  1. Feb 8, 2022 at 7:56 AM
    daveeasa
    I do think that auto spare raise / lower would be a neat product. It does not seem complicated nor expensive. Just a matter of selecting mounting options for specific vehicles off a universal design and a variety of adaptors to fit the plate.
    RUSTYNUTS and chrisb like this.
  2. Feb 8, 2022 at 8:02 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    Something else to consider is that if the elevator is motorized, it'll get exercised more often and that will help with rusting/seizing.
    It's a great idea.
    Tundra2 and daveeasa[QUOTED] like this.
  3. Feb 8, 2022 at 10:52 AM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    your jack crank is 1 piece? Thats gotta be an RC thing, mine is 3 piece.
    oscardog86 and Tundra2 like this.
  4. Feb 8, 2022 at 11:02 AM
    daveeasa
    yeah, great shop tool. A bit of overkill for on the road but still cool. I’d maybe buy another one if I could find one easy.
    oscardog86 and Sirfive[QUOTED] like this.
  5. Feb 8, 2022 at 11:06 AM
    NWPirate
    Zach
    WA
    Interesting, how does that work for lowering your spare tire then?
  6. Feb 8, 2022 at 11:09 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    4 piece!
    I think the sequoias was tubing with square ends. These are solid.
  7. Feb 8, 2022 at 11:11 AM
    daveeasa
    Shove it in the hole, I mean, I guess instructions could have helped but once you do it a few times you figure it out, right?
    Maybe you were asking about the security lock piece? I do have one of those on the Tacoma, however it "fell off" last time DT messed with it. So now both trucks have a slot and the hook fits into the slot.
    I might do some sort of aux lock if I get my 285 wheel under the Tundra since that's worth some real $. The Tacoma spare is an alloy but I could survive if it were stolen.
  8. Feb 8, 2022 at 11:12 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    #universaltruth
    RUSTYNUTS, Darkness, CodyP and 6 others like this.
  9. Feb 8, 2022 at 11:15 AM
    NWPirate
    Zach
    WA
    You have a slotted hole, copy that. :thumbsup:
    RUSTYNUTS and daveeasa[QUOTED] like this.
  10. Feb 8, 2022 at 11:18 AM
    oscardog86
    oscardog86 New Member
    Southern California
    Damn I wish mine was a single piece. Mine 3 or 4 piece version is annoying. They are always falling apart as I use it. Atleast I dont use it very often. Maybe I should weld mine into 1 piece? I always like having a welding project to do so I can get more practice, haha
    NUDRAT, chrisb and daveeasa[QUOTED] like this.
  11. Feb 8, 2022 at 11:20 AM
    Casper421
    In the woods
    06 DC
    Thick bike lock through the wheel and around the frame keeps thieves away from mine. Why don’t you think you’ll be able to fit a 285 in the factory location? My 285/75 “fits”. Is it a RC thing?
    Darkness, chrisb and oscardog86 like this.
  12. Feb 8, 2022 at 11:20 AM
    Yup, this is what mine is also. And the sleeve it comes in is shaped almost like a pistol case, but for some Dirty Hairy jumbo mag44 sized shit.
    NWPirate, Darkness and oscardog86 like this.
  13. Feb 8, 2022 at 11:23 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Not wrong.
  14. Feb 8, 2022 at 11:26 AM
    Dang. Slowly creeping toward page 1-2-69.
    bmf4069 likes this.
  15. Feb 8, 2022 at 11:28 AM
    daveeasa
    I'm hopeful. Friends said it's a no go on 3rd gen Taco but you and Dan and others say it'll be good on the Tundra. Hopefully no extra trouble from my rear bumper either, I think that's far enough away. Not sure if I'll have to re-route the exhaust.
    I was thinking more about power raise/lower, now I'm wondering if a hinge and strut could potentially be sick, with two points of attachment it might be possible to keep the wheel on top of a tray while it rotates down and out to the side, then lock it in place with a pin/padlock on the frame rail. It'd be fun to see how far I could get trying to prototype something like that.
    NUDRAT likes this.
  16. Feb 8, 2022 at 11:42 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
  17. Feb 8, 2022 at 11:45 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    33 (285 variant) will fit under the bed as long as your exhaust is stock. If your exhaust has been modified you might have clearance trouble like me.
    oscardog86 and chrisb like this.
