The S.S. TRDFerguson: Captain’s Log
Discussion in '2.5 Gen Builds (2014-2021)' started by TRDFerguson, Mar 25, 2021.
  1. Dec 19, 2021 at 8:35 AM
    #361
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    what were my chase lights too bright at 100%?
  2. Dec 19, 2021 at 8:38 AM
    #362
    TRDFerguson
    TRDFerguson [OP] SSEM #99/RGBA #8-ish?/It’s a funny name.
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Perhaps a tad…
  3. Dec 19, 2021 at 8:43 AM
    #363
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    I get all that and 100% agree with you on the benefits and quality of the switch pros, but I have a hard time with the 2 year warranty on a fairly non-serviceable product (although I haven’t read too many posts here or on the jeep forums of failures). Guess I’m a little more comfortable with the idea of buying a more reasonably priced controller and throwing on a flasher module from speedtechlights or $15 Amazon voltage regulator for brightness control. Dunno, just my $.02
    TRDFerguson[OP] likes this.
  4. Dec 19, 2021 at 9:23 AM
    #364
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Aux beam 260
    8 flasher @15 each=120
    8 pwm modules @ 15 each =120
    nets you 500, plus a complete packaging nightmare and the inability to control them from the cab(without additional circuitry)…
    Example…from the comfort of the driver’s seat or any app BT connected device in range, i click circuit 1 button: (based on my programming, if I get bored I’ll create an option flow)
    Once: it is whatever brightness I had set last
    Once and hold: it will cycle down through the brightness options (100,50,10)
    Double click: burst strobe mode at previously set brightness.
    that is just scratching the surface of what a real PDM can do, all while being in a single compact package:
    so I sincerely disagree with your statement on value. It is your truck you’re free to do as you please, but as someone who is entrusting his life and the lives of others to have reliable power delivery on a 6,000+lb semi-intelligently guided missile at 65+ mph though the desert or through some sketchy rock sections. So my vote is a tried-n-trued field tested automotive grade PDM.
    -JS
  5. Dec 19, 2021 at 9:34 AM
    #365
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Jason already made good points about adding in things in the electrical arena so I won’t beat up on that. I feel like the Auxbeam and similar modules are great if all you want to do is binary lighting control. If you want to do more, it’s probably a better idea to roll that budget into a purpose built product for the extra $100-200 over the piecemeal method. And this is coming from me, who I consider a notorious cheap-ass hacker.
    BiggHertz likes this.
  6. Dec 19, 2021 at 9:36 AM
    #366
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    cheap ass hacker huh?
  7. Dec 19, 2021 at 9:44 AM
    #367
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Added hyphenation for clarity…
  8. Dec 21, 2021 at 12:50 PM
    #368
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    New air chucks arrived today and they work perfect. Tested it out on the truck and everything worked as expected.
    1E815FC2-829F-4677-BF61-47ACB774AD1A.jpg 78188AEB-6615-44DE-9386-667C73C5023A.jpg 6D7AB7B8-C36E-4999-8A8C-421B1391303C.jpg 9B4FE92B-D9CE-4527-8C51-4E84D228ACBC.jpg
  9. Dec 22, 2021 at 10:07 AM
    #369
    MattJakobs
    MattJakobs New Member
    Matthew
    NorCal
    I just ordered one of those switch holders - where'd you get those switches though?
  10. Dec 22, 2021 at 10:20 AM
    #370
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    MattJakobs[QUOTED] likes this.
  11. Dec 22, 2021 at 10:58 AM
    #371
    thedonn
    thedonn New Member
    Better to be known as a cheap ass than to be known as an ass hacker lol
  12. Dec 27, 2021 at 8:04 AM
    #372
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
  13. Jan 3, 2022 at 2:56 PM
    #373
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Finally made it back from vacation and had my amber replacement lenses waiting for me! Slapped them on, now I just need to wait for the sun to go down to see how they do.
  14. Jan 3, 2022 at 3:24 PM
    #374
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Here's a parts list for anyone looking into building one of these: https://www.amazon.com/hz/wishlist/ls/ZSRJSIN6UCJO?ref_=wl_share
  15. Jan 3, 2022 at 7:02 PM
    #375
    thedonn
    thedonn New Member
    did you mount the compressor ? if not how is it powered?
