GN trailers you are really in the 3/4 ton range. And honestly I tell most people to skip the 3/4 ton and go right to a 1 ton. Stability is key and I have towed way over my limit in the tundra. I need purchased Road Master Active suspension to level out the rear.
    That set up is just shy of 11k. Tundra pulled it just fine, but stability in the rear end was not there. Now the exact same setup with my 1 ton gasser.
    Both trucks look leveled and capable, but they aren’t even in the same category. My GMC makes this setup feel effortless.
    Personally I would look at getting a 1 ton. I paid $47k for mine and I half 4300lbs of payload.
  24. Feb 8, 2022 at 5:59 AM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    2022 GMC Sierra AT4 L5P - 2017 4runner SR5P - 2023 Tesla Model 3 LR
    I'm just glad someone did the math for me. :)
    Lake.Life24 and ColoradoTJ like this.
  25. Feb 8, 2022 at 6:01 AM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    That GMC is a beautiful truck!
    We don't tow really heavy loads, but a 4600 lb travel trailer with a hitch weight of 550 lbs, WDH hitch, bikes in the bed, 3 teenagers, and a 25 lb dog put us at 1500 lbs. Our 14' crew max had a payload of 1350 so we were over but the Tundra still towed fine. I believe those numbers were okay because even though we were technically over, the numbers were relatively low. But our kids will continue to grow and we are looking to go with a slightly bigger trailer. So I waited around to see if the 22 Tundra would have better payload and even put down a deposit based on the early numbers released by Toyota. Sadly, the reality was that payload increased 100 - 200 lbs max.
    So I was left with some decisions to make. The truck is my wife's daily and a 3/4 or 1 Ton was just too much truck for her. We went with a new Titan XD in Pro 4x trim. It has a payload just shy of 2000 lbs, which gives us a nice cushion and will allow us to get a slightly bigger trailer with 300 or 400 lbs more hitch weight and stay within the payload and towing limits. I would have felt better with a 3/4 ton and 2500 lbs + payload, but it is too much truck for us for the 95% of the time we are not towing our camper.
  26. Feb 8, 2022 at 6:06 AM
    Backslider
    Tooele, UT
    The reason I bought a 1 ton truck is because I wanted the ability to tow a large camper, dump trailer, and potentially double tow the camper + a boat.
    I went with a 1 ton instead of a 3/4 ton so that I would have a comfortable buffer.
    I'm on of those people who only likes living on the edge when it comes to my sex life and my diet.
    I maxed my Tundra out a few times when I was doing my yard and was honestly surprised at how well it did from a power perspective, but not surprised enough that I wanted to do that for long trips in and through Utah.
    ColoradoTJ likes this.
  27. Feb 8, 2022 at 8:09 AM
    Lake.Life24
    Shawn
    Upstate, NY
    Love the Nissans. And just for reference I daily drive my 1 ton. The GMC independent front suspension makes it very smooth for a HD truck. I bought mine at the end of April and right now I have 26,273 miles on it. So if you ever have to go with the 3/4 or 1 ton my first stop would be a GM dealer.
    Best towing performance Ford 7.3l
    Nightshade Tundra and ColoradoTJ like this.
  28. Feb 8, 2022 at 11:14 AM
    gdiep
    Syracuse, New York
    Shawn - where in upstate are you? I'm in Baldwinsville just west of Syracuse. I was inches from buying a Chevy/GM 3/4 ton. But it's a little too much truck for my wife who would be the daily driver and way too much for me because I work downtown and have to park in a parking garage.
  29. Feb 8, 2022 at 11:41 AM
    Lake.Life24
    Shawn
    Upstate, NY
    Awesome! I’m just west of Binghamton in the Corning/Elmira area. And you are right. There is no way you are finding a parking spot. No lift and I don’t fit in most parking garages