  18. Feb 8, 2022 at 11:48 AM
    daveeasa
    I'm also not certain about wanting to use a bike lock. I'd proably pre
    Thanks for explaining. I was worried I would have to mod the exhaust. I may be in luck, I'm scared to death of anything exhaust related, I have nightmares of CHP with their boots on my head grinding my teeth on the asphalt if they caught me with a modified exhaust... :)
    bmf4069 likes this.
  19. Feb 8, 2022 at 11:50 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I used a thick bike lock for years on my spare. Its from Schlagueueuue (good luck spelling it). Somebody tried cutting it and failed while I lived in LA.
    bmf4069, KK6PD and chrisb like this.
  20. Feb 8, 2022 at 11:50 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    You and @Darkness are welcome to come to IN and go full send on any truck mod you want.
    With the difference in cost of housing, you can probably afford to build your truck as full prerunners and still drive those things on the street legally.
  21. Feb 8, 2022 at 11:52 AM
    daveeasa
    I'm worried more about trashing the wheel since I overpayed for a 5th faux beadlock b/c I'm a moron and I like to waste money on stupid stuff :)
    chrisb and Darkness[QUOTED] like this.
  22. Feb 8, 2022 at 11:53 AM
    daveeasa
    If I make a tour it'll be to shovel snow, my hands need gloves when it's under 50 degrees and I can't work on trucks below 45 without whining.
    bmf4069, NUDRAT, Tundra2 and 2 others like this.
  23. Feb 8, 2022 at 11:55 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I was once pulled over for driving too fast in a residential, it was early morning and nobody was out except me and a cop.
    While he was writing the ticket he mentioned "you know your tint is illegal?"
    Oh, is it? I asked them to go mild.
    "You know your exhaust is probably exceeding the permitted decibles too?"
    Oh, its quiet in the truck, I've never heard it from outside.
    "It sounds pretty damn good to me, but probably illegal. We won't mention it."
    He also wrote a lower speed on my ticket so I wouldn't catch a reckless. Some cops are really cool guys.
    empty_lord, bmf4069, KK6PD and 6 others like this.
  24. Feb 8, 2022 at 12:00 PM
    daveeasa
    I was literally pulled over on the 5 in Carlsbad and given a ticket for window tint. In the 2002 Tundra, sometime in the 2005-2009 range. No other reason, not speeding, no passengers, not doing anything fun or interesting at all. It was eye opening.
    I did find a friend with a husband who was able to sign off on the fixit without forcing me to scrape, back when anyone could sign off on those. The same tint is still on those windows.
    I think they've gone softer since then or maybe I just got really unlucky that day.
    bmf4069 likes this.
  25. Feb 8, 2022 at 12:01 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    needs a spring latch so it can rest at TDC. Spares are heavy, and i think the loads of harder bounces would strip the teeth if left at an angle.
  26. Feb 8, 2022 at 12:08 PM
    daveeasa
    Yeah, def lock flat / parallel to frame rails, maybe use bump stops and some wedge latch to compress against the bump stop when locked in place.
    Total freaking overkill and extra weight though. But has some potential for a purely mechanical device.
  27. Feb 8, 2022 at 12:17 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    If you ever make it to Indiana and don't make a detour to come see me or at least agree to meet in the middle... so help me God lol :rofl:
    Just busting yer chops.
    Anyways, spare tire rod? Ain't got one for crackie. Not fancy like that, but crackie doesn't have a spare under it anyways.
    The V6 is a three?? Piece. Might be four. Pops and I used it when we were in E-town at that damned Hardee's before he had his big rear end blowout. :D
  28. Feb 8, 2022 at 12:27 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    New backburner project. Gonna make a sleeve to tighten the jack bits to a 3/8” drive.
    about to have to buy a kit of battery powered cordless tools like those kids whos arms hurt when they flex. And if i can power run my jack and spare with a milwaukee or whatever, i’ll be the coolest guy in the parking lot.
    edit:
    Walked into tractor supply and home depot. Looked at cordless tool prices, and battery prices and took a big fat nope. Right there in the aisle. At 9am, with like 5 old men telling some poor guy which box they needed a ladder for. All talking over at each other, and i let out a serious ‘what the fuck!?!’. Then wandered down to the angle grinder section and bought the cheapest one in stock. And some good wheels.
    NUDRAT, shifty` and oscardog86 like this.
  29. Feb 8, 2022 at 1:08 PM
    Damn. That looks like it takes a musket ball. lol
    Tundra2 likes this.
  30. Feb 8, 2022 at 1:10 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Mini-vall?