  16. Jan 3, 2022 at 8:08 PM
    #376
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I'm not going to mount it at this point. I like the idea of keeping in portable, just in case I need to use it on the wife's car or share with a fellow off-roader. The Viair 400p has alligator clamps that go straight to the battery terminals.
    RainMan_PNW, AZTundra and jhardy1979 like this.
  17. Jan 10, 2022 at 7:52 PM
    #377
    thedonn
    thedonn New Member
    what dash cam did you get? im trying to decide if it is worthwhile to get a kenwood dash cam so i can see it on the head unit or if i should just get the best dash cam for the money. and by the way - thanks for all the help!
  18. Jan 10, 2022 at 8:03 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I’ve got an Apeman - not a fan of it. It does the job, as far capturing footage in case of an accident or whatever, but it’s not great for getting footage off from random cool shit like seeing a funky car or something crazy on the trail. I’m eventually going to get a Thinkware, just haven’t done the research to know which model yet. @AT x AT has a nice one and might have some suggestions.
  19. Jan 10, 2022 at 8:08 PM
    #379
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Noticed this on the way home today. I’m thinking I might be due for an alignment. I’m driving straight.
    pvn.beluga and 1794TX like this.
  20. Jan 10, 2022 at 8:35 PM
    #380
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    :eek2:
    that would drive me nuts!
  21. Jan 10, 2022 at 8:41 PM
    #381
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I was a bit frustrated after just getting all this squared away a couple months ago.
    At least playing in the dirt over the weekend was fun, lol.
  22. Jan 10, 2022 at 9:08 PM
    #382
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    This is what happens when you follow me!
  23. Jan 12, 2022 at 8:52 AM
    #383
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    The CaliRaisedLED brackets mount to the top of the 14mm bolt of the outer side of the crash bar... I'm wondering what would happen if I were to flip the brackets. It wouldn't be secured from the top though...
  24. Jan 12, 2022 at 8:57 AM
    #384
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I was able to get my brackets lined up slightly better that way, but there was a significant amount of bounce when off road.
  25. Jan 12, 2022 at 9:02 AM
    #385
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    That's what I'm worried about too since it is to be mounted to 2 locations.
  26. Jan 13, 2022 at 1:10 PM
    #386
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Alignment went well, drives straight and the numbers seem good. Still sounds like I’ll need UCAs before too long, but it’s not an immediate requirement.
  27. Jan 17, 2022 at 8:05 AM
    #387
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Threw some 1” lift shackles back on the truck on Friday, along with doing a tire rotation. With the Icon expansion pack and the shackle lift, I’ve got a little bit of rake back to go along with the Westcott lift on the front. Seemed to do pretty well off road yesterday, so I’m happy with the results all around.
    I’ll just pretend I didn’t see that bed flex…
  28. Jan 26, 2022 at 5:32 PM
    #388
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    They have this:
    I've considered pulling the...trigger...
    buuuuut I don't wanna have to seal up all the switch holes I've made :rofl:
  29. Feb 6, 2022 at 7:07 AM
    #389
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Added mounts for my Garmin InReach Mini and knock off GoPro. Waiting on a mini USB splitter to be able to hard wire the GoPro from my dash cam’s mirror power tap.
  30. Feb 9, 2022 at 6:28 PM
    #390
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Started working on my chase lights. I originally had these on the A-pillars for ditch lights but will be purchasing some SSC2 Pros soon to do that job a bit better. The SSC1 Pros should be awesome chase lights.
    I wanted to mount these on the last panel of the tonneau cover, but the way it folds would have run into the lights when folded up. I decided to use some fender washers to sandwich the cap over the stake pockets and this should be a good spot. Next up, wiring.
    1A15C898-9AB9-43DC-B4E0-C3BB8FD51ED5.jpg D9AFE6F1-350E-415E-BFCE-54DE3906104A.jpg 0EA2407B-D759-4E73-81A6-E4FF8DDDCF76.jpg AEA8ECEA-778D-4F6E-93FD-673C9BECD6B1.jpg EBB00F7A-026C-46A4-8F0C-88FB1D920A4E.jpg
