Led fog adapters
Discussion in '1st Gen Tundras (2000-2006)' started by Jbhoops, Feb 6, 2022.
  1. Feb 6, 2022 at 2:15 PM
    Jbhoops
    Jbhoops [OP] New Member
    2001 tundra access cab
  2. Feb 6, 2022 at 4:41 PM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    I would look at the style of harness for the factory bulb plug in. I don't think that's an "adapter". More part of a kit. Maybe try calling them. When I ordered my harness and relays for headlight retrofit I used TRS (the retrofit source) and I had some questions. They were very helpful. May try them
  3. Feb 6, 2022 at 5:23 PM
    Jbhoops
    Thanks.I will
  4. Feb 6, 2022 at 8:23 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    If you're trying to go all LED for headlights and fog lights and you're worried about them acting funny you can get a plug and play adapter that plugs inline with your dash mounted fog light switch and fixes the issues without having to run super hot resistor packs that put extra load on your electrical system. That is if @daveeasa wants to/has time to keep making more.
  5. Feb 6, 2022 at 9:32 PM
    daveeasa
    I gave them an official spot on then board. Fbchs.square.site
  6. Feb 6, 2022 at 10:05 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Looks to me like you just want to replace stock foglights with LEDs.
    You don't need resistors.
    Resistors are for turn signals, they stop hyper flash.
    It all depends on what the connector is on your LED fog light.
    Or if you don't mind cutting and splicing (solder or crimp), you don't need a connector.
    I used to make adapters for 2014 and up, they were H11 to Deutsch connectors for Rigid foglights.
    I think your 2001 is a different size than H11.
    234016AF-1142-44F3-BE2C-CBD1E7894B24_zps_5f2e030ce4cc92d424d8bf229012982ed49859ca.jpg
  7. Feb 6, 2022 at 10:22 PM
    Jbhoops
    Stock bulbs are 9006. I believe leds are h4. What adapters would I need
  8. Feb 6, 2022 at 10:25 PM
    NickB_01TRD
    KY
    Can't you just get the LED equivalent to 9006 that would fit without having to change anything?
    1lowlife likes this.
  9. Feb 6, 2022 at 10:33 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    Sorry, I thought you were replacing the entire light, not just the bulb..
    There are several 9006 to H4 wiring adapters on Amazon and ebay.
    I never heard of a physical socket adapter if you need one.
    Amazon.com : 9006 to h4
    9006 to h4 | eBay
