Can this be fixed? (Small dent and paint transfer)
Discussion in 'Detailing' started by wsutundra, Jan 27, 2022.
  1. Jan 27, 2022 at 9:34 PM
    wsutundra
    wsutundra [OP] 2021 Smoked Mesquite 1794
    659BC3D6-6704-4A17-BAA2-E1A8DFC6F9B8.jpg Came back from lunch to this. Can it be fixed? Doesn’t seem like a big dent. Can’t tell if its scraped or not. Could be just paint transfer. Really sucks because it’s less than a year old!
  2. Jan 27, 2022 at 10:00 PM
    Freeezen
    Freeezen New Member
    If it's dented I can't really help with that. Wash the area first with car soap. Then use some car soap, all purpose cleaner or even a quick detailer and use a magic eraser to go over the paint transfer. Finish up with some polish on a microfiber applicator or towel to clean up some of the finer scratches.
  3. Jan 27, 2022 at 10:09 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Where is it on the truck?
  4. Jan 28, 2022 at 4:13 AM
    wsutundra
    Door panel
  5. Jan 28, 2022 at 4:43 AM
    Looks like that paint transfer will come off with Turtle Wax rubbing compound. Do not use a magic eraser....they can be abrasive if not used correctly.
    GODZILLA likes this.
  6. Jan 28, 2022 at 5:14 AM
    wsutundra
    Yep just bought some meguiars compound. I have a DA so should work good. Found a PDR guy who has excellent reviews.
  7. Jan 28, 2022 at 5:16 AM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    for paint transfer, have you just tried using lacquer thinner? And assessed if there is any actual dent/ding?
  8. Jan 28, 2022 at 5:16 AM
    It's possible that it will come off easily using the compound and a cloth.
  9. Jan 28, 2022 at 5:17 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    As others have said, looks like the paint transfer can be removed with rubbing compound followed by finish polish, using a machine polisher will yield the best results. As for the dent, you can use a paint-less dent removal service. I've never used them myself but I've seen the results from a friends car door, and it's not expensive either.
    One of our neighbors backed into my brother-in-law 4Runner and left a scuff on his driver front door, no dent though. I just buffed the area with rubbing compound and an medium pad followed by finish polish on a finishing pad, just like new. Down side was he wanted me to do the entire vehicle lol
    Last week I saw that someone had transferred some blue paint onto the cab of my truck just behind the rear door, luckily it wasn't dented. I just used some rubbing compound and a microfiber towel and the paint transfer came off easily. Then I applied some spray wax to the area. You'd never notice. The truck will get a full detail in the spring.
    Tundra234 likes this.
  10. Jan 28, 2022 at 5:17 AM
    :eek:......Rubbing compound will easily take it off.
  11. Jan 28, 2022 at 5:19 AM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Also has the greater chance of introducing micro marring and haziness resulting in a blotchy spot on panel.
  12. Jan 28, 2022 at 5:20 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    What really sucks is how high up the door it is, only tells me another large truck did it. I can't stand dings/paint scrapes, even on my 2001 4Runner so I park away from others!
  13. Jan 28, 2022 at 5:28 AM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    You’d be surprised how a quick wipe in the general direction “grain” of transfer, followed by IPA wipe will do. Or even IPA alone. Followed by sealant and wax of choice.
    this is done all the time in body shops on cured clear coat…it is really effective and time efficient to assess what is or isn’t needed for for panel correction…
  14. Jan 28, 2022 at 5:28 AM
    Kung
    KG, VA
    I had the exact same thing happen to me a few months ago, though I was lucky in that there was no dent. The paint transfer was worse than yours, but the local shop was able to get it off for about 20 minutes worth of work and a 10-spot. :)
  15. Jan 28, 2022 at 7:31 AM
    justcuz
    justcuz 2.5 Gen Member
    Tundratoofun likes this.
  16. Feb 2, 2022 at 5:08 PM
    wsutundra
    Will pulling this dent by means of PDR damage the paint?
  17. Feb 5, 2022 at 6:11 PM
    wsutundra
    1D010FF1-C6BA-4F08-9183-A3C2EF96104C.jpg Update: dent was fixed
    biebs96 likes this.
  18. Feb 5, 2022 at 6:25 PM
    Tilley’s Tundra
    Tilley’s Tundra New Member
    Jerry
    2021 Trail Edition Crewmax
    Looks great! What did you end up doing? Always good to hear success stories!
  19. Feb 5, 2022 at 6:37 PM
    wsutundra
    PDR guy for $300. Happy with how it turned out. Don’t even notice anything except a very minor ding now that you would really have to search to find.
  20. Feb 5, 2022 at 6:46 PM
    Tilley’s Tundra
    Jerry
    Definitely worth it! Glad it worked out for ya.
