High Nox emissions, won’t pass
Discussion in '1st Gen Tundras (2000-2006)' started by Celifis72, Feb 7, 2022.
  1. Feb 7, 2022 at 5:49 AM
    Celifis72
    Celifis72 [OP] New Member
    02 Tundra /93 Sc400
    Having issues with 02 2uz-fe not passing Nox emissions. Can’t find EGR valve to check it. Does this motor not have EGR? Also my temp gauge pops to middle as soon as the engine is started, no gradual rise in temp at all, Very odd!!!
  2. Feb 7, 2022 at 8:26 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Are they giving any other info, check engine light, code pending, not passing a readiness monitor ? Cleaned throttle body and/or MAF sensor lately ?
  3. Feb 7, 2022 at 8:30 AM
    Celifis72
    02 Tundra /93 Sc400
    No check engine codes at all
  4. Feb 7, 2022 at 10:03 AM
    Celifis72
    02 Tundra /93 Sc400
    ? Sniffer test? I have put intake clean in the tank and might do a sea foam spray into the manifold to clean the valves and carbon buildup
  5. Feb 7, 2022 at 10:05 AM
    And you're sure someone didn't just remove the check engine light bulb, and it's not burnt out? Like, you actually had it checked for codes?
    I had a buddy in high school whose motor was clearly about to shit all over itself. Like, clearly it wasn't running right, and it was an OBDII car, so he could've just checked before it got too far along. Took him to the parts store to have it scanned for free. Laundry list about 14 codes long came out.
    "Didn't you see a check engine light?!?!!"
    "Yeah, but the car was running OK when it came on, so I pulled the bulb because it was too bright at night..."
    :boom:
    What could've been a $75 fix ended with him selling the car because he couldn't afford to replace the engine.
    5N0W808 likes this.
  6. Feb 7, 2022 at 10:06 AM
    Celifis72
    02 Tundra /93 Sc400
    I see the light when I turn on ignition, put my scanner on and didn’t find any stored or waiting codes.
    5N0W808 likes this.
  7. Feb 7, 2022 at 10:12 AM
    Weird. I mean, I'd replace the temp sensor, clearly it's failed if it goes straight to center. Not an uncommon thing for those to do on fail (stick high/stick middle/stick low).
    Half tank of 93 octane and a full bottle of SeaFoam followed by several short 5-10 mile trips where the truck sits for 10-30 minutes between runs should clean out things internally. Don't necessarily need to shoot anything into the intake.
    Any more details on what "nox" testing is, though?
  8. Feb 7, 2022 at 10:38 AM
    Celifis72
    02 Tundra /93 Sc400
  9. Feb 7, 2022 at 10:41 AM
    Celifis72
    02 Tundra /93 Sc400
    Anyone know if there is a EGR valve on this engine? All the pics I can find don’t have what my engine bay look like444B5710-818E-435C-853C-874E4E5836BC.jpg
  10. Feb 7, 2022 at 10:43 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Do you know how badly out of range the fail is?
  11. Feb 7, 2022 at 10:45 AM
    Celifis72
    02 Tundra /93 Sc400
    Barely a point. Last time the limit was 2.0, this year it went down to 1.6 and the truck is coming in at 2.3
  12. Feb 7, 2022 at 10:46 AM
    Celifis72
    02 Tundra /93 Sc400
  13. Feb 7, 2022 at 10:51 AM
    MadMaxCanon
    hmm, its not SUPER close, I was thinking if its only a bit, running a can of seafoam or something similar may get it down a hair.
    Celifis72[OP] likes this.
  14. Feb 7, 2022 at 11:26 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Check for small cracks in the vacuum lines. Or even a small intake leak thats not quite enough to trigger a CEL (check your long term fuel trim).
    Also are the front 02 sensors original? May be good to check their response to see if they're starting to go.
  15. Feb 7, 2022 at 11:36 AM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    From over at ih8mud forum.
  16. Feb 7, 2022 at 12:38 PM
    Celifis72
    02 Tundra /93 Sc400
    Thank you, I’ll check all the hoses along with the O2 sensors take them out clean them but I’m not getting any codes which is really strange.
  17. Feb 7, 2022 at 8:32 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    If you're gonna pull the upstream O2 sensors you might as well just do new ones.
    Denso (OE manufacturer) on RA for about $40 each
    https://www.rockauto.com/en/moreinfo.php?pk=991966&cc=1389001&pt=5132
    Seeing posts like this remind me of how much I really like not having to deal with emissions testing of any kind. Good luck!
    Celifis72[QUOTED][OP] likes this.
  18. Feb 7, 2022 at 9:23 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    while its cold if you bang on the cat with bottom fist palm method does it make noise?
  19. Feb 8, 2022 at 6:08 AM
    Someone's whipping out that PHM BDE, cracking the ancient scripture of tactical hand maneuvers!
  20. Jun 30, 2024 at 11:33 PM
    Monz
    Monz New Member
    2001 Tundra
    Bilstein 5100's
    What was the conclusion on this? I'm having a near identical issue.
  21. Jul 1, 2024 at 5:23 AM
